04-12-2017, 17:39 | #1 (permalink) |
Junior Member Join Date: Jun 2007
Member: 532180 Status: Offline Thanks Meter: 33 | samsung i9192 unbrick help samsung i9192 emmc chenge 8gb samsung and boot1,boot 2 and userdata complet programm but phone is dead no dounlode mode (qualcomm hs-usb qdloader 9008) help me ---------- eMMC Device Information ---------- EMMC CID : 15010038574D423352003C545B173150 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 03/2014 Rev.0x0 EMMC NAME: 8WMB3R , S/N: 1012161303 EMMC NAME (HEX): 38574D42335200 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 8WMB3R_1012161303_20170412_2129.extcsd Searching for partition tables... Detected GPT over MBR... Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Warning: Entries Count = 128 MMCBLK0P0 (MODEM) Range: [0X400000,0X3FFFE00] ,Len: 3C00000 MMCBLK0P1 (SBL1) Range: [0X4000000,0X401FE00] ,Len: 20000 MMCBLK0P2 (SBL2) Range: [0X4020000,0X405FE00] ,Len: 40000 MMCBLK0P3 (SBL3) Range: [0X4060000,0X40DFE00] ,Len: 80000 MMCBLK0P4 (ABOOT) Range: [0X40E0000,0X42DFE00] ,Len: 200000 MMCBLK0P5 (RPM) Range: [0X42E0000,0X435FE00] ,Len: 80000 MMCBLK0P6 (TZ) Range: [0X4360000,0X43DFE00] ,Len: 80000 MMCBLK0P7 (PAD) Range: [0X43E0000,0X505FE00] ,Len: C80000 MMCBLK0P8 (PARAM) Range: [0X5060000,0X585FE00] ,Len: 800000 MMCBLK0P9 (EFS) Range: [0X5860000,0X65FFE00] ,Len: DA0000 MMCBLK0P10 (MODEMST1) Range: [0X6600000,0X68FFE00] ,Len: 300000 MMCBLK0P11 (MODEMST2) Range: [0X6900000,0X6BFFE00] ,Len: 300000 MMCBLK0P12 (BOOT) Range: [0X6C00000,0X75FFE00] ,Len: A00000 MMCBLK0P13 (RECOVERY) Range: [0X7600000,0X7FFFE00] ,Len: A00000 MMCBLK0P14 (FOTA) Range: [0X8000000,0X89FFE00] ,Len: A00000 MMCBLK0P15 (BACKUP) Range: [0X8A00000,0X90FDE00] ,Len: 6FE000 MMCBLK0P16 (FSG) Range: [0X90FE000,0X93FDE00] ,Len: 300000 MMCBLK0P17 (SSD) Range: [0X93FE000,0X93FFE00] ,Len: 2000 MMCBLK0P18 (PERSIST) Range: [0X9400000,0X9BFFE00] ,Len: 800000 MMCBLK0P19 (PERSDATA) Range: [0X9C00000,0XA7FFE00] ,Len: C00000 MMCBLK0P20 (SYSTEM) Range: [0XA800000,0X683FFE00] ,Len: 5DC00000 MMCBLK0P21 (CACHE) Range: [0X68400000,0X74BFFE00] ,Len: C800000 MMCBLK0P22 (HIDDEN) Range: [0X74C00000,0X76FFFE00] ,Len: 2400000 MMCBLK0P23 (USERDATA) Range: [0X77000000,0X1D1FFBC00] ,Len: 15AFFBE00 Done...Presets has been updated... Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:1722 mV CMD Active Level:1794 mV Box IO Level:1850 mV CLK Rate:14000 khz Reading S.M.A.R.T S.M.A.R.T Ver. 0 , Card Error mode : Normal Super Block size : 0x00400000 (4194304 bytes) Super Page size : 0x00004000 (16384 bytes) Optimal Write size : 0x00004000 (16384 bytes) Read Reclaim count : 0 Optimal TRIM size : 0x00001000 (4096 bytes) Total Number of banks : 1 Initial bad blocks per bank : 3,0,0,0 Runtime bad blocks per bank : 0,0,0,0 Reserved blocks left per bank : 49,0,0,0 All Erase counts (min,avg,max): 0,0,48 SLC Erase counts (min,avg,max): 1,11,48 MLC Erase counts (min,avg,max): 0,1,2 S.M.A.R.T Report Done. something missing pls help me |
04-14-2017, 22:41 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Just write latest bootloader.tar by easy plus make sure your bootlader have full bl specially SBL1,because some TAR file have only update bl |
