Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member ![]() ![]() Join Date: Jan 2009
Member: 954742 Status: Offline Thanks: 110
| Need help 9650 red light (Answer ) help me please ... ![]() what should i do with this 9650 ..red light then off , red light again here this lod .. read boot info : Connecting to Bootrom: Connected Uploading RAM Image...OK Bootrom Version: 5.13.0.7 Hardware ID: 0x07001504 RIM BlackBerry Device HW ID Override: None Metrics Version: 6.15 Build Date: Feb 18 2010 Build Time: 08:43:25 Build User: ec_agent Security: Enabled Supported Options: 0x00000005 Drivers: 0x00000024 Processor: 0x00010002 LDR Blocks: 0x0C00C8BC Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A HWV: Board Revision 0001 - 0x08 CPU Version 0002 - 0x90 SW Compatibility 0003 - 0x01 POP Revision 0004 - 0x01 Power Mgt Hardware 0007 - 0x30 POP Security 000B - 0x01 Mem Config Table (ver 1.19): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-1951 Modem EFS: blocks 1952-1983, total = 32 OS NV: blocks 1984-2000, total 17 CRC: 0x4129F6F0 Mem Config Table (ver 1.24) (actual): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Fixed: blocks 2-97 UMP Fixed: blocks 98-166, total = 69 FS Fixed: blocks 167-1951, total = 1785 Modem EFS: blocks 1952-1983, total = 32 OS NV: blocks 1984-2000, total 17 CRC: 0x6B3C549C Flash: Number of chips: 1 Flash ID: NAND blocks 0-2000 Device ID: 84 Vendor ID: 236 Version ID: 49 Total Size: 500.3 MB Memory Map: NAND Blocks: 2001 * 256 Kb RAM Base: 0x10000000 IRAM Base: 0x0C000000 OS Range: 2 - 97 File System: Memory Map: 167 - 1951 Sectors: 1785 Branding: VendorID: 105 OS * Not present * UMP: *empty* Done. Device Info: PIN: 324ce6eb Bootrom Version: 5.13.0.7 Hardware ID: 0x07001504 RIM BlackBerry Device HW ID Override: None Metrics Version: 6.15 Build Date: Feb 18 2010 Build Time: 08:43:25 Build User: ec_agent Security: Enabled Supported Options: 0x00000005 Drivers: 0x00000024 Processor: 0x00010002 LDR Blocks: 0x0C00C8BC Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A HWV: Board Revision 0001 - 0x08 CPU Version 0002 - 0x90 SW Compatibility 0003 - 0x01 POP Revision 0004 - 0x01 Power Mgt Hardware 0007 - 0x30 POP Security 000B - 0x01 Mem Config Table (ver 1.19): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-1951 Modem EFS: blocks 1952-1983, total = 32 OS NV: blocks 1984-2000, total 17 CRC: 0x4129F6F0 Mem Config Table (ver 1.24) (actual): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Fixed: blocks 2-97 UMP Fixed: blocks 98-166, total = 69 FS Fixed: blocks 167-1951, total = 1785 Modem EFS: blocks 1952-1983, total = 32 OS NV: blocks 1984-2000, total 17 CRC: 0x6B3C549C Flash: Number of chips: 1 Flash ID: NAND blocks 0-2000 Device ID: 84 Vendor ID: 236 Version ID: 49 Total Size: 500.3 MB Memory Map: NAND Blocks: 2001 * 256 Kb RAM Base: 0x10000000 IRAM Base: 0x0C000000 OS Range: 2 - 97 File System: Memory Map: 167 - 1951 Sectors: 1785 Branding: VendorID: 105 OS * Not present * UMP: *empty* Task Status: Completed i try to update or flashing with loader .... cut off in reconnecting JVM wish somebody here help me thanks in advance |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2009 Location: Shenzhen
Member: 1123681 Status: Offline Sonork: 100.1000 Thanks: 677
| Here is the link with details how to repair How To Work REDBLINK, NOT LOAD OS, JVM ERROR, ETC By Gsm Finder Dongle Regards Supporter |
| The Following User Says Thank You to DITS For This Useful Post: |
| | #5 (permalink) |
| do load MFI file after downloading Loading Files... Connecting to Bootrom: Connected Uploading RAM Image...OK Writing Images...OK Files Loaded. now BB9650 blinking whte screen .... i'm still trying USB Fix Done. Task Status: Completed |
| | #7 (permalink) | |
| Quote:
| | #8 (permalink) |
| here the log after read boot info : Connecting to Bootrom: Connected Uploading RAM Image...OK Bootrom Version: 5.13.0.7 Hardware ID: 0x07001504 RIM BlackBerry Device HW ID Override: None Metrics Version: 6.15 Build Date: Feb 18 2010 Build Time: 08:43:25 Build User: ec_agent Security: Enabled Supported Options: 0x00000005 Drivers: 0x00000024 Processor: 0x00010002 LDR Blocks: 0x0C00C8BC Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A HWV: Board Revision 0001 - 0x08 CPU Version 0002 - 0x90 SW Compatibility 0003 - 0x01 POP Revision 0004 - 0x01 Power Mgt Hardware 0007 - 0x30 POP Security 000B - 0x01 Mem Config Table (ver 1.19): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-1951 Modem EFS: blocks 1952-1983, total = 32 OS NV: blocks 1984-2000, total 17 CRC: 0x4129F6F0 Mem Config Table (ver 1.24) (actual): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-1951 Modem EFS: blocks 1952-1983, total = 32 OS NV: blocks 1984-2000, total 17 CRC: 0xF7A91E01 Flash: Number of chips: 1 Flash ID: NAND blocks 0-2000 Device ID: 84 Vendor ID: 236 Version ID: 49 Total Size: 500.3 MB Memory Map: NAND Blocks: 2001 * 256 Kb RAM Base: 0x10000000 IRAM Base: 0x0C000000 OS Range: 2 - 72 File System: Memory Map: 73 - 1951 Sectors: 1879 Branding: VendorID: 105 OS Version: 4.2.0.492 Hardware ID: 0x07001504 RIM BlackBerry Device Metrics Version: 3.17 FS Code Version: 10.0.0.0 FAT Code Version: 2.33 Package Version: "" Build Date: Jun 16 2011 Build Time: 16:09:51 Build User: absadmin SV Number: 1 OS Address: 0x10000000-0x111954A3 App Start: * No Application Linked * RAM usage: 0x136CFFFC-0x147FFFFF IRAM End: no IRAM! DSP ROM2 Address: *not present* OS Extended Addr: 0x00000000 LDR Blocks: 0x10004FB4 API Checksum: 0x00000000 JumpTable (<3): 0x00000000 JumpTable (>2): 0x00000000 Radio Code: Eltron5 radio code linked OS API Version: 130.3 STP Protocol Ver: 5.201.1 (factory OS) HWV: Board Revision 0001 - [0x04 - 0xFF], 0x01 POP Revision 0004 - [0x00 - 0xFF], 0x01 CPU Version 0002 - [0x00 - 0x8B], 0x01 CPU Version 0002 - [0x8D - 0xFF], 0x01 SW Compatibility 0003 - [0x00 - 0x01], 0x01 WTE supported 003C - [0x01 - 0xFF], 0x00 Power Mgt Hardware 0007 - [0x03 - 0xFF], 0x01 Version Table: OS API Version: 130.3 STP protocol version: 5.201.1 BlockFS API Version: 10.0.0.0 USB driver version: 01.07 Bugdisp RTAS key: 1.0 STP RTAS key: 1.0 NVSIG RTAS key: 1.0 Block map version: 2.16 WLAN radio version: 3.0.1.3800 Done. Device Info: PIN: Bootrom Version: 5.13.0.7 Hardware ID: 0x07001504 RIM BlackBerry Device HW ID Override: None Metrics Version: 6.15 Build Date: Feb 18 2010 Build Time: 08:43:25 Build User: ec_agent Security: Enabled Supported Options: 0x00000005 Drivers: 0x00000024 Processor: 0x00010002 LDR Blocks: 0x0C00C8BC Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A HWV: Board Revision 0001 - 0x08 CPU Version 0002 - 0x90 SW Compatibility 0003 - 0x01 POP Revision 0004 - 0x01 Power Mgt Hardware 0007 - 0x30 POP Security 000B - 0x01 Mem Config Table (ver 1.19): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-1951 Modem EFS: blocks 1952-1983, total = 32 OS NV: blocks 1984-2000, total 17 CRC: 0x4129F6F0 Mem Config Table (ver 1.24) (actual): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-1951 Modem EFS: blocks 1952-1983, total = 32 OS NV: blocks 1984-2000, total 17 CRC: 0xF7A91E01 Flash: Number of chips: 1 Flash ID: NAND blocks 0-2000 Device ID: 84 Vendor ID: 236 Version ID: 49 Total Size: 500.3 MB Memory Map: NAND Blocks: 2001 * 256 Kb RAM Base: 0x10000000 IRAM Base: 0x0C000000 OS Range: 2 - 72 File System: Memory Map: 73 - 1951 Sectors: 1879 Branding: VendorID: 105 OS Version: 4.2.0.492 Hardware ID: 0x07001504 RIM BlackBerry Device Metrics Version: 3.17 FS Code Version: 10.0.0.0 FAT Code Version: 2.33 Package Version: "" Build Date: Jun 16 2011 Build Time: 16:09:51 Build User: absadmin SV Number: 1 OS Address: 0x10000000-0x111954A3 App Start: * No Application Linked * RAM usage: 0x136CFFFC-0x147FFFFF IRAM End: no IRAM! DSP ROM2 Address: *not present* OS Extended Addr: 0x00000000 LDR Blocks: 0x10004FB4 API Checksum: 0x00000000 JumpTable (<3): 0x00000000 JumpTable (>2): 0x00000000 Radio Code: Eltron5 radio code linked OS API Version: 130.3 STP Protocol Ver: 5.201.1 (factory OS) HWV: Board Revision 0001 - [0x04 - 0xFF], 0x01 POP Revision 0004 - [0x00 - 0xFF], 0x01 CPU Version 0002 - [0x00 - 0x8B], 0x01 CPU Version 0002 - [0x8D - 0xFF], 0x01 SW Compatibility 0003 - [0x00 - 0x01], 0x01 WTE supported 003C - [0x01 - 0xFF], 0x00 Power Mgt Hardware 0007 - [0x03 - 0xFF], 0x01 Version Table: OS API Version: 130.3 STP protocol version: 5.201.1 BlockFS API Version: 10.0.0.0 USB driver version: 01.07 Bugdisp RTAS key: 1.0 STP RTAS key: 1.0 NVSIG RTAS key: 1.0 Block map version: 2.16 WLAN radio version: 3.0.1.3800 Task Status: Completed could you show me ..which part code that showing SFI and APP ??? |
| | #9 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2010 Location: India Age: 20
Member: 1713856 Status: Offline Sonork: 100.1592878 Thanks: 4
| bro please read my post carefully,i say to read info not readboot info. in blackberry tab come to service then read info |
| | #10 (permalink) | |
| Quote:
... sorry , i was wrong , not read carefully , read info : always showing Searching Phone... Phone Not Found! 1- turn off the phone. 2- turn on again. 3- Reconnect the cable. Task Status: Not Completed! | |
| | #11 (permalink) | |
| Quote:
you try flash with rapid,rapids available in download tool. | |
| The Following User Says Thank You to Rahul_Bhutani For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| HELP!!! BACKGROUND SCREEN LOGO | Michael Go | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-25-2011 23:56 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
| need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 1 | 06-02-1999 16:23 |
| need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 05-26-1999 11:35 |
