02-20-2017, 13:27 | #1 (permalink) |
Insane Poster Join Date: Jul 2016
Member: 2599387 Status: Offline Thanks Meter: 5 | a300fu dead boot repair.. --------- eMMC Device Information ---------- EMMC CID : 150100513331364D4200FF57EC7C3206 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 03/2015 Rev.0x0 EMMC NAME: Q316MB , S/N: 4283952252 EMMC NAME (HEX): 513331364D4200 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: Q316MB_4283952252_20170220_1715.extcsd Searching for partition tables... Detected GPT over MBR... Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Warning: Entries Count = 128 MMCBLK0P0 (APNHLOS) Range: [0X400000,0X12FFE00] ,Len: F00000 MMCBLK0P1 (MODEM) Range: [0X1300000,0X4C6FE00] ,Len: 3970000 MMCBLK0P2 (SBL1) Range: [0X4C70000,0X4CEFE00] ,Len: 80000 MMCBLK0P3 (DDR) Range: [0X4CF0000,0X4CF7E00] ,Len: 8000 MMCBLK0P4 (ABOOT) Range: [0X4CF8000,0X4EF7E00] ,Len: 200000 MMCBLK0P5 (RPM) Range: [0X4EF8000,0X4F77E00] ,Len: 80000 MMCBLK0P6 (QSEE) Range: [0X4F78000,0X4FF7E00] ,Len: 80000 MMCBLK0P7 (QHEE) Range: [0X4FF8000,0X5077E00] ,Len: 80000 MMCBLK0P8 (FSG) Range: [0X5078000,0X5377E00] ,Len: 300000 MMCBLK0P9 (SEC) Range: [0X5378000,0X537BE00] ,Len: 4000 MMCBLK0P10 (PAD) Range: [0X537C000,0X5DFFE00] ,Len: A84000 MMCBLK0P11 (PARAM) Range: [0X5E00000,0X67FFE00] ,Len: A00000 MMCBLK0P12 (EFS) Range: [0X6800000,0X75FFE00] ,Len: E00000 MMCBLK0P13 (MODEMST1) Range: [0X7600000,0X78FFE00] ,Len: 300000 MMCBLK0P14 (MODEMST2) Range: [0X7900000,0X7BFFE00] ,Len: 300000 MMCBLK0P15 (BOOT) Range: [0X7C00000,0X88FFE00] ,Len: D00000 MMCBLK0P16 (RECOVERY) Range: [0X8900000,0X97FFE00] ,Len: F00000 MMCBLK0P17 (FOTA) Range: [0X9800000,0X9D00200] ,Len: 500400 MMCBLK0P18 (BACKUP) Range: [0X9D00400,0XA3FDE00] ,Len: 6FDC00 MMCBLK0P19 (FSC) Range: [0XA3FE000,0XA6FDE00] ,Len: 300000 MMCBLK0P20 (SSD) Range: [0XA6FE000,0XA6FFE00] ,Len: 2000 MMCBLK0P21 (PERSIST) Range: [0XA700000,0XAEFFE00] ,Len: 800000 MMCBLK0P22 (PERSDATA) Range: [0XAF00000,0XB7FFE00] ,Len: 900000 MMCBLK0P23 (SYSTEM) Range: [0XB800000,0XA4FFFE00] ,Len: 99800000 MMCBLK0P24 (CACHE) Range: [0XA5000000,0XB17FFE00] ,Len: C800000 MMCBLK0P25 (HIDDEN) Range: [0XB1800000,0XB49FFE00] ,Len: 3200000 MMCBLK0P26 (USERDATA) Range: [0XB4A00000,0XB49FFE00] ,Len: 0 Done...Presets has been updated... i wrote the full dump from support but still dead... also tried to flash with Direct eMMC Samsung Flasher .. Flashing completed but phone still dead.. regards |
