Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > MAGMA BOX
Old 03-28-2015, 14:44   #1 (permalink)
lasergsm's Avatar
Member: 1594457
Sonork: 100.1646470
Thanks Meter: 145
HTC One S VilleC2 hang on logo
help sir i need firmware HTC One S VilleC2 cid 044
File Type: jpg 996732_10200157626972388_1584410412_n.jpg (310.0 KB, 59 views)
Old 03-29-2015, 05:31   #2 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,621
You device is hang on and Security ie S-ON. Get the same CID file and Flash the device OR you can use JTAG operations.
Dipendra Pathak
Old 03-29-2015, 06:17   #3 (permalink)
lasergsm's Avatar
Member: 1594457
Sonork: 100.1646470
Thanks Meter: 145
Dipendra Pathak
I was tired of searching the files but did not find her. if you have it? please my master
Old 03-30-2015, 12:44   #4 (permalink)
M7moud 7assan's Avatar
Member: 719979
Sonork: 100.1589075
Thanks Meter: 121
try flash cmw and install rom from it , i think is good in this case
Old 03-30-2015, 14:41   #5 (permalink)
lasergsm's Avatar
Member: 1594457
Sonork: 100.1646470
Thanks Meter: 145
you have it? please give me the link
Old 03-30-2015, 14:59   #6 (permalink)
Member: 719979
Sonork: 100.1589075
Thanks Meter: 121
recovery file from here
Supersu.Download Here
Guide.
*Copy recovery file you download before "openrecovery-twrp-2.2.1-villec2.img" at the same fastboot folder
*open command and flash follow like this
fastboot flash recovery openrecovery-twrp-2.2.1-villec2.img
Old 03-30-2015, 15:13   #7 (permalink)
lasergsm's Avatar
Member: 1594457
Sonork: 100.1646470
Thanks Meter: 145
Guide.
where its firmware sir?...
Old 03-30-2015, 15:58   #8 (permalink)
Member: 719979
Sonork: 100.1589075
Thanks Meter: 121
Instructions:
If it's the first time flashing avatarrom or coming from another ROM
Do a NANDroid backup of your current ROM from backup/restore menu.
Wipe Data/Factory Reset & Wipe cache partition
Flash the downloaded .zip file.
Install Gapps package. If you get Google search crash update Google search from play store.
Download Avatar ROM:
Android version 4.2.2 based on CM10.1
rom
Camcorder fix
Gapps (4.2.2)
Old 03-30-2015, 15:58   #9 (permalink)
Member: 719979
Sonork: 100.1589075
Thanks Meter: 121
Dont forget let me know after you flashed
and press thank you
The Following User Says Thank You to M7moud 7assan For This Useful Post:
Old 03-30-2015, 17:12   #10 (permalink)
lasergsm's Avatar
Member: 1594457
Sonork: 100.1646470
Thanks Meter: 145
how to put file zip to phone?...i can't acces internal memory of phone sir?..This phone is no external memory>>>
Old 03-30-2015, 17:24   #11 (permalink)
Member: 719979
Sonork: 100.1589075
Thanks Meter: 121
from recovery go to mount storage then usb
Old 03-30-2015, 18:14   #12 (permalink)
lasergsm's Avatar
Member: 1594457
Sonork: 100.1646470
Thanks Meter: 145
still unchanged
is there anything wrong? ...
Old 03-30-2015, 18:18   #13 (permalink)
Member: 719979
Sonork: 100.1589075
Thanks Meter: 121
try wipe data / cach and try flashing
Old 03-30-2015, 18:37   #14 (permalink)
lasergsm's Avatar
Member: 1594457
Sonork: 100.1646470
Thanks Meter: 145
still as before and no change sir>>
Old 03-30-2015, 18:53   #15 (permalink)
Member: 719979
Sonork: 100.1589075
Thanks Meter: 121
give me photo for phone on hboot
Page generated in 0.21246 seconds with 9 queries
