Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > GPGORT
Old 06-20-2012, 09:23   #1 (permalink)
Member: 989106
Sonork: kucing
Samsung SPH-D720 problem, plz answer me this time
Sir i Have Problem with samsung SPH-D720.
if i put internal sd to phone, phone cant power on
if i dont put internal to phone, phone can power on but stuck at google logo.
i have try repair, repair succes but problem not remain
i try write full dump with Raw format from support zone, but still not remain.
can u tell me what problem?
emmc problem or what?
If yes EMMC problem, how to fix this,need to replace?
or can i write with emmc file from support download?
thx...........
Old 06-20-2012, 10:32   #2 (permalink)
Electroboys's Avatar
Member: 6594
Sonork: 100.27285
There is eMMC image file in the support and you can write - YES !
This is certainly not dead boot problem problem is with the eMMC part
Try to write and see if it works for you !
Tips :
You should select S5PC110_eMMC before you click SCAN so it will initialize the eMMC not NAND
Best Regards
Oz
Old 06-20-2012, 10:58   #3 (permalink)
Member: 989106
Sonork: kucing
There is have a two file when extract the file.
one is small size,and other one is big size.
which need to write first?
thx for answer me sir
Old 06-20-2012, 12:05   #4 (permalink)
Member: 989106
Sonork: kucing
ok i now which need to write first.
i read from doc manual, thx for fast respond sir.
Old 06-20-2012, 12:10   #5 (permalink)
Crazy Poster
Member: 731821
may be this thread can help u
txs
Old 06-20-2012, 15:01   #6 (permalink)
Member: 989106
Sonork: kucing
THX.... m.akbar06
my SPH-D720 Under proses now......
what happent with u phone,have u Done u problem?
Old 06-20-2012, 17:19   #7 (permalink)
Crazy Poster
Member: 731821
not done yet
1st. i got this phone with empty batrey problem
after some experiment probably i have erase my efs
now my phone get unknown baseband problem
until now still can't recovery my baseband
in normal mode can't connect to PC ( charge only ) ,can't mount sdcard
would you backup efs from this kind phone after all JOB finish
use this sw
https://www.dropbox.com/s/ey1gw42a6a....7_Release.zip
or maybe asansam or other tools.
txs
Old 06-20-2012, 18:22   #8 (permalink)
Member: 989106
Sonork: kucing
u can fix u baseband problem,but i not sure for batry empty.
ok.... i hope my phone will be done,so i can backup efs for u.
The Following User Says Thank You to balestier For This Useful Post:
Old 06-20-2012, 22:56   #9 (permalink)
Member: 989106
Sonork: kucing
Sir can u tell me what should i do after write two emmc file.
because now cant power on with emmc inside,or without inside.
Plz give sugestion again
Old 06-20-2012, 23:11   #10 (permalink)
Member: 989106
Sonork: kucing
ops.......... sory this my mistake..
i try for swtch on with power suplly, but cant power on.
Now try with batry and still power on.
firs step emmc file write complete.
Now time for write second step.....
its very need long time.
Old 06-21-2012, 09:23   #11 (permalink)
Crazy Poster
Member: 731821
yup same very long...long..long time
Vref:2.838V
TCK:RTCK
Model:S5PC110_eMMC
TAP0,IRLength:4,DeviceID:0x1BA00477
CPUID:0x1BA00477,S5PC110,IOLevel:2.8V
FlashID:0x0000000053450102,SubFlashID:0x000000004D 313647
BlockSize:512
PageSize:512
Density:16384MB
Actual Density:0x3B5400000
FlashName:SEM16G
Write Speed:25385/s (5 hours,53 minutes,10 seconds) => D720_0x00000000_P1.bin
Write Speed:23716/s (12 hours,34 minutes,34 seconds) => D720_0x00000000_P2.bin
SkipEmpty => checked
Old 06-21-2012, 22:51   #12 (permalink)
Member: 989106
Sonork: kucing
Vref:2.666V
TCK:12MHz
Model:S5PC110_eMMC
FlashID:0x0000000053440002,SubFlashID:0x000000004D 303332
BlockSize:512
PageSize:512
Density:0MB
Actual Density:0x1E9C000
i,m still write p2 emmc bin file tonight
because last night i,m very tire.
But i not sure can fix my problem with this metode.
way at my ort log show Density 0 when i conect with choice S5pc110_EMMC.
what it means?
i,m afraid this only was my time. heheheheh
Old 06-22-2012, 09:24   #13 (permalink)
Member: 6594
Sonork: 100.27285
The files we have tested on a dead device and it worked for us !
We try to test as many as possible every device support before we release them
Best regards
Oz
Old 06-22-2012, 19:34   #14 (permalink)
Crazy Poster
Member: 731821
i'm thinks file is OK
but maybe there is something wrong with our step
this my last flash result , still have same problem
Old 06-23-2012, 21:26   #15 (permalink)
Member: 989106
Sonork: kucing
Best regards
Oz
Yes sir, i now u file is ok.
But i Means Perhaps my emmc is damage, so i can,t fix my problem.
can u tell me why Show density 0 when conect with check S5pc110_EMMC.
althoug succsess Write the EMMC file.
What it Means Sir?
Plz Answer my question for the last. thx B4 Electro Boy
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-11-1999 17:39
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Page generated in 0.34599 seconds with 11 queries
