Old 01-08-2014, 18:30   #1 (permalink)
Maroon-WSU's Avatar
Member: 485048
Sonork: 100.1619794
Thanks Meter: 109
7 pcs N7100 Dead Repaired And EMMC programmed
7 pieces N7100 Done same day 100% with easy JTAG
i succesfully programmed 7 n7100 (note 2) phones in past 24 hours
Tools needed:
1.Easy Jtag Box (Original from Z3x Official Reseller)
2.Working EMMC
3.cup of coffee
4.good soldering skills and IC replacement skills
Steps:
1.remove old damaged emmc from phone (remove carefully try not to damage any other ic or resistor or any pin) (for me i use irda infrared workstation)
2.replace new emmc we did this with empty emmc (just turning on ur phone doesn't mean emmc is placed 100%)
3.connect to eay jtag (u can use both direct wiring with 2 power supplies or buy moorc connectors or gpg connector) write dumps rom1 rom2 from support and flash phone phone is on 100% working
Special Thanks to The Master "Blang" N1 solutions worldwide
and all Z3x Team
Succesfully DONE
L0RD Cell - Lebanon
General Info: BE CAREFUL OF CHEESY LINES SOME BOX OWNERS AND RESELLERS CLAIM
The Following 5 Users Say Thank You to Maroon-WSU For This Useful Post:
Old 01-09-2014, 10:51   #2 (permalink)
Member: 1743727
Thanks Meter: 76
u use gpg emmc adopter or self maid
Old 01-20-2014, 11:04   #3 (permalink)
Maroon-WSU's Avatar
Member: 485048
Sonork: 100.1619794
Thanks Meter: 109
i use gpg adapter also have moorc adapter also have safe made and can do manual
u can use any doesn't matter
The Following User Says Thank You to Maroon-WSU For This Useful Post:
Old 01-25-2014, 17:59   #4 (permalink)
kasim's Avatar
Member: 107448
Thanks Meter: 29
can i ready this n7100
can i ready this n7100 with easy jtag
Old 02-04-2014, 17:36   #5 (permalink)
kasim's Avatar
Member: 107448
Thanks Meter: 29
Can i ready this n7100 i am new to easy jtag
can i ready this n7100 i am new to easy jtag and also their is no n7100 dump file in z3x shell and also need step by step procedure
thanks in advance
Old 12-07-2016, 20:47   #6 (permalink)
Member: 2658193
I am confused now, I have seen many folks around who just reprogram the phone without replacing the EMMC chip, and they got it working.
And now you are replacing the EMMC chip, what is the purpose of this easy Jtag then? If I have to replace the EMMC!!!!!
Old 12-08-2016, 08:18   #7 (permalink)
Member: 1675290
Thanks Meter: 177
reprogram emmc just 50 %.. the rest 50 % need to be replaced...
to replacing samsung emmc u need enough skill or you will kill the board ... the most save use drill
The Following User Says Thank You to bagus.dps For This Useful Post:
Old 08-15-2019, 18:33   #8 (permalink)
Member: 900168
Thanks Meter: 2
after writing dump files , how do we get imei back ?
Page generated in 0.16687 seconds with 9 queries
