01-19-2020, 15:34 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | about error read emmc with socket mrooc i have received my easy jtag plus today: with E-MATE V1 EMMC BGA 7 IN 1 i set up all interfaces NOW U FACE A PROBLEM WITH read emmc for SM-A750FN BGA-153 ( KLMDG4UCTA-B041> I JUST need to read it for experiment> and use emmc tool suite for this and give me error> Can't init device. Reason: CMD Timeout Error i this error usually: if i conceting isp there is error in vcc or if i put dirctly the emmc may be it is dead but guys i use before another tool and read it what can i do here plz |
01-19-2020, 20:46 | #2 (permalink) |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | what is error guys i test another emmc KMN5X000ZA-B20a bga 162 same problem not read Code: Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz Can't init device. Reason: CMD Timeout Error Can't init device. Reason: CMD Timeout Error Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 36 MHz CMD Pullup Level: 2270 mV CMD Active Level: 2014 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 2269 mV CMD Active Level: 2012 mV Can't init device. Reason: CMD Timeout Error |
01-19-2020, 21:13 | #3 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | all users use complect box adapter and have no problem read this topic, please http://forum.gsmhosting.com/vbb/f672...w-kit-2770872/ |
The Following User Says Thank You to layder For This Useful Post: |
01-22-2020, 13:44 | #4 (permalink) |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | hi my check soket head and IC position is correct and make sure from ur pic check my pic here and plz tell me what is problem / also reballing is good as i said and it work with another tool |
01-22-2020, 16:59 | #5 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | you need check soldering connectors also you need remove head screw and clean PCB pins under socket head |
02-15-2020, 19:36 | #6 (permalink) |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | hi after this time at last i can read it now guys plz need if i can extract data from it -contacts-messages-pic and all data can i or not Code: eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Firmware = 2.50 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 1501004 EMMC CSD: D02701 EMMC Manufacture : SAMSUNG , EMMC NAME: DUTA42 , HEX: 445554413432 , S/N: C9C6588E , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2018 EMMC ROM 1 (Main User Data) Capacity: 119280 MB (001D1F000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: DUTA42_C9C6588E_20200215_203208.extcsd EMMC Init completed. Warning: BusWidth is automatically set to 1 Bit Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: NA, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: CM, [000002800000 - 000003000000], size: 000000800000 (8.00 MB) Partition: m9kefs1, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: m9kefs2, [000003400000 - 000003800000], size: 000000400000 (4.00 MB) Partition: m9kefs3, [000003800000 - 000003C00000], size: 000000400000 (4.00 MB) Partition: NAD_REFER, [000003C00000 - 000003D00000], size: 000000100000 (1.00 MB) Partition: PARAM, [000003D00000 - 000004500000], size: 000000800000 (8.00 MB) Partition: BOOT, [000004500000 - 000006500000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000006500000 - 000008B00000], size: 000002600000 (38.0 MB) Partition: DTBO, [000008B00000 - 000008F00000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000008F00000 - 000009700000], size: 000000800000 (8.00 MB) Partition: MISC, [000009700000 - 000009800000], size: 000000100000 (1.00 MB) Partition: RADIO, [000009800000 - 00000C500000], size: 000002D00000 (45.0 MB) Partition: PERSISTENT, [00000C500000 - 00000C580000], size: 000000080000 (512. KB) Partition: STEADY, [00000C580000 - 00000C980000], size: 000000400000 (4.00 MB) Partition: RESERVED2, [00000C980000 - 00000D000000], size: 000000680000 (6.50 MB) Partition: SYSTEM, [00000D000000 - 000101000000], size: 0000F4000000 (3.81 GB) Partition: VENDOR, [000101000000 - 000120000000], size: 00001F000000 (496. MB) Partition: ODM, [000120000000 - 000142000000], size: 000022000000 (544. MB) Partition: CACHE, [000142000000 - 000151A00000], size: 00000FA00000 (250. MB) Partition: HIDDEN, [000151A00000 - 000151F00000], size: 000000500000 (5.00 MB) Partition: OMR, [000151F00000 - 000155100000], size: 000003200000 (50.0 MB) Partition: CP_DEBUG, [000155100000 - 000155600000], size: 000000500000 (5.00 MB) Partition: NAD_FW, [000155600000 - 000156A00000], size: 000001400000 (20.0 MB) Partition: USERDATA, [000156A00000 - 001D1EA00000], size: 001BC8000000 (111. GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = a7y18lte Model = SM-A750F CPU Abi = arm64-v8a Android release = 9 Firmware version = PPR1.180610.011.A750FXXU2BSH8 Firmware date = Tue Aug 27 19:55:20 KST 2019 |
02-15-2020, 19:39 | #7 (permalink) |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | Code: Operation: File Explorer... Scan from: DUTA42 Vendor: Samsung Searching GPT ... GPT header is found and is valid GPT header successfully parsed Scan done Mount [efs] successfully PartType: LINUX Mount [cpefs] successfully PartType: LINUX Mount [PERSISTENT] SKIPPED PartType: FRP <<< FRP !!! Mount [system] successfully PartType: LINUX Mount [vendor] successfully PartType: LINUX Mount [odm] successfully PartType: LINUX Mount [cache] successfully PartType: LINUX Mount [hidden] successfully PartType: LINUX Mount [omr] successfully PartType: LINUX Mount [USERDATA] SKIPPED PartType: Full Disk Encryption Get firmware version Brand = samsung Manufacturer = samsung Device = a7y18lte Model = SM-A750F CPU Abi = arm64-v8a Android release = 9 Firmware version = PPR1.180610.011.A750FXXU2BSH8 Firmware date = Tue Aug 27 19:55:20 KST 2019 |
