Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 11-01-2018, 16:05   #1 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 109
Exclamation
I want program 3GMR emmc for Asus FE170CG_K012 by easy dump file
easy give me bellow log:
---------- eMMC Device Information ----------
eMMC CID : 90014A48384732640404007BC21280E4
eMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 08/2013  Rev.0x4
eMMC NAME: H8G2d  , S/N:    8110610
eMMC NAME (HEX): 483847326420
EMMC ROM1 (Main User Data)   Capacity: 7456 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x06 , width 8bits  , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G2d _   8110610_20181101_1704.extcsd
Caution: invalid backup GPT header, but valid main header!
Warning! Main and backup partition tables differ!n
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
 GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB
Soft (Partitioned) Disk/Image size: E8BFBC sectors 7.3 GiB
Logical sector size: 0x200  bytes
Disk identifier (GUID): 096FC29F-29A3-CAA8-AE3B-686E70C5E401
First usable sector: 34
Last usable sector: 15253470
Found Data areas (firmware parts) count is: 10
Partition info successfully found
P0 (RESERVED) [0x4400 0x2f00000] Size: 47.0MB
P1 (PANIC) [0x2f04400 0x800000] Size: 8.0MB
P2 (FACTORY) [0x3704400 0x200000] Size: 2.0MB
P3 (CONFIG) [0x3904400 0x1500000] Size: 21.0MB
P4 (GAUGE) [0x4e04400 0x100000] Size: 1.0MB
P5 (FIRMWARE) [0x4f04400 0x1500000] Size: 21.0MB
P6 (ADF) [0x6404400 0x2000000] Size: 32.0MB
P7 (CACHE) [0x8404400 0x1a200000] Size: 418.0MB
P8 (SYSTEM) [0x22604400 0x48800000] Size: 1.132GB
P9 (DATA) [0x6ae04400 0x1661fbc00] Size: 5.594GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0022604400 (1.132GB)
Build ID:  KVT49L
Display Build ID:  KVT49L.WW_fonepad-11.2.3.33-20150302 release-keys
Release ID:  4.4.2
Device Model:  K012
Device Name:  WW_fonepad
Architecture ABI:  x86
Device manufacturer:  asus
Device Platform:  clovertrail
Product ID:  K012
Build Description:  WW_fonepad-user 4.4.2 KVT49L WW_fonepad-11.2.3.33-20150302 release-keys
Done.
How can I fix it by easy jtag?
And how config this emmc for "Asus FE170CG_K012"
this info is from worked device:
Setting frequence to 21 Mhz
CMD Pullup Level: 2103 mV
CMD Active Level: 2165 mV
EMMC Device Information :
EMMC CID: 90014A483847326404050114C1FF4150
EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2
EMMC Manufacture : SKHYNIX , EMMC NAME: H8G2d , HEX: 483847326400 , S/N: 0114C1FF , rev. 0x05
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2014
   EMMC ROM 1 (Main User Data) Capacity: 7448 MB (0001D1800000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
   EMMC GP1 (GP Partition 1) Capacity: 8 MB   , WR_REL (000000800000)
Extended CSD Information :
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Boot Bus Config: 0x06 , width 8bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H8G2d_0114C1FF_20181102_130417.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: reserved, [000000004400 - 000002F04400], size: 000002F00000 (47.0 MB)
Partition: panic, [000002F04400 - 000003704400], size: 000000800000 (8.00 MB)
Partition: factory, [000003704400 - 000003904400], size: 000000200000 (2.00 MB)
Partition: config, [000003904400 - 000004E04400], size: 000001500000 (21.0 MB)
Partition: gauge, [000004E04400 - 000004F04400], size: 000000100000 (1.00 MB)
Partition: firmware, [000004F04400 - 000006404400], size: 000001500000 (21.0 MB)
Partition: ADF, [000006404400 - 000008404400], size: 000002000000 (32.0 MB)
Partition: cache, [000008404400 - 000022604400], size: 00001A200000 (418. MB)
Partition: system, [000022604400 - 00006AE04400], size: 000048800000 (1.13 GB)
Partition: data, [00006AE04400 - 0001D1000000], size: 0001661FBC00 (5.60 GB)
GPT header successfully parsed
Get firmware version
Brand = asus
Manufacturer = asus
Model = K012
Phone platform = clovertrail
CPU Abi = x86
Android release = 4.3
Firmware version = JSS15Q.WW_fonepad-10.32.1.31.2-20140721,release-keys
Firmware date = Mon Jul 21 17:01:05 CST 2014
how can I config new emmc like as this one?
iI try to create GP1 partion by easy plus and give me bellow log:
Operation: Changing GP sizes (final write) ...
GP1 size: 8 MB , WR_REL: 1 , ENH 1
GP2 size: 0 MB , WR_REL: 1 , ENH 0
GP3 size: 0 MB , WR_REL: 1 , ENH 0
GP4 size: 0 MB , WR_REL: 1 , ENH 0
HW_PART error. Reason: Card already partitioned
I try to write GP1 dump and give me this log:
Operation: Write Dump
The value of the start address is greater than the size of GP1
how can I fix it?
this log is for worked emmc for write GP1 :
Writing to: GP1 , start: 0x000000000000 , size: 0x000000800000
Input file: C:\Users\Mehregan\Desktop\EMMC_H8G2d_GP1__000000000000_000000800000.bin
eMMC switching to GP1
Writing partition...
Done writing partition. Write speed: 240.53 KB/s
All done   time: [00:00:34:429]
But give error for that emmc!
Old 11-02-2018, 12:55   #2 (permalink)
Member: 13148
Thanks Meter: 676
GP1 partition can create at eMMC with [PARTITION_SETTING_COMPLETED]=0x00.
It's one time program (OTP) bit
After GPx configured, [PARTITION_SETTING_COMPLETED] bit is set to 0x01
Use new eMMC with [PARTITION_SETTING_COMPLETED]=0x00 to restore you device
The Following User Says Thank You to layder For This Useful Post:
Old 11-02-2018, 13:19   #3 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 109
thanks so much for replay
But in the first log :
 GPT: damaged
Build ID:  KVT49L
Release ID:  4.4.2
Device Model:  K012
Product ID:  K012
Done.
this log have "Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00"
Its mean I can change GPx for one time because partion bit is "0x00"
and when I want create GP1 give me:
and when I want write GP1 dump give me :
How can I write GP1 dump on this emmc?
Old 11-02-2018, 13:41   #4 (permalink)
Member: 13148
Thanks Meter: 676
You can't write GP1 to missing GP1
post full logs of you operations as file from Log folder of program to analize it
Old 11-02-2018, 13:43   #5 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 109
I'm at home
I'll Send it tommarow
Thanks
this is log from scan,write full dump,create GP1 and write GP1 dump:
http://www.mediafire.com/file/lll1gn1cpfgeze3/eMMC_Tool_Log_1.5.2.0_20181103_095341.zip/filehttps://www.mediafire.com/file/lll1gn1cpfgeze3/eMMC_Tool_Log_1.5.2.0_20181103_095341.zip/filehttps://www.mediafire.com/file/lll1gn1cpfgeze3/eMMC_Tool_Log_1.5.2.0_20181103_095341.zip/filehttps://www.mediafire.com/file/lll1gn1cpfgeze3/eMMC_Tool_Log_1.5.2.0_20181103_095341.zip/file
Old 11-03-2018, 10:40   #6 (permalink)
Member: 13148
Thanks Meter: 676
I see "Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01" at begin of log
Post previous log, where are "Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00"
Old 11-03-2018, 11:55   #7 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 109
yes you are right
So now how can see GPx partions size and check them?
Old 11-03-2018, 13:08   #8 (permalink)
Member: 13148
Thanks Meter: 676
yes you are right
If GP partition found - info adout it found at detect
Old 11-03-2018, 21:48   #9 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 360
today k012 done with 16 gb emmc
The Following User Says Thank You to ali_imran For This Useful Post:
Old 11-04-2018, 07:40   #10 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 109
can you share his emmc info?
Old 11-05-2018, 05:16   #11 (permalink)
Member: 1368525
Thanks Meter: 22
can you explain step by step ebout gp partition??
Sent from my Nokia 2 using Tapatalk
Old 11-06-2018, 07:24   #12 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 360
EMMC ROM 1 7448 MB (0001D1800000)
EMMC ROM 2/3 4096 KB (000000400000)
EMMC RPMB 4096 KB (000000400000)
EMMC GP1 for kmvtu000lm-b503 40mb
use kmvtu000lm-b503
1st format
2nd gpt
3rd write dump
after write dump u can flash via many tool
The Following 3 Users Say Thank You to ali_imran For This Useful Post:
Page generated in 0.41881 seconds with 8 queries
