Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 11-22-2018, 15:41   #16 (permalink)
Member: 484531
Thanks Meter: 67
https://www.fshare.vn/file/MACI9GCZP9VE
dump file max level .good luck
Old 11-23-2018, 12:44   #17 (permalink)
durgesh4rbl's Avatar
Member: 1525102
Sonork: 100.1626123
Thanks Meter: 143
c900f boot repair
Thanks bro
but set is not alive
Old 11-24-2018, 05:56   #18 (permalink)
Member: 1525102
Sonork: 100.1626123
Thanks Meter: 143
plz anyone halp me whats wrong with me
Old 11-26-2018, 14:26   #19 (permalink)
Member: 1525102
Sonork: 100.1626123
Thanks Meter: 143
not solve my problem
Old 11-28-2018, 01:25   #20 (permalink)
Crazy Poster
Member: 2772222
Thanks Meter: 2
Are you using the last firmware file?
Old 11-28-2018, 08:19   #21 (permalink)
Member: 1525102
Sonork: 100.1626123
Thanks Meter: 143
c900f boot repair
yes bro use latest bl file
Old 11-28-2018, 21:32   #22 (permalink)
Crazy Poster
Member: 2772222
Thanks Meter: 2
Did you check hardware conditions (CLK, CMD, VCC, VCCQ) ?
Old 11-29-2018, 07:06   #23 (permalink)
Member: 1525102
Sonork: 100.1626123
Thanks Meter: 143
hardware is ok because phone is dead after flash aboot file
Old 12-05-2018, 19:38   #24 (permalink)
Member: 2636476
Thanks Meter: 50
I also having same problem after write bl show 9008 port
I think 8.0 lz4 not supported for write in z3x
Need to w8 for new update
Old 12-05-2018, 21:58   #25 (permalink)
Member: 13148
Thanks Meter: 1,235
We are is testing lz4 at new update. Wait, please
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 12-08-2018, 17:02   #26 (permalink)
Member: 2636476
Thanks Meter: 50
samsung c900f after write BL set goes to 9008 port
samsung c900f set history
dead after flash with combination then connect to easy jtag
after write latest BL with easy jtag plus set goes to 9008 port
using this version C900FDDU1CRJ4
12/8/2018 9:31:16 PM> Setting interface to EasyJtag2/ISP
12/8/2018 9:31:16 PM> Setting bus width to 1 Bit
12/8/2018 9:31:16 PM> Setting frequence to 18 Mhz
12/8/2018 9:31:16 PM> CMD Pullup Level: 2091 mV
12/8/2018 9:31:16 PM> CMD Active Level: 2545 mV
12/8/2018 9:31:16 PM> eMMC Init returned = 0
12/8/2018 9:31:16 PM> EMMC Device Information :
12/8/2018 9:31:16 PM> EMMC CID: 150100434A4E423452103FE9EAE91449
12/8/2018 9:31:16 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
12/8/2018 9:31:16 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: CJNB4R , HEX: 434A4E423452 , S/N: 3FE9EAE9 , rev. 0x10
12/8/2018 9:31:16 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2017
12/8/2018 9:31:16 PM>    EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
12/8/2018 9:31:16 PM>    EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/8/2018 9:31:16 PM>    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
12/8/2018 9:31:16 PM> EMMC Permanent Write Protection: No
12/8/2018 9:31:16 PM> EMMC Temporary Write Protection: No
12/8/2018 9:31:16 PM> Extended CSD Information :
12/8/2018 9:31:16 PM> Extended CSD rev: 1.8 (MMC 5.1)
12/8/2018 9:31:16 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
12/8/2018 9:31:16 PM> Boot Bus Config: 0x00 , width 1bit
12/8/2018 9:31:16 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
12/8/2018 9:31:16 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/8/2018 9:31:16 PM> Device supports partitioning features
12/8/2018 9:31:16 PM> Device can have enhanced technological features in partitions and user data area
12/8/2018 9:31:16 PM> Device can have extended partitions attribute
12/8/2018 9:31:16 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/8/2018 9:31:16 PM> Backup saved: CJNB4R_3FE9EAE9_20181208_213116.extcsd
12/8/2018 9:31:16 PM> EMMC Init completed.
12/8/2018 9:31:16 PM> Scanning soft partitions
12/8/2018 9:31:16 PM> GPT header is found and is valid
12/8/2018 9:31:16 PM> Partition: sbl1, [000000400000 - 000000480000], size: 000000080000 (512. KB)
12/8/2018 9:31:16 PM> Partition: sbl1bak, [000000480000 - 000000500000], size: 000000080000 (512. KB)
12/8/2018 9:31:16 PM> Partition: ddr, [000000500000 - 000000508000], size: 000000008000 (32.0 KB)
12/8/2018 9:31:16 PM> Partition: limits, [000000508000 - 000000510000], size: 000000008000 (32.0 KB)
12/8/2018 9:31:16 PM> Partition: aboot, [000000510000 - 000000710000], size: 000000200000 (2.00 MB)
12/8/2018 9:31:16 PM> Partition: rpm, [000000710000 - 000000790000], size: 000000080000 (512. KB)
12/8/2018 9:31:16 PM> Partition: tz, [000000790000 - 000000990000], size: 000000200000 (2.00 MB)
12/8/2018 9:31:16 PM> Partition: hyp, [000000990000 - 000000A10000], size: 000000080000 (512. KB)
12/8/2018 9:31:16 PM> Partition: fsg, [000000A10000 - 000000D10000], size: 000000300000 (3.00 MB)
12/8/2018 9:31:16 PM> Partition: sec, [000000D10000 - 000000D14000], size: 000000004000 (16.0 KB)
12/8/2018 9:31:16 PM> Partition: keymaster, [000000D14000 - 000000D94000], size: 000000080000 (512. KB)
12/8/2018 9:31:16 PM> Partition: cmnlib, [000000D94000 - 000000DD4000], size: 000000040000 (256. KB)
12/8/2018 9:31:16 PM> Partition: lksecapp, [000000DD4000 - 000000E54000], size: 000000080000 (512. KB)
12/8/2018 9:31:16 PM> Partition: apdp, [000000E54000 - 000000E74000], size: 000000020000 (128. KB)
12/8/2018 9:31:16 PM> Partition: msadp, [000000E74000 - 000000E94000], size: 000000020000 (128. KB)
12/8/2018 9:31:16 PM> Partition: pad, [000000E94000 - 000001800000], size: 00000096C000 (9.42 MB)
12/8/2018 9:31:16 PM> Partition: modemst1, [000001800000 - 000001B00000], size: 000000300000 (3.00 MB)
12/8/2018 9:31:16 PM> Partition: modemst2, [000001B00000 - 000001E00000], size: 000000300000 (3.00 MB)
12/8/2018 9:31:16 PM> Partition: param, [000001E00000 - 000002800000], size: 000000A00000 (10.0 MB)
12/8/2018 9:31:16 PM> Partition: efs, [000002800000 - 000003600000], size: 000000E00000 (14.0 MB)
12/8/2018 9:31:16 PM> Partition: boot, [000003600000 - 000005600000], size: 000002000000 (32.0 MB)
12/8/2018 9:31:16 PM> Partition: recovery, [000005600000 - 000007600000], size: 000002000000 (32.0 MB)
12/8/2018 9:31:16 PM> Partition: bota, [000007600000 - 000007D00000], size: 000000700000 (7.00 MB)
12/8/2018 9:31:16 PM> Partition: fota, [000007D00000 - 000008200400], size: 000000500400 (5.00 MB)
12/8/2018 9:31:16 PM> Partition: backup, [000008200400 - 0000087FE000], size: 0000005FDC00 (5.99 MB)
12/8/2018 9:31:16 PM> Partition: fsc, [0000087FE000 - 000008AFE000], size: 000000300000 (3.00 MB)
12/8/2018 9:31:16 PM> Partition: ssd, [000008AFE000 - 000008B00000], size: 000000002000 (8.00 KB)
12/8/2018 9:31:16 PM> Partition: persist, [000008B00000 - 00000AB00000], size: 000002000000 (32.0 MB)
12/8/2018 9:31:16 PM> Partition: persistent, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB)
12/8/2018 9:31:16 PM> Partition: steady, [00000AC00000 - 00000AD00000], size: 000000100000 (1.00 MB)
12/8/2018 9:31:16 PM> Partition: keystore, [00000AD00000 - 00000AD80000], size: 000000080000 (512. KB)
12/8/2018 9:31:16 PM> Partition: config, [00000AD80000 - 00000AD88000], size: 000000008000 (32.0 KB)
12/8/2018 9:31:16 PM> Partition: mota, [00000AD88000 - 00000AE88000], size: 000000100000 (1.00 MB)
12/8/2018 9:31:16 PM> Partition: devcfg, [00000AE88000 - 00000AEC8000], size: 000000040000 (256. KB)
12/8/2018 9:31:16 PM> Partition: dsp, [00000AEC8000 - 00000BEC8000], size: 000001000000 (16.0 MB)
12/8/2018 9:31:16 PM> Partition: modem, [00000BEC8000 - 000012700000], size: 000006838000 (104. MB)
12/8/2018 9:31:16 PM> Partition: apnhlos, [000012700000 - 000014F00000], size: 000002800000 (40.0 MB)
12/8/2018 9:31:16 PM> Partition: persdata, [000014F00000 - 000015800000], size: 000000900000 (9.00 MB)
12/8/2018 9:31:16 PM> Partition: system, [000015800000 - 000134800000], size: 00011F000000 (4.48 GB)
12/8/2018 9:31:16 PM> Partition: cache, [000134800000 - 000141000000], size: 00000C800000 (200. MB)
12/8/2018 9:31:16 PM> Partition: hidden, [000141000000 - 000147400000], size: 000006400000 (100. MB)
12/8/2018 9:31:16 PM> Partition: userdata, [000147400000 - 000E8F7FB000], size: 000D483FB000 (53.1 GB)
12/8/2018 9:31:16 PM> GPT header successfully parsed
12/8/2018 9:31:16 PM> Get firmware version
12/8/2018 9:31:17 PM> Brand = samsung
12/8/2018 9:31:17 PM> Manufacturer = samsung
12/8/2018 9:31:17 PM> Model = SM-C900F
12/8/2018 9:31:17 PM> Phone platform = msm8952
12/8/2018 9:31:17 PM> CPU Abi = arm64-v8a
12/8/2018 9:31:17 PM> Android release = 8.0.0
12/8/2018 9:31:17 PM> Firmware version = R16NW.C900FDDU1CRJ4
12/8/2018 9:31:17 PM> Firmware date = Thu Oct 25 15:42:44 KST 2018
12/8/2018 9:31:22 PM>
12/8/2018 9:31:22 PM> Looking for EasyJTAG box...
12/8/2018 9:31:22 PM> EasyJTAG API ver. 2100
12/8/2018 9:31:22 PM> Setting IO Levels to 2.8V
12/8/2018 9:31:22 PM> Setting frequence to 18 Mhz
12/8/2018 9:31:22 PM> EasyJTAG Box Serial =
12/8/2018 9:31:22 PM> EasyJTAG Box Firmware = 2.30
12/8/2018 9:31:23 PM> Setting interface to EasyJtag2/ISP
12/8/2018 9:31:23 PM> Setting bus width to 1 Bit
12/8/2018 9:31:23 PM> Setting frequence to 18 Mhz
12/8/2018 9:31:23 PM> CMD Pullup Level: 2094 mV
12/8/2018 9:31:23 PM> CMD Active Level: 2668 mV
12/8/2018 9:31:23 PM> eMMC Init returned = 0
12/8/2018 9:31:23 PM> EMMC Device Information :
12/8/2018 9:31:23 PM> EMMC CID: 150100434A4E423452103FE9EAE91449
12/8/2018 9:31:23 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
12/8/2018 9:31:23 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: CJNB4R , HEX: 434A4E423452 , S/N: 3FE9EAE9 , rev. 0x10
12/8/2018 9:31:23 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2017
12/8/2018 9:31:23 PM>    EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
12/8/2018 9:31:23 PM>    EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/8/2018 9:31:23 PM>    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
12/8/2018 9:31:23 PM> EMMC Permanent Write Protection: No
12/8/2018 9:31:23 PM> EMMC Temporary Write Protection: No
12/8/2018 9:31:23 PM> Extended CSD Information :
12/8/2018 9:31:23 PM> Extended CSD rev: 1.8 (MMC 5.1)
12/8/2018 9:31:23 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
12/8/2018 9:31:23 PM> Boot Bus Config: 0x00 , width 1bit
12/8/2018 9:31:23 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
12/8/2018 9:31:23 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/8/2018 9:31:23 PM> Device supports partitioning features
12/8/2018 9:31:23 PM> Device can have enhanced technological features in partitions and user data area
12/8/2018 9:31:23 PM> Device can have extended partitions attribute
12/8/2018 9:31:23 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/8/2018 9:31:23 PM> Backup saved: CJNB4R_3FE9EAE9_20181208_213123.extcsd
12/8/2018 9:31:23 PM> EMMC Init completed.
12/8/2018 9:31:23 PM> Operation: Find table from emmc
12/8/2018 9:31:23 PM> Vendor: Samsung
12/8/2018 9:31:23 PM> Searching GPT ...
12/8/2018 9:31:23 PM> GPT header is found and is valid
12/8/2018 9:31:23 PM> Checking for ROM2 ...
12/8/2018 9:31:25 PM> ROM2 is blank
12/8/2018 9:31:26 PM> GPT header successfully parsed
12/8/2018 9:31:26 PM> EFS backup is performed. Please wait...
12/8/2018 9:31:33 PM> EFS saved to:
12/8/2018 9:31:33 PM> \Backups\EFS\efs_SM-C900F_RZ8J3179Y2P_20181208_213126.bin
12/8/2018 9:31:33 PM> \Backups\EFS\efs_for_z3x_oldtype_SM-C900F_RZ8J3179Y2P_20181208_213126.tar
12/8/2018 9:31:33 PM> \Backups\EFS\efs_for_z3x_newtype_SM-C900F_RZ8J3179Y2P_20181208_213126.tar
12/8/2018 9:31:33 PM> All Done
12/8/2018 9:31:49 PM> Looking for EasyJTAG box...
12/8/2018 9:31:49 PM> EasyJTAG API ver. 2100
12/8/2018 9:31:49 PM> Setting IO Levels to 2.8V
12/8/2018 9:31:49 PM> Setting frequence to 18 Mhz
12/8/2018 9:31:49 PM> EasyJTAG Box Serial =
12/8/2018 9:31:49 PM> EasyJTAG Box Firmware = 2.30
12/8/2018 9:31:49 PM> Setting interface to EasyJtag2/ISP
12/8/2018 9:31:49 PM> Setting bus width to 1 Bit
12/8/2018 9:31:49 PM> CMD Pullup Level: 2093 mV
12/8/2018 9:31:49 PM> CMD Active Level: 2667 mV
12/8/2018 9:31:49 PM> eMMC Init returned = 0
12/8/2018 9:31:49 PM> EMMC Device Information :
12/8/2018 9:31:49 PM> EMMC CID: 150100434A4E423452103FE9EAE91449
12/8/2018 9:31:49 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
12/8/2018 9:31:49 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: CJNB4R , HEX: 434A4E423452 , S/N: 3FE9EAE9 , rev. 0x10
12/8/2018 9:31:49 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2017
12/8/2018 9:31:49 PM>    EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
12/8/2018 9:31:49 PM>    EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/8/2018 9:31:49 PM>    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
12/8/2018 9:31:49 PM> EMMC Permanent Write Protection: No
12/8/2018 9:31:49 PM> EMMC Temporary Write Protection: No
12/8/2018 9:31:49 PM> Extended CSD Information :
12/8/2018 9:31:49 PM> Extended CSD rev: 1.8 (MMC 5.1)
12/8/2018 9:31:49 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
12/8/2018 9:31:49 PM> Boot Bus Config: 0x00 , width 1bit
12/8/2018 9:31:49 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
12/8/2018 9:31:49 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/8/2018 9:31:49 PM> Device supports partitioning features
12/8/2018 9:31:49 PM> Device can have enhanced technological features in partitions and user data area
12/8/2018 9:31:49 PM> Device can have extended partitions attribute
12/8/2018 9:31:49 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/8/2018 9:31:49 PM> Backup saved: CJNB4R_3FE9EAE9_20181208_213149.extcsd
12/8/2018 9:31:49 PM> EMMC Init completed.
12/8/2018 9:31:51 PM> Backup partition: PrimaryGPT
12/8/2018 9:31:51 PM> Address: 000000000000, size: 000000004400
12/8/2018 9:31:51 PM> GPTHeader is valid
12/8/2018 9:31:51 PM> Partition name: sbl1
12/8/2018 9:31:51 PM> Address: 000000400000, size: 000000080000
12/8/2018 9:31:51 PM> eMMC switching to ROM1
12/8/2018 9:31:51 PM> Reading partition...
12/8/2018 9:31:51 PM> Done reading partition. Read speed: 2143.79 Kb/s
12/8/2018 9:31:51 PM> Partition name: sbl1bak
12/8/2018 9:31:51 PM> Address: 000000480000, size: 000000080000
12/8/2018 9:31:52 PM> Reading partition...
12/8/2018 9:31:52 PM> Done reading partition. Read speed: 2135.19 Kb/s
12/8/2018 9:31:52 PM> Partition name: ddr
12/8/2018 9:31:52 PM> Address: 000000500000, size: 000000008000
12/8/2018 9:31:52 PM> eMMC switching to ROM1
12/8/2018 9:31:52 PM> Done reading partition. Read speed: 1945.94 Kb/s
12/8/2018 9:31:52 PM> Partition name: limits
12/8/2018 9:31:52 PM> Address: 000000508000, size: 000000008000
12/8/2018 9:31:52 PM> Done reading partition. Read speed: 1911.24 Kb/s
12/8/2018 9:31:52 PM> Partition name: aboot
12/8/2018 9:31:52 PM> Address: 000000510000, size: 000000200000
12/8/2018 9:31:53 PM> Done reading partition. Read speed: 2133.41 Kb/s
12/8/2018 9:31:53 PM> Partition name: rpm
12/8/2018 9:31:53 PM> Address: 000000710000, size: 000000080000
12/8/2018 9:31:53 PM> eMMC switching to ROM1
12/8/2018 9:31:53 PM> Reading partition...
12/8/2018 9:31:54 PM> Done reading partition. Read speed: 2140.45 Kb/s
12/8/2018 9:31:54 PM> Partition name: tz
12/8/2018 9:31:54 PM> Address: 000000790000, size: 000000200000
12/8/2018 9:31:54 PM> eMMC switching to ROM1
12/8/2018 9:31:54 PM> Reading partition...
12/8/2018 9:31:55 PM> Done reading partition. Read speed: 2149.35 Kb/s
12/8/2018 9:31:55 PM> Partition name: hyp
12/8/2018 9:31:55 PM> Address: 000000990000, size: 000000080000
12/8/2018 9:31:55 PM> eMMC switching to ROM1
12/8/2018 9:31:55 PM> Reading partition...
12/8/2018 9:31:55 PM> Done reading partition. Read speed: 2133.08 Kb/s
12/8/2018 9:31:55 PM> Partition name: fsg
12/8/2018 9:31:55 PM> Address: 000000A10000, size: 000000300000
12/8/2018 9:31:57 PM> Done reading partition. Read speed: 2146.85 Kb/s
12/8/2018 9:31:57 PM> Partition name: sec
12/8/2018 9:31:57 PM> Address: 000000D10000, size: 000000004000
12/8/2018 9:31:57 PM> eMMC switching to ROM1
12/8/2018 9:31:57 PM> Reading partition...
12/8/2018 9:31:57 PM> Done reading partition. Read speed: 1740.31 Kb/s
12/8/2018 9:31:57 PM> Partition name: keymaster
12/8/2018 9:31:57 PM> Address: 000000D14000, size: 000000080000
12/8/2018 9:31:57 PM> Done reading partition. Read speed: 2122.92 Kb/s
12/8/2018 9:31:57 PM> Partition name: cmnlib
12/8/2018 9:31:57 PM> Address: 000000D94000, size: 000000040000
12/8/2018 9:31:57 PM> Done reading partition. Read speed: 2123.55 Kb/s
12/8/2018 9:31:57 PM> Partition name: lksecapp
12/8/2018 9:31:57 PM> Address: 000000DD4000, size: 000000080000
12/8/2018 9:31:58 PM> Reading partition...
12/8/2018 9:31:58 PM> Done reading partition. Read speed: 2135.04 Kb/s
12/8/2018 9:31:58 PM> Partition name: apdp
12/8/2018 9:31:58 PM> Address: 000000E54000, size: 000000020000
12/8/2018 9:31:58 PM> eMMC switching to ROM1
12/8/2018 9:31:58 PM> Done reading partition. Read speed: 2097.93 Kb/s
12/8/2018 9:31:58 PM> Partition name: msadp
12/8/2018 9:31:58 PM> Address: 000000E74000, size: 000000020000
12/8/2018 9:31:58 PM> Done reading partition. Read speed: 2093.63 Kb/s
12/8/2018 9:31:58 PM> Partition name: pad
12/8/2018 9:31:58 PM> Address: 000000E94000, size: 00000096C000
12/8/2018 9:32:03 PM> Done reading partition. Read speed: 2150.64 Kb/s
12/8/2018 9:32:03 PM> Partition name: modemst1
12/8/2018 9:32:03 PM> Address: 000001800000, size: 000000300000
12/8/2018 9:32:03 PM> eMMC switching to ROM1
12/8/2018 9:32:03 PM> Reading partition...
12/8/2018 9:32:04 PM> Done reading partition. Read speed: 2120.53 Kb/s
12/8/2018 9:32:04 PM> Partition name: modemst2
12/8/2018 9:32:04 PM> Address: 000001B00000, size: 000000300000
12/8/2018 9:32:04 PM> eMMC switching to ROM1
12/8/2018 9:32:05 PM> Reading partition...
12/8/2018 9:32:06 PM> Done reading partition. Read speed: 2142.18 Kb/s
12/8/2018 9:32:06 PM> Partition name: param
12/8/2018 9:32:06 PM> Address: 000001E00000, size: 000000A00000
12/8/2018 9:32:06 PM> eMMC switching to ROM1
12/8/2018 9:32:06 PM> Reading partition...
12/8/2018 9:32:11 PM> Done reading partition. Read speed: 2139.51 Kb/s
12/8/2018 9:32:11 PM> Partition name: efs
12/8/2018 9:32:11 PM> Address: 000002800000, size: 000000E00000
12/8/2018 9:32:11 PM> eMMC switching to ROM1
12/8/2018 9:32:11 PM> Reading partition...
12/8/2018 9:32:18 PM> Done reading partition. Read speed: 2148.20 Kb/s
12/8/2018 9:32:18 PM> Partition name: boot
12/8/2018 9:32:18 PM> Address: 000003600000, size: 000002000000
12/8/2018 9:32:18 PM> eMMC switching to ROM1
12/8/2018 9:32:18 PM> Reading partition...
12/8/2018 9:32:34 PM> Done reading partition. Read speed: 2001.09 Kb/s
12/8/2018 9:32:34 PM> Partition name: recovery
12/8/2018 9:32:34 PM> Address: 000005600000, size: 000002000000
12/8/2018 9:32:34 PM> eMMC switching to ROM1
12/8/2018 9:32:34 PM> Reading partition...
12/8/2018 9:33:00 PM> Done reading partition. Read speed: 1299.06 Kb/s
12/8/2018 9:33:00 PM> Partition name: bota
12/8/2018 9:33:00 PM> Address: 000007600000, size: 000000700000
12/8/2018 9:33:00 PM> eMMC switching to ROM1
12/8/2018 9:33:00 PM> Reading partition...
12/8/2018 9:33:03 PM> Done reading partition. Read speed: 2150.65 Kb/s
12/8/2018 9:33:03 PM> Partition name: fota
12/8/2018 9:33:03 PM> Address: 000007D00000, size: 000000500400
12/8/2018 9:33:03 PM> eMMC switching to ROM1
12/8/2018 9:33:03 PM> Reading partition...
12/8/2018 9:33:06 PM> Done reading partition. Read speed: 2143.54 Kb/s
12/8/2018 9:33:06 PM> Partition name: backup
12/8/2018 9:33:06 PM> Address: 000008200400, size: 0000005FDC00
12/8/2018 9:33:06 PM> eMMC switching to ROM1
12/8/2018 9:33:06 PM> Reading partition...
12/8/2018 9:33:09 PM> Done reading partition. Read speed: 2135.04 Kb/s
12/8/2018 9:33:09 PM> Partition name: fsc
12/8/2018 9:33:09 PM> Address: 0000087FE000, size: 000000300000
12/8/2018 9:33:09 PM> eMMC switching to ROM1
12/8/2018 9:33:09 PM> Reading partition...
12/8/2018 9:33:10 PM> Done reading partition. Read speed: 2150.25 Kb/s
12/8/2018 9:33:10 PM> Partition name: ssd
12/8/2018 9:33:10 PM> Address: 000008AFE000, size: 000000002000
12/8/2018 9:33:10 PM> eMMC switching to ROM1
12/8/2018 9:33:11 PM> Reading partition...
12/8/2018 9:33:11 PM> Done reading partition. Read speed: 1529.71 Kb/s
12/8/2018 9:33:11 PM> Partition name: persist
12/8/2018 9:33:11 PM> Address: 000008B00000, size: 000002000000
12/8/2018 9:33:11 PM> eMMC switching to ROM1
12/8/2018 9:33:26 PM> Done reading partition. Read speed: 2143.58 Kb/s
12/8/2018 9:33:26 PM> Partition name: persistent
12/8/2018 9:33:26 PM> Address: 00000AB00000, size: 000000100000
12/8/2018 9:33:26 PM> eMMC switching to ROM1
12/8/2018 9:33:26 PM> Reading partition...
12/8/2018 9:33:27 PM> Done reading partition. Read speed: 2120.77 Kb/s
12/8/2018 9:33:27 PM> Partition name: steady
12/8/2018 9:33:27 PM> Address: 00000AC00000, size: 000000100000
12/8/2018 9:33:27 PM> eMMC switching to ROM1
12/8/2018 9:33:27 PM> Reading partition...
12/8/2018 9:33:27 PM> Done reading partition. Read speed: 2120.85 Kb/s
12/8/2018 9:33:27 PM> Partition name: keystore
12/8/2018 9:33:27 PM> Address: 00000AD00000, size: 000000080000
12/8/2018 9:33:28 PM> Done reading partition. Read speed: 2089.31 Kb/s
12/8/2018 9:33:28 PM> Partition name: config
12/8/2018 9:33:28 PM> Address: 00000AD80000, size: 000000008000
12/8/2018 9:33:28 PM> eMMC switching to ROM1
12/8/2018 9:33:28 PM> Reading partition...
12/8/2018 9:33:28 PM> Done reading partition. Read speed: 1904.08 Kb/s
12/8/2018 9:33:28 PM> Partition name: mota
12/8/2018 9:33:28 PM> Address: 00000AD88000, size: 000000100000
12/8/2018 9:33:29 PM> Done reading partition. Read speed: 2126.00 Kb/s
12/8/2018 9:33:29 PM> Partition name: devcfg
12/8/2018 9:33:29 PM> Address: 00000AE88000, size: 000000040000
12/8/2018 9:33:29 PM> eMMC switching to ROM1
12/8/2018 9:33:29 PM> Reading partition...
12/8/2018 9:33:29 PM> Done reading partition. Read speed: 2143.88 Kb/s
12/8/2018 9:33:34 PM> Partition name: dsp
12/8/2018 9:33:34 PM> Address: 00000AEC8000, size: 000001000000
12/8/2018 9:33:34 PM> eMMC switching to ROM1
12/8/2018 9:33:34 PM> Reading partition...
12/8/2018 9:33:42 PM> Done reading partition. Read speed: 2069.14 Kb/s
12/8/2018 9:33:42 PM> Partition name: modem
12/8/2018 9:33:42 PM> Address: 00000BEC8000, size: 000006838000
12/8/2018 9:33:42 PM> eMMC switching to ROM1
12/8/2018 9:33:42 PM> Reading partition...
12/8/2018 9:34:33 PM> Done reading partition. Read speed: 2102.59 Kb/s
12/8/2018 9:34:33 PM> Partition name: apnhlos
12/8/2018 9:34:33 PM> Address: 000012700000, size: 000002800000
12/8/2018 9:34:33 PM> eMMC switching to ROM1
12/8/2018 9:34:33 PM> Reading partition...
12/8/2018 9:34:52 PM> Done reading partition. Read speed: 2142.95 Kb/s
12/8/2018 9:34:52 PM> Partition name: persdata
12/8/2018 9:34:52 PM> Address: 000014F00000, size: 000000900000
12/8/2018 9:34:52 PM> eMMC switching to ROM1
12/8/2018 9:34:52 PM> Reading partition...
12/8/2018 9:34:56 PM> Done reading partition. Read speed: 2146.37 Kb/s
12/8/2018 9:34:56 PM> Partition name: hidden
12/8/2018 9:34:56 PM> Address: 000141000000, size: 000006400000
12/8/2018 9:34:56 PM> eMMC switching to ROM1
12/8/2018 9:34:57 PM> Reading partition...
12/8/2018 9:35:44 PM> Done reading partition. Read speed: 2146.46 Kb/s
12/8/2018 9:35:44 PM> All done   time: [00:03:55:692]
12/8/2018 9:51:21 PM> Looking for EasyJTAG box...
12/8/2018 9:51:21 PM> EasyJTAG API ver. 2100
12/8/2018 9:51:21 PM> Setting IO Levels to 2.8V
12/8/2018 9:51:21 PM> Setting frequence to 18 Mhz
12/8/2018 9:51:21 PM> EasyJTAG Box Serial = 5
12/8/2018 9:51:21 PM> EasyJTAG Box Firmware = 2.30
12/8/2018 9:51:22 PM> Setting interface to EasyJtag2/ISP
12/8/2018 9:51:22 PM> Setting bus width to 1 Bit
12/8/2018 9:51:22 PM> Setting frequence to 18 Mhz
12/8/2018 9:51:22 PM> CMD Pullup Level: 2093 mV
12/8/2018 9:51:22 PM> CMD Active Level: 2667 mV
12/8/2018 9:51:22 PM> eMMC Init returned = 0
12/8/2018 9:51:22 PM> EMMC Device Information :
12/8/2018 9:51:22 PM> EMMC CID: 150100434A4E423452103FE9EAE91449
12/8/2018 9:51:22 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
12/8/2018 9:51:22 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: CJNB4R , HEX: 434A4E423452 , S/N: 3FE9EAE9 , rev. 0x10
12/8/2018 9:51:22 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2017
12/8/2018 9:51:22 PM>    EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
12/8/2018 9:51:22 PM>    EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/8/2018 9:51:22 PM>    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
12/8/2018 9:51:22 PM> EMMC Permanent Write Protection: No
12/8/2018 9:51:22 PM> EMMC Temporary Write Protection: No
12/8/2018 9:51:22 PM> Extended CSD Information :
12/8/2018 9:51:22 PM> Extended CSD rev: 1.8 (MMC 5.1)
12/8/2018 9:51:22 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
12/8/2018 9:51:22 PM> Boot Bus Config: 0x00 , width 1bit
12/8/2018 9:51:22 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
12/8/2018 9:51:22 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/8/2018 9:51:22 PM> Device supports partitioning features
12/8/2018 9:51:22 PM> Device can have enhanced technological features in partitions and user data area
12/8/2018 9:51:22 PM> Device can have extended partitions attribute
12/8/2018 9:51:22 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/8/2018 9:51:22 PM> Backup saved: CJNB4R_3FE9EAE9_20181208_215122.extcsd
12/8/2018 9:51:22 PM> EMMC Init completed.
12/8/2018 9:51:22 PM> Opening file: H:\DISK H\samsung files\C900f\8.0\SM-C900F_1_20181025194627_mc4f8lsqzx_fac\C9LTE_SWA_OPEN_HIDDEN100M.pit
12/8/2018 9:51:22 PM> Pit: C9LTE_SWA_OPEN_HIDDEN100M.pit
12/8/2018 9:51:22 PM> Entry count: 46
12/8/2018 9:51:22 PM> The size of the last section has been updated
12/8/2018 9:51:28 PM> Selected file: H:\DISK H\samsung files\C900f\8.0\SM-C900F_1_20181025194627_mc4f8lsqzx_fac\BL_C900FDDU1CRJ4_CL14339333_QB20329317_REV00_user_low_ship_MULTI_CERT.tar.md5
12/8/2018 9:51:28 PM> BL_C900FDDU1CRJ4_CL14339333_QB20329317_REV00_user_low_ship_MULTI_CERT.tar.md5
12/8/2018 9:51:28 PM> The list of files in the firmware:
12/8/2018 9:51:28 PM> aboot.mbn.lz4
12/8/2018 9:51:28 PM> sbl1.mbn.lz4
12/8/2018 9:51:28 PM> rpm.mbn.lz4
12/8/2018 9:51:28 PM> tz.mbn.lz4
12/8/2018 9:51:28 PM> devcfg.mbn.lz4
12/8/2018 9:51:28 PM> cmnlib.mbn.lz4
12/8/2018 9:51:28 PM> keymaster.mbn.lz4
12/8/2018 9:51:28 PM> apdp.mbn.lz4
12/8/2018 9:51:28 PM> msadp.mbn.lz4
12/8/2018 9:51:28 PM> non-hlos.bin.lz4
12/8/2018 9:51:28 PM> lksecapp.mbn.lz4
12/8/2018 9:51:28 PM> sec.dat.lz4
12/8/2018 9:51:53 PM> Nothing to write. Process stopped.
12/8/2018 9:56:44 PM> Looking for EasyJTAG box...
12/8/2018 9:56:44 PM> EasyJTAG API ver. 2100
12/8/2018 9:56:44 PM> Setting IO Levels to 2.8V
12/8/2018 9:56:44 PM> Setting frequence to 18 Mhz
12/8/2018 9:56:44 PM> EasyJTAG Box Serial =
12/8/2018 9:56:44 PM> EasyJTAG Box Firmware = 2.30
12/8/2018 9:56:45 PM> Setting interface to EasyJtag2/ISP
12/8/2018 9:56:45 PM> Setting bus width to 1 Bit
12/8/2018 9:56:45 PM> Setting frequence to 18 Mhz
12/8/2018 9:56:45 PM> CMD Pullup Level: 2094 mV
12/8/2018 9:56:45 PM> CMD Active Level: 2667 mV
12/8/2018 9:56:45 PM> eMMC Init returned = 0
12/8/2018 9:56:45 PM> EMMC Device Information :
12/8/2018 9:56:45 PM> EMMC CID: 150100434A4E423452103FE9EAE91449
12/8/2018 9:56:45 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
12/8/2018 9:56:45 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: CJNB4R , HEX: 434A4E423452 , S/N: 3FE9EAE9 , rev. 0x10
12/8/2018 9:56:45 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2017
12/8/2018 9:56:45 PM>    EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
12/8/2018 9:56:45 PM>    EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/8/2018 9:56:45 PM>    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
12/8/2018 9:56:45 PM> EMMC Permanent Write Protection: No
12/8/2018 9:56:45 PM> EMMC Temporary Write Protection: No
12/8/2018 9:56:45 PM> Extended CSD Information :
12/8/2018 9:56:45 PM> Extended CSD rev: 1.8 (MMC 5.1)
12/8/2018 9:56:45 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
12/8/2018 9:56:45 PM> Boot Bus Config: 0x00 , width 1bit
12/8/2018 9:56:45 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
12/8/2018 9:56:45 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/8/2018 9:56:45 PM> Device supports partitioning features
12/8/2018 9:56:45 PM> Device can have enhanced technological features in partitions and user data area
12/8/2018 9:56:45 PM> Device can have extended partitions attribute
12/8/2018 9:56:45 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/8/2018 9:56:45 PM> Backup saved: CJNB4R_3FE9EAE9_20181208_215645.extcsd
12/8/2018 9:56:45 PM> EMMC Init completed.
12/8/2018 9:56:45 PM> Operation: Write by vendor (Samsung)
12/8/2018 9:56:45 PM> Partition name: SBL1
12/8/2018 9:56:45 PM> Filename: sbl1.mbn.lz4 , Offset: 000000400000 , filesize: 289789 bytes
12/8/2018 9:56:45 PM> eMMC switching to ROM1
12/8/2018 9:56:45 PM> Writing partition...
12/8/2018 9:56:46 PM> Done writing partition. Write speed: 892.30 KB/s
12/8/2018 9:56:46 PM> Partition name: ABOOT
12/8/2018 9:56:46 PM> Filename: aboot.mbn.lz4 , Offset: 000000510000 , filesize: 1032515 bytes
12/8/2018 9:56:46 PM> eMMC switching to ROM1
12/8/2018 9:56:46 PM> Writing partition...
12/8/2018 9:56:47 PM> Done writing partition. Write speed: 1024.28 KB/s
12/8/2018 9:56:47 PM> Partition name: RPM
12/8/2018 9:56:47 PM> Filename: rpm.mbn.lz4 , Offset: 000000710000 , filesize: 124536 bytes
12/8/2018 9:56:47 PM> eMMC switching to ROM1
12/8/2018 9:56:47 PM> Writing partition...
12/8/2018 9:56:47 PM> Done writing partition. Write speed: 1357.51 KB/s
12/8/2018 9:56:47 PM> Partition name: TZ
12/8/2018 9:56:47 PM> Filename: tz.mbn.lz4 , Offset: 000000790000 , filesize: 586337 bytes
12/8/2018 9:56:47 PM> Done writing partition. Write speed: 1882.56 KB/s
12/8/2018 9:56:47 PM> Partition name: SEC
12/8/2018 9:56:47 PM> Filename: sec.dat.lz4 , Offset: 000000D10000 , filesize: 579 bytes
12/8/2018 9:56:48 PM> Done writing partition. Write speed: 20.21 KB/s
12/8/2018 9:56:48 PM> Partition name: KEYMASTER
12/8/2018 9:56:48 PM> Filename: keymaster.mbn.lz4 , Offset: 000000D14000 , filesize: 161077 bytes
12/8/2018 9:56:48 PM> eMMC switching to ROM1
12/8/2018 9:56:48 PM> Writing partition...
12/8/2018 9:56:48 PM> Done writing partition. Write speed: 1549.18 KB/s
12/8/2018 9:56:48 PM> Partition name: CMNLIB
12/8/2018 9:56:48 PM> Filename: cmnlib.mbn.lz4 , Offset: 000000D94000 , filesize: 167357 bytes
12/8/2018 9:56:48 PM> Done writing partition. Write speed: 1397.26 KB/s
12/8/2018 9:56:48 PM> Partition name: LKSECAPP
12/8/2018 9:56:48 PM> Filename: lksecapp.mbn.lz4 , Offset: 000000DD4000 , filesize: 100833 bytes
12/8/2018 9:56:48 PM> Done writing partition. Write speed: 1216.85 KB/s
12/8/2018 9:56:48 PM> Partition name: APDP
12/8/2018 9:56:48 PM> Filename: apdp.mbn.lz4 , Offset: 000000E54000 , filesize: 11626 bytes
12/8/2018 9:56:48 PM> Done writing partition. Write speed: 248.06 KB/s
12/8/2018 9:56:48 PM> Partition name: MSADP
12/8/2018 9:56:48 PM> Filename: msadp.mbn.lz4 , Offset: 000000E74000 , filesize: 11624 bytes
12/8/2018 9:56:49 PM> Writing partition...
12/8/2018 9:56:49 PM> Done writing partition. Write speed: 245.74 KB/s
12/8/2018 9:56:49 PM> Partition name: DEVCFG
12/8/2018 9:56:49 PM> Filename: devcfg.mbn.lz4 , Offset: 00000AE88000 , filesize: 23646 bytes
12/8/2018 9:56:49 PM> eMMC switching to ROM1
12/8/2018 9:56:49 PM> Done writing partition. Write speed: 460.47 KB/s
12/8/2018 9:56:49 PM> Partition name: APNHLOS
12/8/2018 9:56:49 PM> Filename: NON-HLOS.bin.lz4 , Offset: 000012700000 , filesize: 10769345 bytes
12/8/2018 9:56:54 PM> Done writing partition. Write speed: 2017.40 KB/s
12/8/2018 9:56:55 PM> Partition USERDATA : formatting as EXT4. Please wait ...
12/8/2018 9:57:06 PM> Formatting completed
12/8/2018 9:57:06 PM> Check BootConfig for the selected vendor
12/8/2018 9:57:06 PM> All done   time: [00:00:21:325]
12/8/2018 9:57:15 PM> Looking for EasyJTAG box...
12/8/2018 9:57:15 PM> EasyJTAG API ver. 2100
12/8/2018 9:57:15 PM> Setting IO Levels to 2.8V
12/8/2018 9:57:15 PM> Setting frequence to 18 Mhz
12/8/2018 9:57:15 PM> EasyJTAG Box Serial =
12/8/2018 9:57:15 PM> EasyJTAG Box Firmware = 2.30
12/8/2018 9:57:15 PM> Setting interface to EasyJtag2/ISP
12/8/2018 9:57:15 PM> Setting bus width to 1 Bit
12/8/2018 9:57:15 PM> CMD Pullup Level: 2093 mV
12/8/2018 9:57:15 PM> CMD Active Level: 2668 mV
12/8/2018 9:57:16 PM> eMMC Init returned = 0
12/8/2018 9:57:16 PM> EMMC Device Information :
12/8/2018 9:57:16 PM> EMMC CID: 150100434A4E423452103FE9EAE91449
12/8/2018 9:57:16 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
12/8/2018 9:57:16 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: CJNB4R , HEX: 434A4E423452 , S/N: 3FE9EAE9 , rev. 0x10
12/8/2018 9:57:16 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2017
12/8/2018 9:57:16 PM>    EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
12/8/2018 9:57:16 PM>    EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
12/8/2018 9:57:16 PM>    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
12/8/2018 9:57:16 PM> EMMC Permanent Write Protection: No
12/8/2018 9:57:16 PM> EMMC Temporary Write Protection: No
12/8/2018 9:57:16 PM> Extended CSD Information :
12/8/2018 9:57:16 PM> Extended CSD rev: 1.8 (MMC 5.1)
12/8/2018 9:57:16 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
12/8/2018 9:57:16 PM> Boot Bus Config: 0x00 , width 1bit
12/8/2018 9:57:16 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
12/8/2018 9:57:16 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
12/8/2018 9:57:16 PM> Device supports partitioning features
12/8/2018 9:57:16 PM> Device can have enhanced technological features in partitions and user data area
12/8/2018 9:57:16 PM> Device can have extended partitions attribute
12/8/2018 9:57:16 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
12/8/2018 9:57:16 PM> Backup saved: CJNB4R_3FE9EAE9_20181208_215716.extcsd
12/8/2018 9:57:16 PM> EMMC Init completed.
12/8/2018 9:57:16 PM> Scanning soft partitions
12/8/2018 9:57:16 PM> GPT header is found and is valid
12/8/2018 9:57:16 PM> Partition: sbl1, [000000400000 - 000000480000], size: 000000080000 (512. KB)
12/8/2018 9:57:16 PM> Partition: sbl1bak, [000000480000 - 000000500000], size: 000000080000 (512. KB)
12/8/2018 9:57:16 PM> Partition: ddr, [000000500000 - 000000508000], size: 000000008000 (32.0 KB)
12/8/2018 9:57:16 PM> Partition: limits, [000000508000 - 000000510000], size: 000000008000 (32.0 KB)
12/8/2018 9:57:16 PM> Partition: aboot, [000000510000 - 000000710000], size: 000000200000 (2.00 MB)
12/8/2018 9:57:16 PM> Partition: rpm, [000000710000 - 000000790000], size: 000000080000 (512. KB)
12/8/2018 9:57:16 PM> Partition: tz, [000000790000 - 000000990000], size: 000000200000 (2.00 MB)
12/8/2018 9:57:16 PM> Partition: hyp, [000000990000 - 000000A10000], size: 000000080000 (512. KB)
12/8/2018 9:57:16 PM> Partition: fsg, [000000A10000 - 000000D10000], size: 000000300000 (3.00 MB)
12/8/2018 9:57:16 PM> Partition: sec, [000000D10000 - 000000D14000], size: 000000004000 (16.0 KB)
12/8/2018 9:57:16 PM> Partition: keymaster, [000000D14000 - 000000D94000], size: 000000080000 (512. KB)
12/8/2018 9:57:16 PM> Partition: cmnlib, [000000D94000 - 000000DD4000], size: 000000040000 (256. KB)
12/8/2018 9:57:16 PM> Partition: lksecapp, [000000DD4000 - 000000E54000], size: 000000080000 (512. KB)
12/8/2018 9:57:16 PM> Partition: apdp, [000000E54000 - 000000E74000], size: 000000020000 (128. KB)
12/8/2018 9:57:16 PM> Partition: msadp, [000000E74000 - 000000E94000], size: 000000020000 (128. KB)
12/8/2018 9:57:16 PM> Partition: pad, [000000E94000 - 000001800000], size: 00000096C000 (9.42 MB)
12/8/2018 9:57:16 PM> Partition: modemst1, [000001800000 - 000001B00000], size: 000000300000 (3.00 MB)
12/8/2018 9:57:16 PM> Partition: modemst2, [000001B00000 - 000001E00000], size: 000000300000 (3.00 MB)
12/8/2018 9:57:16 PM> Partition: param, [000001E00000 - 000002800000], size: 000000A00000 (10.0 MB)
12/8/2018 9:57:16 PM> Partition: efs, [000002800000 - 000003600000], size: 000000E00000 (14.0 MB)
12/8/2018 9:57:16 PM> Partition: boot, [000003600000 - 000005600000], size: 000002000000 (32.0 MB)
12/8/2018 9:57:16 PM> Partition: recovery, [000005600000 - 000007600000], size: 000002000000 (32.0 MB)
12/8/2018 9:57:16 PM> Partition: bota, [000007600000 - 000007D00000], size: 000000700000 (7.00 MB)
12/8/2018 9:57:16 PM> Partition: fota, [000007D00000 - 000008200400], size: 000000500400 (5.00 MB)
12/8/2018 9:57:16 PM> Partition: backup, [000008200400 - 0000087FE000], size: 0000005FDC00 (5.99 MB)
12/8/2018 9:57:16 PM> Partition: fsc, [0000087FE000 - 000008AFE000], size: 000000300000 (3.00 MB)
12/8/2018 9:57:16 PM> Partition: ssd, [000008AFE000 - 000008B00000], size: 000000002000 (8.00 KB)
12/8/2018 9:57:16 PM> Partition: persist, [000008B00000 - 00000AB00000], size: 000002000000 (32.0 MB)
12/8/2018 9:57:16 PM> Partition: persistent, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB)
12/8/2018 9:57:16 PM> Partition: steady, [00000AC00000 - 00000AD00000], size: 000000100000 (1.00 MB)
12/8/2018 9:57:16 PM> Partition: keystore, [00000AD00000 - 00000AD80000], size: 000000080000 (512. KB)
12/8/2018 9:57:16 PM> Partition: config, [00000AD80000 - 00000AD88000], size: 000000008000 (32.0 KB)
12/8/2018 9:57:16 PM> Partition: mota, [00000AD88000 - 00000AE88000], size: 000000100000 (1.00 MB)
12/8/2018 9:57:16 PM> Partition: devcfg, [00000AE88000 - 00000AEC8000], size: 000000040000 (256. KB)
12/8/2018 9:57:16 PM> Partition: dsp, [00000AEC8000 - 00000BEC8000], size: 000001000000 (16.0 MB)
12/8/2018 9:57:16 PM> Partition: modem, [00000BEC8000 - 000012700000], size: 000006838000 (104. MB)
12/8/2018 9:57:16 PM> Partition: apnhlos, [000012700000 - 000014F00000], size: 000002800000 (40.0 MB)
12/8/2018 9:57:16 PM> Partition: persdata, [000014F00000 - 000015800000], size: 000000900000 (9.00 MB)
12/8/2018 9:57:16 PM> Partition: system, [000015800000 - 000134800000], size: 00011F000000 (4.48 GB)
12/8/2018 9:57:16 PM> Partition: cache, [000134800000 - 000141000000], size: 00000C800000 (200. MB)
12/8/2018 9:57:16 PM> Partition: hidden, [000141000000 - 000147400000], size: 000006400000 (100. MB)
12/8/2018 9:57:16 PM> Partition: userdata, [000147400000 - 000E8F7FB000], size: 000D483FB000 (53.1 GB)
12/8/2018 9:57:16 PM> GPT header successfully parsed
12/8/2018 9:57:16 PM> Get firmware version
12/8/2018 9:57:17 PM> Brand = samsung
12/8/2018 9:57:17 PM> Manufacturer = samsung
12/8/2018 9:57:17 PM> Model = SM-C900F
12/8/2018 9:57:17 PM> Phone platform = msm8952
12/8/2018 9:57:17 PM> CPU Abi = arm64-v8a
12/8/2018 9:57:17 PM> Android release = 8.0.0
12/8/2018 9:57:17 PM> Firmware version = R16NW.C900FDDU1CRJ4
12/8/2018 9:57:17 PM> Firmware date = Thu Oct 25 15:42:44 KST 2018
Old 12-08-2018, 18:15   #27 (permalink)
Member: 13148
Thanks Meter: 1,235
lz4 unpack will be added at next version
upload to some host file
BL_C900FDDU1CRJ4_CL14339333_QB20329317_REV00_user_ low_ship_MULTI_CERT.tar.md5
and I unpack it for you
The Following User Says Thank You to layder For This Useful Post:
Old 12-08-2018, 18:45   #28 (permalink)
Member: 2636476
Thanks Meter: 50
Sir i already unpack with winzip then select one by one files and write then set goes to 9008 port
What to do now
Old 12-08-2018, 20:48   #29 (permalink)
Member: 13148
Thanks Meter: 1,235
unpack files and add it by duble-click on lines
https://mega.nz/#!OYhi3CzC!U0IdupGLD...3Gy89mMiPQe5wI
The Following 3 Users Say Thank You to layder For This Useful Post:
Old 12-10-2018, 12:33   #30 (permalink)
Member: 2636476
Thanks Meter: 50
back to life thank u sir
Opening file: C9LTE_SWA_OPEN_HIDDEN100M.pit
Entry count: 46
CMD Pullup Level: 2098 mV
Backup saved: CJNB4R_3FE9EAE9_20181210_175625.extcsd
Filename: sbl1.mbn , Offset: 000000400000 , filesize: 404896 bytes
Done writing partition. Write speed: 867.99 KB/s
Filename: aboot.mbn , Offset: 000000510000 , filesize: 1470712 bytes
Done writing partition. Write speed: 1052.90 KB/s
Partition name: RPM
Filename: rpm.mbn , Offset: 000000710000 , filesize: 201112 bytes
Done writing partition. Write speed: 1612.67 KB/s
Partition name: TZ
Filename: tz.mbn , Offset: 000000790000 , filesize: 1523200 bytes
Done writing partition. Write speed: 1927.05 KB/s
Partition name: SEC
Filename: sec.dat , Offset: 000000D10000 , filesize: 692 bytes
Done writing partition. Write speed: 24.78 KB/s
Filename: keymaster.mbn , Offset: 000000D14000 , filesize: 259032 bytes
Done writing partition. Write speed: 1626.80 KB/s
Filename: cmnlib.mbn , Offset: 000000D94000 , filesize: 234304 bytes
Done writing partition. Write speed: 1562.19 KB/s
Filename: lksecapp.mbn , Offset: 000000DD4000 , filesize: 279160 bytes
Done writing partition. Write speed: 1670.15 KB/s
Filename: apdp.mbn , Offset: 000000E54000 , filesize: 46272 bytes
Done writing partition. Write speed: 916.99 KB/s
Filename: msadp.mbn , Offset: 000000E74000 , filesize: 46272 bytes
Done writing partition. Write speed: 916.49 KB/s
Filename: devcfg.mbn , Offset: 00000AE88000 , filesize: 70652 bytes
Done writing partition. Write speed: 1204.77 KB/s
Filename: NON-HLOS.bin , Offset: 000012700000 , filesize: 24942336 bytes
Done writing partition. Write speed: 2020.45 KB/s
All done   time: [00:00:17:538]
CMD Pullup Level: 2097 mV
Backup saved: CJNB4R_3FE9EAE9_20181210_175649.extcsd
Brand = samsung
Model = SM-C900F
CPU Abi = arm64-v8a
Page generated in 0.56637 seconds with 7 queries
