Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2010 Location: India Age: 20
Member: 1713856 Status: Offline Sonork: 100.1592878 Thanks: 4
| Root Guides For Hxc Dongle Users. How To Root One V [INSTRUCTIONS]: [Prerequisites:] HTC Sync (Windows Only) HTC Super Tool r1-primo-superboot.zip Enable USB Debug Use Charge Only mode when connected to PC Exit HTC Sync on PC [Steps:] 1. Go to HTCDEV website: HTCdev - Unlock Bootloader 2. Click on "Begin Unlock Bootloader" (create a user if you don't have one) 3. Use HTC Super Tool in the [Prerequisites] to generate your token. (Or, alternatively, follow the instructions step 1 through step 10 on htcdev.com) 4. In step 10, when posting your token, make sure you remove the blanks preceding each line 5. After you receive your Unlock_code.bin in email, follow step 11. 6. Now your One V should reboot and you have your bootloader unlocked. [Root Steps:] Switch off your HTC One V. Reboot your HTC One V into Bootloader Mode by pressing the Volume Down key and Power button simultaneously until Bootloader Mode boots. Select Fastboot from the Bootloader Menu. Connect your HTC One V to the computer via USB cable. The Bootloader screen should say “FASTBOOT USB.” Go to the r1-primo-superboot folder and double-click the install-superboot-window.bat file. This will automatically start the rooting process. Once the rooting process is complete, your HTC One V will automatically reboot. After complete boot, go to the app drawer. Tap the SuperSU icon and update the SU binary to the latest version. Congratulations! You have successfully rooted your HTC One V |
| The Following 7 Users Say Thank You to Rahul_Bhutani For This Useful Post: |
| | #2 (permalink) |
| Root Droid Incredible With Hboot 1.02.0000 [INSTRUCTIONS]: [Prerequisites:] HTC Sync (Windows Only) Su Zip ADB Fastboot CWM Recovery HBOOT Drivers Enable USB Debug Use Charge Only mode when connected to PC Exit HTC Sync on PC [Steps:] 1. Head over to HTC Dev HTCdev - Unlock Bootloader 2. Create a account or sign in (you must use your real email address) 3. Go to unlock bootloader 4. Select “HTC DROID INCREDIBLE*” 5. Follow the directions and install all the software provided and you will end up with a unlocked bootloader with s-on. Save a copy of the unlock_code.bin to your pc, so you have it after dooing the froyo ruu. 6. Enter FASTBOOT again on your phone 7.Open the command prompt again on your pc to where adb.exe is. (ie. C:\android-sdk\platform-tools or C:\adb 8. place CWM Recivery it in the same folder as fastboot (where you put unlock_code.bin ie. C:\adb) 9. for simplicity’s sake rename the above file to recovery.img if it doesn’t already save it as recovery.img. 10. In your command prompt navigate to the folder containing your fastboot files and recovery.img 11. Enter the following in the command prompt: fastboot flash recovery recovery.img 12. Once that completes navigate to recovery on your phone and press power to select it 13. Once CWM recovery boots on your phone use the volume up and down to pick Mounts and storage press the trackball to select it 14. Select Mount usb storage 15. Take Su zip and drag it to the root of your SD card. 16. On your phone press the trackball to unmount your usb storage 17. Select go back 18. Select install zip from SD card 19. Choose zip from sd card 20. Select the su.zip file we just downloaded and press power to flash 21. Reboot the phone 22. Once your phone is booted go to the market and search superuser 23. Download and install superuser 24. Search busy 25. Use one of the busybox installers and install busybox (hit allow on the su notification) 26. Enter superuser, press the menu button on your phone, select preferences, then scroll down to su-binary 27. Hit update, and allow the prompt, if all the output is in green then you have full root congrats!!! Credits Goes To cmlusco For This simple Guide... |
| The Following 3 Users Say Thank You to Rahul_Bhutani For This Useful Post: |
| | #3 (permalink) |
| ROOT Flyer+View Supported HBoot Details: HTC View (express) 1.09.0000 and 1.13.0000 HTC Flyer (flyer) 1.10.0000 and 1.11.0003 [INSTRUCTIONS]: [Prerequisites:] Read documentation Uninstall HTC Sync. Install these fastboot drivers su-3.0-beta4-efgh-signed.zip USB Debugging Should be On. [steps:] 1.Phone Should be in normal mode now not in fastboot or in any other mode. 2.Connect the device via USB. 3.Got to the revolutionary website and select the download for your platform (Windows or Linux ) do not enter anything in the form and do not close the page. 4.Run the application to get your serial number it will be something like HTCXXXXXX 5.Go back to the webpage and enter the details required on the form to get your KEY. Note: If you have a flyer select Flyer, if you have a View select Express 6.Copy and Paste the beta key back to the application and press return. If you don't know how to paste,visit the site. 7.Follow the on screen instructions. If you see this message: SUCCESS - Life gave us lemons, we didn't make lemonade! then S-OFF has been successful,Even CWM. Note:If you did not download CWM as part of the process or it failed to download, then get it from xda. ----------------------------------------------------------------------- [For Root:] Copy su-3.0-beta4-efgh-signed.zip to your sdcard root Start clockworkmod recovery bye vol down+power select recovery. Select "install zip from sdcard" Then select "Choose zip from sdcard" Then select "su-3.0-beta4-efgh-signed.zip" Then select "Yes - install su-3.0-beta4-efgh-signed.zip" to confirm Then go back Then reboot. You're rooted! if you get an error "Status 0" when installing the SU zip file, immediately retry 99% of the time that works. If you can't get CWM on view to see the su zip file. Open the lid and put an SD card in your flyer/view. It does open - it's just difficult and there is an SD slot. Alternatively Follow the instructions here but DO NOT DO STEP 1. Last edited by Rahul_Bhutani; 06-01-2012 at 09:32. |
| The Following 5 Users Say Thank You to Rahul_Bhutani For This Useful Post: |
| | #4 (permalink) |
| Root Desire S aks Saga... [INSTRUCTIONS]: [Prerequisites:] Uninstall HTC Sync. Read documentation Install these fastboot drivers su-2.3.6.3-efgh-signed.zip USB Debugging Should be On. [steps:] 1.Phone Should be in normal mode now not in fastboot or in any other mode. 2.Connect the device via USB. 3.Got to the revolutionary website and select the download for your platform (Windows or Linux ) do not enter anything in the form and do not close the page. 4.Run the application to get your serial number it will be something like HTCXXXXXX 5.Go back to the webpage and enter the details required on the form to get your KEY. 6.Copy and Paste the beta key back to the application and press return. If you don't know how to paste,visit the site. 7.Follow the on screen instructions. If you see this message: SUCCESS - Life gave us lemons, we didn't make lemonade! then S-OFF has been successful,Even CWM. ----------------------------------------------------------------------- [For Root:] Copy su-3.0-beta4-efgh-signed.zip to your sdcard root Start clockworkmod recovery bye vol down+power select recovery. Select "install zip from sdcard" Then select "Choose zip from sdcard" Then select "su-3.0-beta4-efgh-signed.zip" Then select "Yes - install su-3.0-beta4-efgh-signed.zip" to confirm Then go back Then reboot. You're rooted! if you get an error "Status 0" when installing the SU zip file, immediately retry 99% of the time that works. Congratulations! Your HTC Desire s will now have S-OFF and the phone will have been successfully rooted |
| The Following 9 Users Say Thank You to Rahul_Bhutani For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| How can I do a Welcome note for my 6110 a dosn't have any one ? | Viper | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 07-18-2012 07:57 |
| Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 05-10-2012 14:14 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware-Repair Area | 1 | 12-27-2006 10:20 |
