08-10-2014, 02:26 | #115 (permalink) |
No Life Poster Join Date: May 2003 Location: Romania Age: 48
Member: 29006 Status: Offline Thanks Meter: 31 | SM-G3815 Dead boot by other unlock tool Full log Code: Initialising: SAMSUNG SGH-I527 Config ver.:1.00 I/O Level set to : 2200 mV Box S/N: XXXX ,FW Ver.: 01.50 Connecting to Target... Warn: JTAG device: MSM8230AB. CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4Warn: CPU Manufacturer: Samsung , CPU Name: ARM7GENWarn: JTAG device: MSM8230AB. CPU IDCODE : 0x308930E1 Mfg.: 0x070, Part: 0x0893, Ver.: 0x3Warn: CPU Manufacturer: QUALCOMM , CPU Name: Unknown Halting CPU... Initialize hardware... Starting target communication... Warn: Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00000045 Name : SEM08G Size : 7.3 G , (15269888) Blocks EMMC #1 : ID : 0x00000045 Name : SEM08G Size : 2.0 M , (4096) Blocks Error: eMMC flash device(s) found, Device ID : 0x00450000Reading... Warn: Searching for partition tables... Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20 MMCBLK0P0 (MODEM) Range: [0X400000,0X3FFFE00] ,Len: 3C00000 MMCBLK0P1 (SBL1) Range: [0X4000000,0X401FE00] ,Len: 20000 MMCBLK0P2 (SBL2) Range: [0X4020000,0X405FE00] ,Len: 40000 MMCBLK0P3 (SBL3) Range: [0X4060000,0X40DFE00] ,Len: 80000 MMCBLK0P4 (ABOOT) Range: [0X40E0000,0X42DFE00] ,Len: 200000 MMCBLK0P5 (RPM) Range: [0X42E0000,0X435FE00] ,Len: 80000 MMCBLK0P6 (TZ) Range: [0X4360000,0X43DFE00] ,Len: 80000 MMCBLK0P7 (PAD) Range: [0X43E0000,0X505FE00] ,Len: C80000 MMCBLK0P8 (PARAM) Range: [0X5060000,0X585FE00] ,Len: 800000 MMCBLK0P9 (EFS) Range: [0X5860000,0X65FFE00] ,Len: DA0000 MMCBLK0P10 (MODEMST1) Range: [0X6600000,0X68FFE00] ,Len: 300000 MMCBLK0P11 (MODEMST2) Range: [0X6900000,0X6BFFE00] ,Len: 300000 MMCBLK0P12 (BOOT) Range: [0X6C00000,0X75FFE00] ,Len: A00000 MMCBLK0P13 (RECOVERY) Range: [0X7600000,0X7FFFE00] ,Len: A00000 MMCBLK0P14 (FOTA) Range: [0X8000000,0X89FFE00] ,Len: A00000 MMCBLK0P15 (BACKUP) Range: [0X8A00000,0X90FDE00] ,Len: 6FE000 MMCBLK0P16 (FSG) Range: [0X90FE000,0X93FDE00] ,Len: 300000 MMCBLK0P17 (SSD) Range: [0X93FE000,0X93FFE00] ,Len: 2000 MMCBLK0P18 (PERSIST) Range: [0X9400000,0X9BFFE00] ,Len: 800000 MMCBLK0P19 (PERSDATA) Range: [0X9C00000,0XA7FFE00] ,Len: C00000 MMCBLK0P20 (SYSTEM) Range: [0XA800000,0X813FFE00] ,Len: 76C00000 MMCBLK0P21 (CACHE) Range: [0X81400000,0XACFFFE00] ,Len: 2BC00000 MMCBLK0P22 (HIDDEN) Range: [0XAD000000,0XADFFFE00] ,Len: 1000000 MMCBLK0P23 (USERDATA) Range: [0XAE000000,0X3AB3FBC00] ,Len: 2FD3FBE00 Created helper script 'dump_gpt_partitions.txt' for dumping all regions in deviceCreated helper script 'write_gpt_partitions.txt' for writing all regions in device<b>Presets list on main window has been updated!</b>Done |
