07-31-2014, 14:01 | #3 (permalink) |
No Life Poster Join Date: Apr 2008 Location: INSIDE OCLHASHCAT
Member: 751235 Status: Offline Sonork: 100.1662008 Thanks Meter: 526 | HXC CABLE IS REQUIRED AND WILL BE USED FOR THIS JOB! Loading device driver dll: OK Checking device driver dll version: OK Checking device driver version: OK Searching for device: OK Switching to APPLICATION MODE: OK Searching for device: OK Found HXC CABLE! Reading HXC CABLE info: OK HXC CABLE SN: EDCB83D8322E302E HXC CABLE FW: V2.0. Please power on phone and connect to usb in android debug mode! If phone ask to allow usb debuging please accept! Searching for phone: OK Reading info: OK BRAND: HTC / SOFTBANK_JP MODEL: 001HT ACE / HTC_ACE IMEI: 356812041134303 CID: SBM__802 MID: PD9810000 HWID: SPADE-128 BOOT LOADER: 0.85.0024 VERSION: ANDROID 2.3.3 BUILD GRI40 FIRMWARE: 2.64.762.3 / 12.62.60.2501U_26.13.08.02_M KERNEL: 2.6.35.10-g0516f0f (gcc 4.4.0) CPU TYPE: MSM7X30 / ARMv7 CARD ID: 0353445353313647800139B57A00E584 Restarting phone: OK Please wait, phone is starting up: OK Searching for phone: OK Reading info: OK BRAND: HTC / SOFTBANK_JP MODEL: ACE ACE / HTC_ACE IMEI: 356812041134303 PLATFORM: HBOOT-7230 CID: SBM__802 MID: PD9810000 HWID: SPADE-128 BOOT LOADER: 0.85.0024 / dirty-ae32a7eb VERSION: ANDROID 2.3.3 0.5 / 0438 FIRMWARE: 2.64.762.3 / 26.13.08.02_M KERNEL: 2.6.35.10-g0516f0f (gcc 4.4.0) CPU TYPE: MSM7X30 / ARMv7 CARD ID: 0353445353313647800139B57A00E584 SECURITY FLAG: ON BATTERY STATUS: GOOD SMARTCARD Emulator running: WARNING! SIMUNLOCK in this mode maybe not supported by THIS PARTICULAR PHONE! Writing simlock: ERROR [NOT_SUPPORTED1] PLEASE USE <UNLOCK by HBOOT SIMLOCK MENU> METHOD! SMARTCARD Emulator running: STOPPED End HTC Desire HD UNLOCK at 4:24:17 AM Start HTC Desire HD UNLOCK (HBOOT SIMLOCK MENU) at 4:21:27 AM Loading device driver dll: OK Checking device driver dll version: OK Checking device driver version: OK Searching for device: OK Found HXC CABLE! Reading HXC CABLE info: OK HXC CABLE SN: EDCB83D8322E302E HXC CABLE FW: V2.0. Please power on phone and connect to usb in android debug mode! If phone ask to allow usb debuging please accept! Searching for phone: OK Reading info: OK BRAND: HTC / SOFTBANK_JP MODEL: 001HT ACE / HTC_ACE IMEI: 356812041134303 CID: SBM__802 MID: PD9810000 HWID: SPADE-128 BOOT LOADER: 0.85.0024 VERSION: ANDROID 2.3.3 BUILD GRI40 FIRMWARE: 2.64.762.3 / 12.62.60.2501U_26.13.08.02_M KERNEL: 2.6.35.10-g0516f0f (gcc 4.4.0) CPU TYPE: MSM7X30 / ARMv7 CARD ID: 0353445353313647800139B57A00E584 Searching for phone: OK Reading info: OK Checking root: OK (NOT ROOTED) Please wait, running TEMPROOT[2]: OK Searching for phone: OK Checking root: OK (NOT ROOTED) Please wait, running TEMPROOT[3]: OK Searching for phone: OK Checking root: OK (NOT ROOTED) Temproot not work, please root phone manually! Restarting phone: phone cant unlock |
07-31-2014, 15:24 | #4 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: tr
Member: 539148 Status: Offline Thanks Meter: 2,174 | Please First make root the phone then try again... Quote:
Good Lucks.. BR, Dicle_Gsm | |
07-31-2014, 17:47 | #6 (permalink) |
Member: 751235 Status: Offline Sonork: 100.1662008 Thanks Meter: 526 | clean s58 data function is not working in *****.......... ah whats so special about this box? i regret buying it..... up till now not even a single phone has been done with this box |
08-05-2014, 16:53 | #7 (permalink) | |
Member: 751235 Status: Offline Sonork: 100.1662008 Thanks Meter: 526 | Quote:
Start HTC Desire HD UNLOCK (HBOOT SIMLOCK MENU) at 4:22:24 AM Loading device driver dll: OK Checking device driver dll version: OK Checking device driver version: OK Searching for device: OK Found HXC CABLE! Reading HXC CABLE info: OK HXC CABLE SN: EDCB83D8322E302E HXC CABLE FW: V2.0. Please power on phone and connect to usb in android debug mode! If phone ask to allow usb debuging please accept! Searching for phone: OK Reading info: OK BRAND: HTC / SOFTBANK_JP MODEL: 001HT ACE / HTC_ACE IMEI: 356812041134303 CID: SBM__802 MID: PD9810000 HWID: SPADE-128 BOOT LOADER: 0.85.0024 VERSION: ANDROID 2.3.3 BUILD GRI40 FIRMWARE: 2.64.762.3 / 12.62.60.2501U_26.13.08.02_M KERNEL: 2.6.35.10-g0516f0f (gcc 4.4.0) CPU TYPE: MSM7X30 / ARMv7 CARD ID: 0030004150505344001280000000D316 Searching for phone: OK Reading info: OK Checking root: OK (ROOTED) Writing card: OK Writing data: ERROR(UART_C:NOT_ASSIGNED) Restarting phone: OK End HTC Desire HD UNLOCK (HBOOT SIMLOCK MENU) at 4:23:13 AM | |
08-05-2014, 17:26 | #8 (permalink) | |
Member: 539148 Status: Offline Thanks Meter: 2,174 | Quote:
HI Bro, for by hboot simlock direct unlock method phone is should be s-off so, please first make s-off then try again. or try to read codes to phone.. if still same then use HXC old version mean 3.20 Good Lucks! BR, Dicle_Gsm | |
08-06-2014, 08:25 | #11 (permalink) | |
