a30s cant write dump Skip loading eMMC Addon Firmware CMD Pullup Level:467 mV CMD Active Level:2255 mV Input file : D:\a307m\backup a307g bit 3\EMMC_CUTA42_ROM1_000000000000_000020000000.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Error writing address 0x00000000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x0000000000 (Attempt #1)... Retry failed at address 0x00000000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x0000000000 (Attempt #2)... Retry failed at address 0x00000000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x0000000000 (Attempt #3)... Retry failed at address 0x00000000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x0000000000 (Attempt #4)... Retry failed at address 0x00000000 Error Code:-8 Reason :DATA SND CRC Error Retry writing address 0x0000000000 (Attempt #5)... Retry failed at address 0x00000000 Error Code:-8 Reason :DATA SND CRC Error Write Block Failed, Reason: DATA SND CRC Error Done. Done with error(s) |
Try another eMMC. This eMMC need replace Try to read stiked topics or use search |
Hello sir you can shared the mmc pinout pleace |
3/28/2020 1:10:49 AM> Looking for EasyJTAG box... 3/28/2020 1:10:49 AM> EasyJTAG API ver. 3307 3/28/2020 1:10:49 AM> Setting IO Levels to 2.8V 3/28/2020 1:10:49 AM> Setting frequence to 18 MHz 3/28/2020 1:10:49 AM> EasyJTAG Box Serial = xxxxxxxxxxxx 3/28/2020 1:10:49 AM> EasyJTAG Box Firmware = 2.50 3/28/2020 1:10:50 AM> Setting interface to EasyJtag2/ISP 3/28/2020 1:10:50 AM> Setting bus width to 1 Bit 3/28/2020 1:10:50 AM> Setting frequence to 18 MHz 3/28/2020 1:10:50 AM> CMD Pullup Level: 2719 mV 3/28/2020 1:10:50 AM> CMD Active Level: 2791 mV 3/28/2020 1:10:50 AM> eMMC Init returned = 0 3/28/2020 1:10:50 AM> EMMC Device Information : 3/28/2020 1:10:50 AM> EMMC CID: 450100444134303634015653800B2625 3/28/2020 1:10:50 AM> EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 3/28/2020 1:10:50 AM> EMMC Manufacture : SANDISK , EMMC NAME: DA4064 , HEX: 444134303634 , S/N: 5653800B , rev. 0x01 3/28/2020 1:10:50 AM> EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2019 3/28/2020 1:10:50 AM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) 3/28/2020 1:10:50 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/28/2020 1:10:50 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 6523 , Response: Not Clean 3/28/2020 1:10:50 AM> EMMC Permanent Write Protection: No 3/28/2020 1:10:50 AM> EMMC Temporary Write Protection: No 3/28/2020 1:10:50 AM> Extended CSD Information : 3/28/2020 1:10:50 AM> Extended CSD rev: 1.8 (MMC 5.1) 3/28/2020 1:10:50 AM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 3/28/2020 1:10:50 AM> Boot Bus Config: 0x02 , width 8bit 3/28/2020 1:10:50 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 3/28/2020 1:10:50 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/28/2020 1:10:50 AM> Device supports partitioning features 3/28/2020 1:10:50 AM> Device can have enhanced technological features in partitions and user data area 3/28/2020 1:10:50 AM> Device can have extended partitions attribute 3/28/2020 1:10:50 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/28/2020 1:10:50 AM> Backup saved: DA4064_5653800B_20200328_011050.extcsd 3/28/2020 1:10:50 AM> EMMC Init completed. 3/28/2020 1:10:50 AM> 3/28/2020 1:10:50 AM> Operation: Writing all eMMC Regions... 3/28/2020 1:10:50 AM> 3/28/2020 1:10:51 AM> Operation: Writing BootConfig ... 3/28/2020 1:10:51 AM> Reg: 179 Value: 0x08 3/28/2020 1:10:51 AM> Reg: 177 Value: 0x02 3/28/2020 1:10:51 AM> Reg: 162 Value: 0x01 3/28/2020 1:10:51 AM> Done 3/28/2020 1:10:51 AM> 3/28/2020 1:10:52 AM> Writing to: ROM1 , start: 0x000000000000 , size: 0x000100000000 3/28/2020 1:10:52 AM> Filename: userarea_4GiB.bin 3/28/2020 1:10:52 AM> eMMC switching to ROM1 3/28/2020 1:10:52 AM> Writing partition... 3/28/2020 1:44:58 AM> Done writing partition. Write speed: 2050.68 KB/s mr layder now dump write ok, now my phone download mode but try to write firmware BL AP CSC and CP but always error in param. my frp is off my oem :on and kg locked can helpme to solved this problem |
where can i find easy jtag plus pinout for isp a307g please |
