Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported WebShop Companies > "DITS" > Gsm Finder > Gsmfinder Dongle Version
Old 07-07-2012, 17:25   #1 (permalink)
m-soft's Avatar
Member: 1193296
Sonork: 100.1616292
plz add red light selution for bold 9000 [answered]
please add red light solution for bold 9000
i ve 4 pcs recognized by USB but restart after red light blink
regard
Old 07-07-2012, 18:32   #2 (permalink)
Member: 659181
Sonork: 100.1597028
regard
How To Work REDBLINK, NOT LOAD OS, JVM ERROR, ETC By Gsm Finder Dongle
Old 07-08-2012, 12:42   #3 (permalink)
m-soft's Avatar
Member: 1193296
Sonork: 100.1616292
thanks but i cant find app and sfi files for bold 9000
Old 07-08-2012, 13:03   #4 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: 100.1592878
Hello,
my i may i know your phone prd and which app and sfi not in download tool?
The Following User Says Thank You to Rahul_Bhutani For This Useful Post:
Old 07-08-2012, 15:32   #5 (permalink)
m-soft's Avatar
Member: 1193296
Sonork: 100.1616292
this is my phone bold 9000
pdr-277730-008
and
pdr-277730-009
I NEED MFI,APP,SFI,RAPID AND 9000_Load_OS_PDR
Old 07-10-2012, 06:49   #6 (permalink)
Member: 1713856
Sonork: 100.1592878
@M-soft
check your prd it's wrong.
Old 07-10-2012, 13:49   #7 (permalink)
m-soft's Avatar
Member: 1193296
Sonork: 100.1616292
Originally Posted by Rahul_Bhutani View Post
@M-soft
sorry this is my PDR
Old 07-10-2012, 13:56   #8 (permalink)
Member: 1713856
Sonork: 100.1592878
Hello,
first load mfi to phone,as phone come in factory os,readinfo in gsm-finder,you will see all sfi and app in info,download that from download tool and flash,redlight problem will solve.
MFI-17584-015,MFI-17584-038.
Download both and try one by one.
Old 07-10-2012, 14:53   #9 (permalink)
m-soft's Avatar
Member: 1193296
Sonork: 100.1616292
THIS MFI-17584-015
Loading Files...
Connecting to Bootrom: Connected
Uploading RAM Image...OK
Writing Images...Error during check of OS against bootrom.
This OS does not match this device!
Task Status: Not Completed!
AND
MFI-17584-038
IS OK GIVES ME WHITE SCREEN NOW
AND WHEN I TRY TO READ INFO
Searching Phone...
Phone Not Found!
1- turn off the phone.
2- turn on again.
3- Reconnect the cable.
Old 07-10-2012, 14:54   #10 (permalink)
Member: 1713856
Sonork: 100.1592878
THIS MFI-17584-015
Loading Files...
AND
MFI-17584-038
Searching Phone...
Phone Not Found!
2- turn on again.
try another mfi,and readinfo when,when phone come to factory os in white display.
Old 07-10-2012, 15:08   #11 (permalink)
m-soft's Avatar
Member: 1193296
Sonork: 100.1616292
Please i need to revive this phone so what can i do next
and this is the boot info
Bootrom Version:       5.4.0.23
    Hardware ID:       0x84000E07 RIM BlackBerry Device
    HW ID Override:    None
    Supported Bands:   0x000F
    Metrics Version:   6.1
    Build Date:        Mar  9 2009
    Build Time:        12:14:29
    Build User:        absadmin
    Security:          Enabled
    Drivers:           0x00000004
    LDR Blocks:        0x5C01E570
    Bootrom Size:      0x00020000
    External MCT/HWV:  Enabled
    Boot Mode:         N/A
    Boot OS Count:     N/A
    HWV:
        Board Revision       0001 - 0x10
        CPU Version          0002 - 0xE7
        SW Compatibility     0003 - 0x02
        POP Revision         0004 - 0x17
        Power Mgt Hardware   0007 - 0x25
    Mem Config Table (ver 1.16):
        Flash Chip:   blocks 0-996, Chip 0, Sub 0
        Bootrom:      blocks 0-0
        OS Dynamic:   blocks 2-????
        FS Dynamic:   blocks ????-979
        OS NV:        blocks 980-996, total 17
        CRC:          0x3BAE419A
Flash:
    Number of chips:       1
    Flash ID:              NAND blocks 0-996
    Device ID:             48
    Vendor ID:             236
    Version ID:            33
    Total Size:            124.6 MB
Memory Map:
    NAND Blocks:       997 * 128 Kb
    RAM Base:          0x80000000
    IRAM Base:         0x5C000000
    OS Range:          2 - 70
File System:
    Memory Map:
                       71 - 979
    Sectors:           909
Branding:
    VendorID:          100
OS Version:            4.0.0.50
    Supported Bands:   0x0000FFFF
    Metrics Version:   3.16
    FS Code Version:   10.0.0.0
    FAT Code Version:  2.14
    Package Version:   ""
    Build Date:        May  5 2008
    Build Time:        11:49:54
    OS Address:        0x80000000-0x80881FB3
    App Start:         * No Application Linked *
    Companion Binary:  0.0.0.0
    RAM usage:         0x8709FFFC-0x877FFFFC
    IRAM End:          0xD0F901F0
    DSP ROM2 Address:  *not present*
    OS Extended Addr:  0x80410DC8
    LDR Blocks:        0x804F8630
    API Checksum:      0x00000000
    JumpTable (<3):    0x800002F8
    JumpTable (>2):    0x80001AF4
    Radio Code:        Janus radio code linked
    OS API Version:    95.46
    STP Protocol Ver:  5.89.1 (factory OS)
    HWV:
        Board Revision       0001 - [0x0C - 0xFF], 0x01
        POP Revision         0004 - [0x00 - 0xFF], 0x01
        CPU Version          0002 - [0xE6 - 0xFF], 0x01
        SW Compatibility     0003 - [0x00 - 0x02], 0x01
        Power Mgt Hardware   0007 - [0x23 - 0xFF], 0x01
    Version Table:
        STP protocol version:    5.89.1
        BlockFS API Version:     10.0.0.0
        USB driver version:      02.01
        FAT FS Version:          2.14
        Block map version:       2.1
        WLAN radio version:      2.4.0.32
    Kernel Version:        1.10.0.69
        Metrics Version:   1.1
        Build Time:        10:49:59
        Build User:        SCM
Done.
Device Info:
    PIN:               212bff06
    Security:          Enabled
    Drivers:           0x00000004
    Boot Mode:         N/A
    Boot OS Count:     N/A
    HWV:
        Bootrom:      blocks 0-0
        CRC:          0x3BAE419A
Flash:
    Number of chips:       1
    Device ID:             48
    Vendor ID:             236
    Version ID:            33
Memory Map:
    OS Range:          2 - 70
File System:
    Memory Map:
                       71 - 979
    Sectors:           909
Branding:
    VendorID:          100
    Package Version:   ""
    HWV:
    Version Table:
        Build User:        SCM
Task Status: Completed
and i flash it with 9000_Load_OS_PRD-12528-098.exe
still the same
Old 07-10-2012, 16:15   #12 (permalink)
m-soft's Avatar
Member: 1193296
Sonork: 100.1616292
i tried 4 mfis same thing
Old 07-11-2012, 07:03   #13 (permalink)
Member: 1713856
Sonork: 100.1592878
contact me online....
Old 07-14-2012, 18:13   #14 (permalink)
m-soft's Avatar
Member: 1193296
Sonork: 100.1616292
I am trying to contact you 4 3 days now you are always offline
Old 07-15-2012, 04:29   #15 (permalink)
Member: 1713856
Sonork: 100.1592878
what is your gmt,my gmt 5:30+ and i m online 12:00pm to 7:00pm,and monday holliday
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 Yesterday 19:20
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
Page generated in 0.53973 seconds with 11 queries
