07-19-2014, 07:24 | #92 (permalink) |
No Life Poster Join Date: May 2013 Location: In Core Of eMMC
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | need support for unsupported model..micromax A111!!!! Sir i have one Micromax A111 For dead boot repair it has Quallcomm cpu inside here is clean photos of pcb Waiting for your reply!!! |
07-26-2014, 09:26 | #101 (permalink) |
Freak Poster Join Date: May 2005 Location: hanoi.vietnam
Member: 142949 Status: Offline Thanks Meter: 71 | lg lu6200 and lgf160 emmc not samsung lg f160 connect ,read write ok,but not format...,config,emmc toshiba connect lu 6200 ok but not format,not read write Z3X EasyJtag Software ver. 1.5.6.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 0D00401A13836xxx, ,FW Ver.: 01.50 CMD Pullup Level:1680 mV CMD Active Level:1629 mV eMMC Device Information EMMC CID : 90014A48594E49582056001DA162BE7A EMMC CSD : D04F01320F5903FFFFFFFFEF8A400060 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 11/2011 Rev.0x56 EMMC NAME: HYNIX , S/N: 1941858 EMMC ROM1 (Main User Data) Capacity: 3448 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: HYNIX _ 1941858_20140606_1506.extcsd Done. Z3X EasyJtag Software ver. 1.5.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1680 mV CMD Active Level:1639 mV Reading 0x000000200000 bytes from 0x000000000000 ...ROM2 ( BOOT1 ROM) Read Check Failed, Reason: CARD Data FIFO Timeout Error Firmware file...F:\LG\eMMC_Firmware.bin Running:SAMSUNG: MoviNAND Firmware extraction... Z3X EasyJtag Software ver. 1.5.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1680 mV CMD Active Level:1639 mV ERROR: This eMMC are not Samsung! Done! |
