06-06-2014, 21:30 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: . Age: 35
Member: 400280 Status: Offline Thanks Meter: 83 | Impossible UNlock HTC ONE M7!!! I tried unlock by HBoot but I don't understand some things Here is my log: Code: Start HTC M7_UL UNLOCK (HBOOT SIMLOCK MENU) at 03:23:14 p.m. Please power on phone and connect to usb in android debug mode! If phone ask to allow usb debuging please accept! Searching for phone: OK Reading info: OK BRAND: HTC / CINGULAR_US MODEL: HTC ONE M7 IMEI: 784785489654874 CID: HTC__A07 MID: PN0710000 HWID: M7-3 BOOT LOADER: 1.44.0000 VERSION: ANDROID 4.1.2 BUILD JZO54K FIRMWARE: 1.26.502.12 / 4A.14.3250.13_10.33.1150.01L KERNEL: 3.4.10-g0a0f902 (gcc 4.6.x-google) CPU TYPE: MSM8960 / ARMv7 Searching for phone: OK Reading info: OK Checking root: OK (ROOTED) Installing app: OK Writing data: OK Running app: OK Please REMOVE CABLE from phone Process require Y CABLE (USB OTG CABLE with external power) Please follow instructions from app on phone display After phone restart, reconnect Y cable to phone (if see message: "Please plug off USB") Select HBOOT MODE (if not already selected) Select SIMLOCK MENU using [VOLUME UP] / [VOLUME DOWN] Press [POWER] to confirm and wait for process to finish! OR (for older models) Press [SEND] to select SIMLOCK MENU! Wait for process to finish! NETWORK CODE RESET TO: 00000000! End HTC M7_UL UNLOCK (HBOOT SIMLOCK MENU) at 03:24:09 p.m. this is the green cable??? which SD ??? with external sd reader??? PLzzz I need some steps explanation for dummies.. or video... because I don't understand!! when I put these cable nothing happened. sorry for my bad english |
06-07-2014, 13:53 | #3 (permalink) |
Junior Member Join Date: Mar 2012 Location: Dublin, Ireland
Member: 1738637 Status: Offline Sonork: 100.1627531 Thanks Meter: 7 | Hd7 y-cable don't work ***** box is not as good as it said on the forum . But good for repaire imei . 1) try at least 3 htc one m7 , all rooted and s-off , cid set to 111111 . can not directly unlock by ***** . try hboot unlock method , the hd7 y-cable come with the box don't work for me . maybe we need some special y-cable for htc one . 2) htc one m8 . try at least 5 pics , all rooted and s off , cid set to 111111, can not directly unlock by *****. please explain what kind y cable will work for htc one , if need to purchase , give me the link . get really tired of it |
06-07-2014, 21:47 | #4 (permalink) |
Freak Poster Join Date: Jul 2011 Location: in /dev/null/01110cod3r1100101
Member: 1613754 Status: Offline Sonork: 1623976 Thanks Meter: 115 | HxC ***** no good software nothing work for HTC devices. |
The Following User Says Thank You to cod3r For This Useful Post: |
06-10-2014, 06:50 | #5 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | @Medusin Please use good company pandrive like kingston and must format to fat32. @cod3r Please check unknown source from security and please report me back. |
The Following User Says Thank You to Rahul_Bhutani For This Useful Post: |
06-10-2014, 11:40 | #6 (permalink) |
Member: 1613754 Status: Offline Sonork: 1623976 Thanks Meter: 115 | @Rahul Bhutani bro, ***** can not unlock the HTC One M7 on 4.4.2, i'm check Unknown Source, and nothing. I'm downgrade to 4.1.2 and hboot to 1.44 and successful unlock. Pls solve this problem on 4.4.2 Br |
06-12-2014, 23:24 | #7 (permalink) | |
Member: 400280 Status: Offline Thanks Meter: 83 | Quote:
thanks for reply, I will use it but I need know more about how tu use this cable... steps etc, because ok, I format fat32 and... then??? what I do? thanks best regards | |
06-13-2014, 07:51 | #8 (permalink) |
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Repeat the process and when software ask to connect otg cable connect one side to pc usb if otg cable attach pen drive or a good sdcard with good sdcard reader,and follow instruction on phone ***** app. PS:if in case phone not detect your otg cable repeat process with another pen drive or card reader. |
06-20-2014, 22:02 | #9 (permalink) | |
I have a question... This HTC ask about PIN IMSI SIM... with this method is possible unlock it?? | |
