11-28-2018, 15:11 | #1 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | a106 please suggest how to rectify this error Looking for EasyJTAG box... 11/28/2018 7:30:56 PM> EasyJTAG API ver. 2100 11/28/2018 7:30:56 PM> Setting IO Levels to 2.8V 11/28/2018 7:30:56 PM> Setting frequence to 42 Mhz 11/28/2018 7:30:56 PM> EasyJTAG Box Serial = 026862FABF5A25EA 11/28/2018 7:30:56 PM> EasyJTAG Box Firmware = 2.30 11/28/2018 7:30:57 PM> Setting interface to EasyJtag2/E-Socket 11/28/2018 7:30:57 PM> Setting bus width to 8 Bit 11/28/2018 7:30:57 PM> Setting frequence to 42 Mhz 11/28/2018 7:30:57 PM> eMMC Init returned = 0 11/28/2018 7:30:57 PM> EMMC Device Information : 11/28/2018 7:30:57 PM> EMMC CID: 90014A4838473264040503A2F2B69131 11/28/2018 7:30:57 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 11/28/2018 7:30:57 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G2d , HEX: 483847326400 , S/N: 03A2F2B6 , rev. 0x05 11/28/2018 7:30:57 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2014 11/28/2018 7:30:57 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 11/28/2018 7:30:57 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/28/2018 7:30:57 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 11/28/2018 7:30:57 PM> EMMC Permanent Write Protection: No 11/28/2018 7:30:57 PM> EMMC Temporary Write Protection: No 11/28/2018 7:30:57 PM> Extended CSD Information : 11/28/2018 7:30:57 PM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 11/28/2018 7:30:57 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 11/28/2018 7:30:57 PM> Boot Bus Config: 0x00 , width 1bit 11/28/2018 7:30:57 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 11/28/2018 7:30:57 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/28/2018 7:30:57 PM> Device supports partitioning features 11/28/2018 7:30:57 PM> Device can have enhanced technological features in partitions and user data area 11/28/2018 7:30:57 PM> Device can have extended partitions attribute 11/28/2018 7:30:57 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 11/28/2018 7:30:57 PM> Backup saved: H8G2d_03A2F2B6_20181128_193057.extcsd 11/28/2018 7:30:57 PM> EMMC Init completed. 11/28/2018 7:30:57 PM> 11/28/2018 7:30:57 PM> Opening file: I:\MICROMAX\A 106\Micromax_A106_V1_14.05.14_S4700BP_MP_MMX_IN_10 _(by_xdafirmware.com)\Micromax_A106_V1_14.05.14_S4 700BP_MP_MMX_IN_10\Firmware\MT6582_Android_scatter .txt 11/28/2018 7:30:57 PM> 11/28/2018 7:30:57 PM> The new format of scatter 11/28/2018 7:30:57 PM> config_version: V1.1.1 11/28/2018 7:30:57 PM> platform: MT6582 11/28/2018 7:30:57 PM> preloader_s4700.bin 11/28/2018 7:30:57 PM> Found 2 supported eMMC CID: 11/28/2018 7:30:57 PM> name = 'H4G1d' hex = 0x483447316404 [SKHYNIX] 11/28/2018 7:30:57 PM> eNAND_H26M31002GPR/4GB @FBGA153 11/28/2018 7:30:57 PM> eNAND_H9DP32A4JJBCGR-KEM/4GB @FBGA153 11/28/2018 7:30:57 PM> eNAND_H9TP32A4GDBCPR-KGM/4GB @FBGA162 11/28/2018 7:30:57 PM> eNAND_H9TP32A8JDACPR-KGM/4GB @FBGA162 11/28/2018 7:30:57 PM> name = '004G90' hex = 0x303034473930 [TOSHIBA] 11/28/2018 7:30:57 PM> eSD_THGBM5G5A1JBAIR/4GB @FBGA153 11/28/2018 7:30:57 PM> eSD_THGBMAG5A1JBAIR/4GB @FBGA153 11/28/2018 7:30:57 PM> TYC0FH121597RA/4GB @FBGA153 11/28/2018 7:30:57 PM> TYD0FH221618RA/4GB @FBGA162 11/28/2018 7:30:57 PM> TYD0FH221618RA-4G @BGA162 11/28/2018 7:30:57 PM> 11/28/2018 7:30:57 PM> The size of the last section has been updated 11/28/2018 7:30:57 PM> 11/28/2018 7:30:57 PM> Warning: Preloader does not contain your EMMC CID. Make sure that your emmc matches the parameters |
11-28-2018, 18:21 | #3 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: Vice City
Member: 1436243 Status: Offline Thanks Meter: 99 | Quote:
try another version of firmware until preloader have your emmc cid, or replace with samsung emmc same capacity and same lpddr, and patch that emmc to , one of the supported type. ps. you can use preloader parser to get info emmc supported in this case your emmc is skyhynix not support for patch CID. two option: replaces same type, or replace with samsung emmc and do patch CiD | |
11-29-2018, 10:48 | #4 (permalink) | |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Quote:
eMMC_tool Suite ver. 1.5.2.0 (release date: 06.08.2018) 11/29/2018 1:58:15 PM> Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.17932) 11/29/2018 1:58:15 PM> 11/29/2018 1:58:15 PM> Looking for EasyJTAG box... 11/29/2018 1:58:15 PM> EasyJTAG API ver. 2100 11/29/2018 1:58:16 PM> OpenUSB returned = 0 11/29/2018 1:58:17 PM> EasyJTAG Box Serial = 026862FABF5A25EA 11/29/2018 1:58:18 PM> Card Serial = AA0BB341 11/29/2018 1:58:18 PM> EasyJTAG Box Firmware = 2.30 11/29/2018 1:58:18 PM> 11/29/2018 1:58:28 PM> Looking for EasyJTAG box... 11/29/2018 1:58:28 PM> EasyJTAG API ver. 2100 11/29/2018 1:58:28 PM> Setting IO Levels to 2.8V 11/29/2018 1:58:28 PM> Setting frequence to 42 Mhz 11/29/2018 1:58:28 PM> EasyJTAG Box Serial = 026862FABF5A25EA 11/29/2018 1:58:28 PM> EasyJTAG Box Firmware = 2.30 11/29/2018 1:58:29 PM> Setting interface to EasyJtag2/E-Socket 11/29/2018 1:58:29 PM> Setting bus width to 8 Bit 11/29/2018 1:58:29 PM> Setting frequence to 42 Mhz 11/29/2018 1:58:29 PM> eMMC Init returned = 0 11/29/2018 1:58:29 PM> EMMC Device Information : 11/29/2018 1:58:29 PM> EMMC CID: 90014A4838473264040503A2F2B69131 11/29/2018 1:58:29 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 11/29/2018 1:58:29 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G2d , HEX: 483847326400 , S/N: 03A2F2B6 , rev. 0x05 11/29/2018 1:58:29 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2014 11/29/2018 1:58:29 PM> EMMC ROM 1 (Main User Data) Capacity: 7424 MB (0001D0000000) 11/29/2018 1:58:29 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/29/2018 1:58:29 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 11/29/2018 1:58:29 PM> EMMC GP1 (GP Partition 1) Capacity: 8 MB (000000800000) 11/29/2018 1:58:29 PM> EMMC GP2 (GP Partition 2) Capacity: 8 MB (000000800000) 11/29/2018 1:58:29 PM> EMMC GP3 (GP Partition 3) Capacity: 8 MB (000000800000) 11/29/2018 1:58:29 PM> EMMC GP4 (GP Partition 4) Capacity: 8 MB (000000800000) 11/29/2018 1:58:29 PM> EMMC Permanent Write Protection: No 11/29/2018 1:58:29 PM> EMMC Temporary Write Protection: No 11/29/2018 1:58:29 PM> Extended CSD Information : 11/29/2018 1:58:29 PM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 11/29/2018 1:58:29 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 11/29/2018 1:58:30 PM> Boot Bus Config: 0x00 , width 1bit 11/29/2018 1:58:30 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 11/29/2018 1:58:30 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/29/2018 1:58:30 PM> Device supports partitioning features 11/29/2018 1:58:30 PM> Device can have enhanced technological features in partitions and user data area 11/29/2018 1:58:30 PM> Device can have extended partitions attribute 11/29/2018 1:58:30 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 11/29/2018 1:58:30 PM> Backup saved: H8G2d_03A2F2B6_20181129_135830.extcsd 11/29/2018 1:58:30 PM> EMMC Init completed. 11/29/2018 1:58:30 PM> 11/29/2018 1:58:30 PM> Scanning soft partitions 11/29/2018 1:58:32 PM> Partition table not found 11/29/2018 1:58:32 PM> 11/29/2018 1:58:32 PM> Get firmware version 11/29/2018 1:58:37 PM> Firmware info not found 11/29/2018 1:59:02 PM> Looking for EasyJTAG box... 11/29/2018 1:59:02 PM> EasyJTAG API ver. 2100 11/29/2018 1:59:02 PM> Setting IO Levels to 2.8V 11/29/2018 1:59:02 PM> Setting frequence to 42 Mhz 11/29/2018 1:59:02 PM> EasyJTAG Box Serial = 026862FABF5A25EA 11/29/2018 1:59:02 PM> EasyJTAG Box Firmware = 2.30 11/29/2018 1:59:03 PM> Setting interface to EasyJtag2/E-Socket 11/29/2018 1:59:03 PM> Setting bus width to 8 Bit 11/29/2018 1:59:03 PM> Setting frequence to 42 Mhz 11/29/2018 1:59:03 PM> eMMC Init returned = 0 11/29/2018 1:59:03 PM> EMMC Device Information : 11/29/2018 1:59:03 PM> EMMC CID: 90014A4838473264040503A2F2B69131 11/29/2018 1:59:03 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 11/29/2018 1:59:03 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G2d , HEX: 483847326400 , S/N: 03A2F2B6 , rev. 0x05 11/29/2018 1:59:03 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2014 11/29/2018 1:59:03 PM> EMMC ROM 1 (Main User Data) Capacity: 7424 MB (0001D0000000) 11/29/2018 1:59:03 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/29/2018 1:59:03 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 11/29/2018 1:59:03 PM> EMMC GP1 (GP Partition 1) Capacity: 8 MB (000000800000) 11/29/2018 1:59:03 PM> EMMC GP2 (GP Partition 2) Capacity: 8 MB (000000800000) 11/29/2018 1:59:03 PM> EMMC GP3 (GP Partition 3) Capacity: 8 MB (000000800000) 11/29/2018 1:59:03 PM> EMMC GP4 (GP Partition 4) Capacity: 8 MB (000000800000) 11/29/2018 1:59:03 PM> EMMC Permanent Write Protection: No 11/29/2018 1:59:03 PM> EMMC Temporary Write Protection: No 11/29/2018 1:59:03 PM> Extended CSD Information : 11/29/2018 1:59:03 PM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 11/29/2018 1:59:03 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 11/29/2018 1:59:03 PM> Boot Bus Config: 0x00 , width 1bit 11/29/2018 1:59:03 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 11/29/2018 1:59:03 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/29/2018 1:59:03 PM> Device supports partitioning features 11/29/2018 1:59:03 PM> Device can have enhanced technological features in partitions and user data area 11/29/2018 1:59:03 PM> Device can have extended partitions attribute 11/29/2018 1:59:03 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 11/29/2018 1:59:03 PM> Backup saved: H8G2d_03A2F2B6_20181129_135903.extcsd 11/29/2018 1:59:03 PM> EMMC Init completed. 11/29/2018 1:59:03 PM> 11/29/2018 1:59:03 PM> Operation: Write by vendor (MediaTek) 11/29/2018 1:59:03 PM> 11/29/2018 1:59:03 PM> Partition name: PRELOADER 11/29/2018 1:59:03 PM> Filename: preloader_s4700.bin , Offset: 000000000000 , filesize: 117472 bytes 11/29/2018 1:59:03 PM> eMMC switching to ROM2 11/29/2018 1:59:03 PM> Erasing partition... 11/29/2018 1:59:05 PM> Writing partition... 11/29/2018 1:59:05 PM> Done writing partition. Write speed: 2399.98 KB/s 11/29/2018 1:59:05 PM> Partition name: MBR 11/29/2018 1:59:05 PM> Filename: MBR , Offset: 000000C00000 , filesize: 512 bytes 11/29/2018 1:59:05 PM> eMMC switching to ROM1 11/29/2018 1:59:06 PM> Erasing partition... 11/29/2018 1:59:06 PM> Writing partition... 11/29/2018 1:59:06 PM> Done writing partition. Write speed: 88.52 KB/s 11/29/2018 1:59:06 PM> Partition name: EBR1 11/29/2018 1:59:06 PM> Filename: EBR1 , Offset: 000000C80000 , filesize: 512 bytes 11/29/2018 1:59:06 PM> eMMC switching to ROM1 11/29/2018 1:59:06 PM> Erasing partition... 11/29/2018 1:59:07 PM> Writing partition... 11/29/2018 1:59:07 PM> Done writing partition. Write speed: 87.00 KB/s 11/29/2018 1:59:07 PM> Partition name: UBOOT 11/29/2018 1:59:07 PM> Filename: lk.bin , Offset: 000002920000 , filesize: 245288 bytes 11/29/2018 1:59:07 PM> eMMC switching to ROM1 11/29/2018 1:59:07 PM> Erasing partition... 11/29/2018 1:59:08 PM> Writing partition... 11/29/2018 1:59:08 PM> Done writing partition. Write speed: 7076.34 KB/s 11/29/2018 1:59:08 PM> Partition name: BOOTIMG 11/29/2018 1:59:08 PM> Filename: boot.img , Offset: 000002980000 , filesize: 5896192 bytes 11/29/2018 1:59:08 PM> eMMC switching to ROM1 11/29/2018 1:59:08 PM> Erasing partition... 11/29/2018 1:59:09 PM> Writing partition... 11/29/2018 1:59:10 PM> Done writing partition. Write speed: 9079.70 KB/s 11/29/2018 1:59:10 PM> Partition name: RECOVERY 11/29/2018 1:59:10 PM> Filename: recovery.img , Offset: 000003980000 , filesize: 6275072 bytes 11/29/2018 1:59:10 PM> eMMC switching to ROM1 11/29/2018 1:59:10 PM> Erasing partition... 11/29/2018 1:59:11 PM> Writing partition... 11/29/2018 1:59:11 PM> Done writing partition. Write speed: 14413.11 KB/s 11/29/2018 1:59:11 PM> Partition name: SEC_RO 11/29/2018 1:59:11 PM> Filename: secro.img , Offset: 000004980000 , filesize: 135168 bytes 11/29/2018 1:59:11 PM> eMMC switching to ROM1 11/29/2018 1:59:11 PM> Erasing partition... 11/29/2018 1:59:12 PM> Writing partition... 11/29/2018 1:59:12 PM> Done writing partition. Write speed: 12399.23 KB/s 11/29/2018 1:59:12 PM> Partition name: LOGO 11/29/2018 1:59:12 PM> Filename: logo.bin , Offset: 000005000000 , filesize: 244996 bytes 11/29/2018 1:59:12 PM> eMMC switching to ROM1 11/29/2018 1:59:12 PM> Erasing partition... 11/29/2018 1:59:12 PM> Writing partition... 11/29/2018 1:59:13 PM> Done writing partition. Write speed: 12502.56 KB/s 11/29/2018 1:59:13 PM> Partition name: EBR2 11/29/2018 1:59:13 PM> Filename: EBR2 , Offset: 000005300000 , filesize: 512 bytes 11/29/2018 1:59:13 PM> eMMC switching to ROM1 11/29/2018 1:59:13 PM> Erasing partition... 11/29/2018 1:59:13 PM> Writing partition... 11/29/2018 1:59:13 PM> Done writing partition. Write speed: 115.17 KB/s 11/29/2018 1:59:13 PM> Partition name: ANDROID 11/29/2018 1:59:13 PM> Filename: system.img , Offset: 000005D80000 , filesize: 843336440 bytes 11/29/2018 1:59:13 PM> eMMC switching to ROM1 11/29/2018 1:59:13 PM> Erasing partition... 11/29/2018 1:59:15 PM> Writing partition... 11/29/2018 1:59:15 PM> Sparse image found v.1.0 Total chunks: 1597 11/29/2018 2:00:08 PM> Done writing partition. Write speed: 15499.21 KB/s 11/29/2018 2:00:08 PM> Partition name: CACHE 11/29/2018 2:00:08 PM> Filename: cache.img , Offset: 00003E180000 , filesize: 6316180 bytes 11/29/2018 2:00:08 PM> eMMC switching to ROM1 11/29/2018 2:00:08 PM> Erasing partition... 11/29/2018 2:00:09 PM> Writing partition... 11/29/2018 2:00:09 PM> Sparse image found v.1.0 Total chunks: 10 11/29/2018 2:00:09 PM> Done writing partition. Write speed: 15913.99 KB/s 11/29/2018 2:00:09 PM> Partition name: USRDATA 11/29/2018 2:00:09 PM> Filename: userdata.img , Offset: 000045F80000 , filesize: 67962072 bytes 11/29/2018 2:00:09 PM> eMMC switching to ROM1 11/29/2018 2:00:10 PM> Erasing partition... 11/29/2018 2:00:11 PM> Writing partition... 11/29/2018 2:00:11 PM> Sparse image found v.1.0 Total chunks: 101 11/29/2018 2:00:15 PM> Done writing partition. Write speed: 15862.91 KB/s 11/29/2018 2:00:15 PM> 11/29/2018 2:00:15 PM> Writing DL_Info... 11/29/2018 2:00:15 PM> Writing DL_Info done 11/29/2018 2:00:15 PM> 11/29/2018 2:00:16 PM> Partition PROTECT_F : formatting as EXT4. Please wait ... 11/29/2018 2:00:16 PM> Formatting completed 11/29/2018 2:00:16 PM> Partition PROTECT_S : formatting as EXT4. Please wait ... 11/29/2018 2:00:16 PM> Formatting completed 11/29/2018 2:00:16 PM> 11/29/2018 2:00:16 PM> Writing eMMC Register ... 11/29/2018 2:00:16 PM> Reg: 179 Value: 0x48 11/29/2018 2:00:17 PM> Reg: 177 Value: 0x00 11/29/2018 2:00:17 PM> Reg: 162 Value: 0x01 11/29/2018 2:00:17 PM> 11/29/2018 2:00:18 PM> All done time: [00:01:14:341] 11/29/2018 2:00:18 PM> 11/29/2018 2:00:24 PM> Looking for EasyJTAG box... 11/29/2018 2:00:24 PM> EasyJTAG API ver. 2100 11/29/2018 2:00:24 PM> Setting IO Levels to 2.8V 11/29/2018 2:00:24 PM> Setting frequence to 42 Mhz 11/29/2018 2:00:24 PM> EasyJTAG Box Serial = 026862FABF5A25EA 11/29/2018 2:00:24 PM> EasyJTAG Box Firmware = 2.30 11/29/2018 2:00:24 PM> Setting interface to EasyJtag2/E-Socket 11/29/2018 2:00:24 PM> Setting bus width to 8 Bit 11/29/2018 2:00:24 PM> Setting frequence to 42 Mhz 11/29/2018 2:00:25 PM> eMMC Init returned = 0 11/29/2018 2:00:25 PM> EMMC Device Information : 11/29/2018 2:00:25 PM> EMMC CID: 90014A4838473264040503A2F2B69131 11/29/2018 2:00:25 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 11/29/2018 2:00:25 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G2d , HEX: 483847326400 , S/N: 03A2F2B6 , rev. 0x05 11/29/2018 2:00:25 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2014 11/29/2018 2:00:25 PM> EMMC ROM 1 (Main User Data) Capacity: 7424 MB (0001D0000000) 11/29/2018 2:00:25 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/29/2018 2:00:25 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 11/29/2018 2:00:25 PM> EMMC GP1 (GP Partition 1) Capacity: 8 MB (000000800000) 11/29/2018 2:00:25 PM> EMMC GP2 (GP Partition 2) Capacity: 8 MB (000000800000) 11/29/2018 2:00:25 PM> EMMC GP3 (GP Partition 3) Capacity: 8 MB (000000800000) 11/29/2018 2:00:25 PM> EMMC GP4 (GP Partition 4) Capacity: 8 MB (000000800000) 11/29/2018 2:00:25 PM> EMMC Permanent Write Protection: No 11/29/2018 2:00:25 PM> EMMC Temporary Write Protection: No 11/29/2018 2:00:25 PM> Extended CSD Information : 11/29/2018 2:00:25 PM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 11/29/2018 2:00:25 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 11/29/2018 2:00:25 PM> Boot Bus Config: 0x00 , width 1bit 11/29/2018 2:00:25 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 11/29/2018 2:00:25 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/29/2018 2:00:25 PM> Device supports partitioning features 11/29/2018 2:00:25 PM> Device can have enhanced technological features in partitions and user data area 11/29/2018 2:00:25 PM> Device can have extended partitions attribute 11/29/2018 2:00:25 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 11/29/2018 2:00:25 PM> Backup saved: H8G2d_03A2F2B6_20181129_140025.extcsd 11/29/2018 2:00:25 PM> EMMC Init completed. 11/29/2018 2:00:25 PM> 11/29/2018 2:00:25 PM> Scanning soft partitions 11/29/2018 2:00:25 PM> GPT header is not found 11/29/2018 2:00:25 PM> MBR header is found. Analyzing data ... 11/29/2018 2:00:25 PM> EBR detected at address: 000000080000 11/29/2018 2:00:25 PM> Partition: mmcblk0p0 [000000900000 - 000001300000], size: 000000A00000 (10.0 MB) 11/29/2018 2:00:25 PM> Partition: mmcblk0p1 [000001300000 - 000001D00000], size: 000000A00000 (10.0 MB) 11/29/2018 2:00:25 PM> Partition: mmcblk0p2 [000003D80000 - 000004380000], size: 000000600000 (6.00 MB) 11/29/2018 2:00:25 PM> Partition: mmcblk0p3 [000005180000 - 00003D580000], size: 000038400000 11/29/2018 2:00:25 PM> Partition: mmcblk0p4 [00003D580000 - 000045380000], size: 000007E00000 11/29/2018 2:00:25 PM> Partition: mmcblk0p5 [000045380000 - 00007EF80000], size: 000039C00000 11/29/2018 2:00:25 PM> Partition: mmcblk0p6 [00007EF80000 - 02000007FE00], size: 01FF810FFE00 11/29/2018 2:00:25 PM> MBR header successfully parsed 11/29/2018 2:00:25 PM> 11/29/2018 2:00:25 PM> Get firmware version 11/29/2018 2:00:25 PM> GPT header is not found 11/29/2018 2:00:25 PM> 11/29/2018 2:00:25 PM> Brand = Micromax 11/29/2018 2:00:25 PM> Manufacturer = Micromax 11/29/2018 2:00:25 PM> Model = Micromax A106 11/29/2018 2:00:25 PM> CPU Abi = armeabi-v7a 11/29/2018 2:00:25 PM> Mediatek platform = MT6582 11/29/2018 2:00:25 PM> Android release = 4.4.2 11/29/2018 2:00:25 PM> Firmware version = ALPS.KK1.MP1.V2.10 11/29/2018 2:00:25 PM> Firmware date = 2014? 06? 03? ??? 16:48:59 CST Last edited by Bhagat20; 11-29-2018 at 10:58. | |
11-29-2018, 14:41 | #6 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
old MTK (up to 6592) with MBR table may be not start without PMT PMT is created by flashtool, when flashing MT6589 phones can backup PMT partition and may restore it via EasyJTAG New MTK (67xx) may be flashed by EasyJTAG (GPT table) Some MTK phones (Huawei and other) have Sec-ro configered firmware. Sec-ro partition created by flashtool with sec-ro function. Flashtool binds Sec-ro partition to phone CPU and phone can not strart with bad (or foreign) sec-ro partition Last edited by layder; 11-29-2018 at 14:46. | |
The Following 2 Users Say Thank You to layder For This Useful Post: |
11-29-2018, 15:35 | #7 (permalink) | |
Btw i will make everything EASY. Just use easy jtag to write PRELOADER ONLY, remove isp /apply emmc if you use socket, assemble the phone, make sure battery have 50% capacity, and flash with any flash tool you have exam: spflashtool,cm2,ufi... etc I think its time to easyjtag PLUS , add own USB/tools flasher for multi platform. Regards | |
The Following User Says Thank You to mifluvcute For This Useful Post: |
