07-23-2014, 23:40 | #1 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2227768 Status: Offline Thanks Meter: 1 | Searching for SPRD com enumerator and MTK USB Serial Driver i am searching these drivers as listed in the title. i found one here vbb/f646/need-sprd-com-enumerator-driver-1653605/ but which doesnt work because of not being digitally signed driver (Error Code 52) Where can i find these drivers for win 7 64 bit? These are the Hardware IDs: USB\VID_1782&PID_3D00&MI_01 //SPRD COM Enumerator USB\VID_1782&PID_3D00&MI_00 //MTK USB Serial |
The Following User Says Thank You to ookana For This Useful Post: |
07-24-2014, 03:00 | #2 (permalink) | |
Product Manager Join Date: Jul 2009 Location: GsmGenesis
Member: 1084080 Status: Offline Thanks Meter: 8,204 | Quote:
Its not Perfect For Mobile Box/Device Software & Applications You have to Install Windows 7 Ultimate 32 Bits That will Work Best For Mobile Works BR, MUKESH RAJ | |
07-24-2014, 07:20 | #3 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Restart your pc and continue press f8 till menu not appear. Then select "disable driver signature enforcement" its temp solution of your problem. For permanent you can ask mr google.. |
07-24-2014, 17:25 | #4 (permalink) | |||
Member: 2227768 Status: Offline Thanks Meter: 1 | Quote:
Or is it just all about 32 Bit / 64 Bit? Quote:
By the way, does this Forum have a section, where needed drivers can be found for download? Thank you and best regards!! | |||
07-26-2014, 14:39 | #5 (permalink) | |
Yes! You Are Right , That's is Too Much Better , You Can Use Windows XP , No Problem With Drivers BR, MUKESH RAJ | |
