12-06-2017, 14:30 | #1 (permalink) |
Freak Poster Join Date: Jul 2014
Member: 2228162 Status: Offline Sonork: 23243564rtrwe Thanks Meter: 31 | after replacing n7100 emmc from i9300 imei null and when repair alwys stuck with error Product code: Unknown Phone version: Unknown PDA version: N7100XXSFQAA CSC version: N7100OLBFNI1 IMEI: Unknown Phone S/N: Unknown Checking Super user right... true Disabling Factory mode... OK Reading nv data... OK Reading modem... OK Patching modem... OK Writing modem... OK Reading kernel... OK Checking magic... SSNV not found i installed a new emmc that prevucly programed it worked my question is why the emmc from the i9300 shoing imei null |
12-06-2017, 16:28 | #2 (permalink) |
Insane Poster Join Date: Nov 2009 Location: iran .. sari
Member: 1168670 Status: Offline Thanks Meter: 20 | Hi Your problem is internal ram of this type of emmc Your emmc hase a kind of ram with 1g capacity If that is not conected each of any pin or be damaged by voltag cant get good conection with cpu of base band processor . So your phone havnt base band and you need by orginal new emmc then replace after that must reset and write good efs If you have any problem make report on this post By drphone team |
12-06-2017, 16:31 | #3 (permalink) |
Junior Member Join Date: Dec 2017 Location: iran-sari
Member: 2786231 Status: Offline Thanks Meter: 6 | Hi You get your emmc from alive phone not dead becuse may emmc of dead phone have any problem or be damaged |
The Following User Says Thank You to mohamad.shahabi For This Useful Post: |
12-07-2017, 07:49 | #4 (permalink) | |
Member: 2228162 Status: Offline Sonork: 23243564rtrwe Thanks Meter: 31 | Quote:
and my s3 emmc is working but shows imei null | |
12-07-2017, 12:24 | #6 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | on i9300 there is a pad on pcb.that is connected to baseband chip.if that pad is open broken then you will get imei null. i have tested that problam. my sonork is not working. batter pm me i will send you problam picture |
12-23-2017, 04:42 | #11 (permalink) |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | kmvtu kmv3w kmv2w can use on i9300 no problem .....your baseband unknown is because bad emmc bad pad .... for 100% succes you need to remove emmc with drill and use new kmvtu etc here how to drill emmc tutorial https://www.youtube.com/watch?v=stXUsLWyQIY&t=62s if success the baseband exist and imei shoul 0049xxxxxxxx Last edited by bagus.dps; 12-23-2017 at 04:50. |
