01-14-2015, 14:43 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Kathmandu, Nepal
Member: 260236 Status: Offline Sonork: 100.1641081 Thanks Meter: 135 | ***** not working as promised!! Check logs [ANSWERED] If phone ask to allow usb debuging please accept! Searching for phone: OK Reading info: OK BRAND: SAMSUNG / KDDI MODEL: SCL22 SCL22 IMEI: 99xxxxxxxxxxxx HWID: QCOM-10 BOOT LOADER: SCL22KDU2FNF7 VERSION: ANDROID 4.4.2 BUILD KOT49H / SCL22KDU2FNF7 SCL22KDU2FNF7 / SCL22KDI2FNF7 (PDA/CSC) FIRMWARE: HLTEKDI-USER / SCL22KDU2FNF7 HARDWARE: N900J.09 KERNEL: 3.4.0-1990145 (gcc 4.7) PHONE SN: 00000000000 CPU TYPE: MSM8974 / ARMv7 Checking server 1: NOT OK Checking server 2: NOT OK Checking server 3: OK Connecting to server: OK Asking server for access: OK Checking if version supported by server: OK THIS VERSION IS NOT TESTED! CHANCES TO GET UNLOCK ARE HIGH BUT BE WARNED IT COULD NOT WORK EITHER! After unlock process finished please check if phone unlocked and PLEASE REPORT TO US ON FORUM! System Error. Code: 5. Access is denied End KDDI Galaxy Note 3 LTE SCL22 UNLOCK at 7:27:25 PM |
01-14-2015, 14:44 | #2 (permalink) |
Member: 260236 Status: Offline Sonork: 100.1641081 Thanks Meter: 135 | Start Chinese MOBA MT8 UNLOCK at 7:32:25 PM Waiting for USB connection: OK Sending loader: OK Reading flash: ERROR End Chinese MOBA MT8 UNLOCK at 7:32:42 PM |
01-14-2015, 15:46 | #3 (permalink) |
Freak Poster Join Date: May 2014 Location: In the Chip Level
Member: 2187058 Status: Offline Thanks Meter: 41 | Does the device ask "SIM PIN" when you put unsupported Sim card? If not, not possible. I did not see any GSM device supports this device. Still, ***** Box trying to do this Your device has 4.4.2 New Security and Knox version 2. So, you can think yourself. If the device ask "SIM PIN" you can use factory unlock button if support is online. BR Micro Mind? |
01-15-2015, 15:49 | #5 (permalink) | |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Quote:
What we are not doing brother, we are doing as we have promised. Check the log above, software TIPS. It is clearly said that..........just let it know us if something happen. We will work on it; if possible. Thank you for your report. We will send this report to the coder. Post the logs, screen short as we have described in our sticky thread. BR Dipendra Pathak | |
01-22-2015, 14:55 | #6 (permalink) | |
Member: 260236 Status: Offline Sonork: 100.1641081 Thanks Meter: 135 | Quote:
Regards, Ace | |
01-24-2015, 10:32 | #8 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Pakistan & UAE (Dubai) Age: 34
Member: 1526738 Status: Offline Sonork: 100.1607644 Thanks Meter: 6,688 | @ace_venturia Phone Must Be Need USB Debuging Enable need Root your phone then read info and unlock Best Regards GPG team |
01-25-2015, 15:34 | #9 (permalink) | |
Member: 260236 Status: Offline Sonork: 100.1641081 Thanks Meter: 135 | This is funny Quote:
1. There is no 'Read Info' for MOBA MT8 2. The process you described is not as in the help context of the software. There is no adb connection mode in the interface while only samsung spd usb is available. | |
01-25-2015, 16:56 | #10 (permalink) |
Member: 1526738 Status: Offline Sonork: 100.1607644 Thanks Meter: 6,688 | Please don't try to make user fool check here if you again face this problem turn off phone remove battery and put it again then PRESS HOLD BOTH VOL Buttens and press start butten in ***** box then conect mobile Best Regards GPG team |
01-26-2015, 15:00 | #11 (permalink) | |
Member: 260236 Status: Offline Sonork: 100.1641081 Thanks Meter: 135 | Plesae check before blaming Quote:
Please check my previuos post, the error logs have been posted. There is no problem in connecting the handset. the error is rather different. And check your previous post you told the handset's usb debug mode should be enabled and to make a 'read info'. The thing I pointed was there is no usb debug connection in the model to be unlocked and neither there is 'read info' function for the model. So, your post is mis-guiding. Regards. | |
