01-04-2012, 04:37 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Brunei dar
Member: 597784 Status: Offline Thanks Meter: 348 | Wildfire s Reset when clear s58 data[Solved] I turned check/enabled the usb debugging and htc sync as default. why pc is not detecting the mobile as ADB device it only detect as adroid device.. the problem is I wanted to install the mobile as adb device so i can proceed to unlock.. plz.. I followed every way in Sticky [frequently asked] |
01-04-2012, 04:59 | #2 (permalink) |
Member: 597784 Status: Offline Thanks Meter: 348 | the pc cant detect mobile into adb any solution from out there? Ive done it in fresh xp but still the same without the pc is no other htc driver installed. instead of adb the pc detect it as android |
01-04-2012, 07:44 | #3 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | i think for unlock this phone no need to connect to pc,select model from list then click on full unlock and follow instruction. |
The Following User Says Thank You to Rahul_Bhutani For This Useful Post: |
01-04-2012, 08:32 | #6 (permalink) | |
Member: 597784 Status: Offline Thanks Meter: 348 | Quote:
but when I used tester to check if the connection is the same with the other 2nd flex its all okay(continuity).. | |
01-04-2012, 08:33 | #7 (permalink) | |
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Quote:
01-04-2012, 09:18 | #8 (permalink) | |
Data cable | Aldrin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:06 |
cellular data suite kabel | vingis | Main Sales Section | 0 | 11-25-1999 19:18 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | Nk_Cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-10-1999 10:08 |
Cellular Data Suite Cables avaliable !!! | vingis | Main Sales Section | 0 | 11-02-1999 17:35 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | nk.cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-14-1999 15:33 |
