Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > MAGMA BOX
Old 03-24-2015, 18:37   #1 (permalink)
Member: 2242847
Thanks Meter: 5
htc m7 uk vodafone red triangle plz help
C:\android-sdk\platform-tools>fastboot getvar all
(bootloader) version: 0.5
(bootloader) version-bootloader: 1.57.0000
(bootloader) version-baseband: 4T.28.3218.04
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main:
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: FA3AHW907441
(bootloader) imei: 359405051054904
(bootloader) meid: 00000000000000
(bootloader) product: m7_ul
(bootloader) platform: HBOOT-8064
(bootloader) modelid: PN0710000
(bootloader) cidnum: VODAP001
(bootloader) battery-status: good
(bootloader) battery-voltage: 3752mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: dirty-6d8a0b9b
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
all: Done!
finished. total time: 0.044s
i have managed to unlock the bootloader
phone is not s off
i have also installed philzrecovery through fastboot
i have also send the rootfile su through sideload
now how can i flash this phone i have tried several roms.zipz through sideload but no luck plz help me
Old 03-24-2015, 19:41   #2 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
If phone is S-ON you must need of Relock Bootloader first of flash ROM, and cannot flash ANY rom but only what mutch with you Cid....if use Search button can have miracle from this same forum...
The Following User Says Thank You to allumts For This Useful Post:
Old 03-25-2015, 12:26   #3 (permalink)
Member: 2242847
Thanks Meter: 5
thank x for ur help allumts but what the steps
relock bootloader i understand this
then you are saying falsh of first rom what do you mean by that
then you are saying what much of your cid i didnt understand what are you trying to say
Old 03-26-2015, 08:56   #4 (permalink)
dicle_gsm's Avatar
Member: 539148
Thanks Meter: 2,174
HI,
install this rom via recovery : Android Revolution HD - Mirror Site
if you want write stock rom then relock the bootloader and find stock rom for same cid phone, : VODAP001,
BR,
Dicle_Gsm
Old 03-26-2015, 13:36   #5 (permalink)
allumts's Avatar
Member: 1564612
Yes perfect friend @Dicle_Gsm....you have understand speed what i've wrote above to @memo1234....
had thinked that him know how write one ROM in HTC S-ON...but i was on wrong way...
Now next step hope isn't What rom write... first of this i post this easy tutorial for understand easy Right ROM for his Cid phone:
http://forum.gsmhosting.com/vbb/f485...0/#post9274756
Obvius that this is for all members...
allumts
Old 03-26-2015, 13:51   #6 (permalink)
Member: 2242847
Thanks Meter: 5
your are some guy man thank you so much my friend helping people is a great thing
thank you bro
Old 03-26-2015, 13:56   #7 (permalink)
Member: 2242847
Thanks Meter: 5
how can i flash with recovery you mean by sideload or by fastboot
which cmd comand i need to use
i ahev already installed philz recovery by fastboot
do i need to relock my bootloader before your file
Old 03-26-2015, 14:08   #8 (permalink)
dicle_gsm's Avatar
Member: 539148
Thanks Meter: 2,174
you can via install sideload or via otg cable,
The Following User Says Thank You to dicle_gsm For This Useful Post:
Old 03-26-2015, 16:55   #9 (permalink)
Member: 2242847
Thanks Meter: 5
thank you firend but do i have to relock bootloader dicl gsm
Old 03-26-2015, 20:35   #10 (permalink)
allumts's Avatar
Member: 1564612
@memo1234,
loock:
install TWRP 2.6.3.3 for M7_UL, (work with charme), not use PhilzRecovery, via fasboot cmd
then go in Advanced/install via Sideload....
You are S-ON, so you have need of relock bootloader...
allumts
Old 03-27-2015, 19:24   #11 (permalink)
Member: 2242847
Thanks Meter: 5
thann you so much bro i will try and post results
Old 03-30-2015, 13:53   #12 (permalink)
Member: 2242847
Thanks Meter: 5
allumts my friend you are a super star
your solution worked i wish i could thank you more just a quistion
how did you know that this rom will work is this is a custom rom caue i had s-on
was your rom a custom rom
cause i wanna fllash htc more where can i get these kinda rom that u sent me how did you this rom would work
thank you again
Page generated in 0.19094 seconds with 9 queries
