08-03-2015, 08:27 | #1 (permalink) |
Freak Poster Join Date: May 2011 Location: indonesia
Member: 1586473 Status: Offline Thanks Meter: 19 | ask: replace emmc n7000 from n7100 is it compatible? i have backup the n7000 emmc(extcsd,boot1,2 and userdata512mb) then i format the n7100 emmc, write extcsd with n7000 extcsd, also boot1,2 and userdata from the n7000 emmc backup but the phone is not powered on with the old n7000 emmc,the phone is on what step i do wrong? |
08-03-2015, 19:34 | #5 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | Quote:
and write after flash with odin.. i replaced many time .also s3 not2 emmc work n8000,n5100.sm-t210,t111,t310,i9500,s2, all these model i am tested....... | |
The Following User Says Thank You to drjaved_akhter For This Useful Post: |
08-03-2015, 20:36 | #6 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 931282 Status: Offline Thanks Meter: 19 | if you change the size of the boot, get downlad but the flash mode Odin will get only stopping for recovery, you do not get the full work, you need to have a new EMMC which never before has there been programmed. |
08-04-2015, 02:42 | #9 (permalink) |
Member: 1586473 Status: Offline Thanks Meter: 19 | emmc is new(not used..) this phone is not recognized by jtag even if with the old emmc (maybe broken jtag lines) i have changed the boot size with the same size from the old emmc/2mb but still not worked, don't know why the phone is taken back by customer... the full story: phone dead(jtag not detected, direct emmc says the emmc is dead) change used n7000 emmc (phone powered on normal with 0049 imei,repair imei,done) i have one new n7100 emmc and i want to test it so i format it then write the n7000 emmc backup ext,boot,and usrdata(phone dead) replace back the used n7000 emmc(phone is alive back,customer take it home...) Last edited by mamakemadena; 08-04-2015 at 02:51. |
08-04-2015, 20:20 | #11 (permalink) |
Member: 931282 Status: Offline Thanks Meter: 19 | there is no difference, sometimes at N7000 increased in boot partition because it was damaged up to 2 mb and upload a file of 512 mb and it was ok, so not a problem boot size, but EMMC is a problem |
08-05-2015, 05:45 | #12 (permalink) |
Member: 1586473 Status: Offline Thanks Meter: 19 | i have tried to set boot 512kb before. (it's not worked..) i'll try this emmc on another phone next time to make sure if it's damaged or not thanx all... |
04-01-2016, 18:21 | #15 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: Vice City
Member: 1436243 Status: Offline Thanks Meter: 99 | Quote:
- before dealing with eMMC you must now the capacity,density etc example: KMVYL000LM-B503 is 16GB capacity with 1GB of RAM -->eMCP KMVTU000LM-B503 is 16GB capacity with 1GB of RAM -->eMCP it is same ,and sure compatible, but better always factory erase,and upgrade firmware to the new eMMC/eMCP ic - check partition size, ROM1 ROM 2, make sure is same as n7000 partition resize it if necesary - if the phone not powering ON, after change then maybe RAM inside eMCP is dead or weak, if you sure anything is okey then the phone must can enter odin mode BTW, why you change eMCP ic? if with old n7000 eMCP the phone is ON??? | |
The Following 2 Users Say Thank You to mifluvcute For This Useful Post: |
