Easy-Jtag / Easy-Jtag Plus The official support section. You can ask here your question and get answer regarding using Easy-Jtag / Easy-Jtag Plus. |
11-01-2018, 15:05 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Shiraz Iran Age: 37
Member: 1171122 Status: Offline Sonork: 100.1623220 Thanks Meter: 151 | easy give me bellow log: Code: ---------- eMMC Device Information ---------- eMMC CID : 90014A48384732640404007BC21280E4 eMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 08/2013 Rev.0x4 eMMC NAME: H8G2d , S/N: 8110610 eMMC NAME (HEX): 483847326420 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x06 , width 8bits , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H8G2d _ 8110610_20181101_1704.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: E8BFBC sectors 7.3 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 096FC29F-29A3-CAA8-AE3B-686E70C5E401 First usable sector: 34 Last usable sector: 15253470 Found Data areas (firmware parts) count is: 10 Partition info successfully found --------------------------------------------- P0 (RESERVED) [0x4400 0x2f00000] Size: 47.0MB P1 (PANIC) [0x2f04400 0x800000] Size: 8.0MB P2 (FACTORY) [0x3704400 0x200000] Size: 2.0MB P3 (CONFIG) [0x3904400 0x1500000] Size: 21.0MB P4 (GAUGE) [0x4e04400 0x100000] Size: 1.0MB P5 (FIRMWARE) [0x4f04400 0x1500000] Size: 21.0MB P6 (ADF) [0x6404400 0x2000000] Size: 32.0MB P7 (CACHE) [0x8404400 0x1a200000] Size: 418.0MB P8 (SYSTEM) [0x22604400 0x48800000] Size: 1.132GB P9 (DATA) [0x6ae04400 0x1661fbc00] Size: 5.594GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0022604400 (1.132GB) Build ID: KVT49L Display Build ID: KVT49L.WW_fonepad-11.2.3.33-20150302 release-keys Release ID: 4.4.2 Device Model: K012 Device Name: WW_fonepad Architecture ABI: x86 Device manufacturer: asus Device Platform: clovertrail Product ID: K012 Build Description: WW_fonepad-user 4.4.2 KVT49L WW_fonepad-11.2.3.33-20150302 release-keys --------------------------------------------- Done. And how config this emmc for "Asus FE170CG_K012" this info is from worked device: Code: Setting frequence to 21 Mhz CMD Pullup Level: 2103 mV CMD Active Level: 2165 mV EMMC Device Information : EMMC CID: 90014A483847326404050114C1FF4150 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G2d , HEX: 483847326400 , S/N: 0114C1FF , rev. 0x05 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2014 EMMC ROM 1 (Main User Data) Capacity: 7448 MB (0001D1800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC GP1 (GP Partition 1) Capacity: 8 MB , WR_REL (000000800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x06 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G2d_0114C1FF_20181102_130417.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: reserved, [000000004400 - 000002F04400], size: 000002F00000 (47.0 MB) Partition: panic, [000002F04400 - 000003704400], size: 000000800000 (8.00 MB) Partition: factory, [000003704400 - 000003904400], size: 000000200000 (2.00 MB) Partition: config, [000003904400 - 000004E04400], size: 000001500000 (21.0 MB) Partition: gauge, [000004E04400 - 000004F04400], size: 000000100000 (1.00 MB) Partition: firmware, [000004F04400 - 000006404400], size: 000001500000 (21.0 MB) Partition: ADF, [000006404400 - 000008404400], size: 000002000000 (32.0 MB) Partition: cache, [000008404400 - 000022604400], size: 00001A200000 (418. MB) Partition: system, [000022604400 - 00006AE04400], size: 000048800000 (1.13 GB) Partition: data, [00006AE04400 - 0001D1000000], size: 0001661FBC00 (5.60 GB) GPT header successfully parsed Get firmware version Brand = asus Manufacturer = asus Model = K012 Phone platform = clovertrail CPU Abi = x86 Android release = 4.3 Firmware version = JSS15Q.WW_fonepad-10.32.1.31.2-20140721,release-keys Firmware date = Mon Jul 21 17:01:05 CST 2014 iI try to create GP1 partion by easy plus and give me bellow log: Code: Operation: Changing GP sizes (final write) ... GP1 size: 8 MB , WR_REL: 1 , ENH 1 GP2 size: 0 MB , WR_REL: 1 , ENH 0 GP3 size: 0 MB , WR_REL: 1 , ENH 0 GP4 size: 0 MB , WR_REL: 1 , ENH 0 HW_PART error. Reason: Card already partitioned Code: Operation: Write Dump The value of the start address is greater than the size of GP1 this log is for worked emmc for write GP1 : Code: Operation: Write Dump Writing to: GP1 , start: 0x000000000000 , size: 0x000000800000 Input file: C:\Users\Mehregan\Desktop\EMMC_H8G2d_GP1__000000000000_000000800000.bin eMMC switching to GP1 Writing partition... Done writing partition. Write speed: 240.53 KB/s All done time: [00:00:34:429] Last edited by layder; 11-02-2018 at 11:51. Reason: merge posts |
11-02-2018, 11:55 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
It's one time program (OTP) bit After GPx configured, [PARTITION_SETTING_COMPLETED] bit is set to 0x01 Use new eMMC with [PARTITION_SETTING_COMPLETED]=0x00 to restore you device | |
11-02-2018, 12:19 | #3 (permalink) | |
Member: 1171122 Status: Offline Sonork: 100.1623220 Thanks Meter: 151 | Quote:
thanks so much for replay But in the first log : Code: ---------- eMMC Device Information ---------- eMMC CID : 90014A48384732640404007BC21280E4 eMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 08/2013 Rev.0x4 eMMC NAME: H8G2d , S/N: 8110610 eMMC NAME (HEX): 483847326420 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x06 , width 8bits , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H8G2d _ 8110610_20181101_1704.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: E8BFBC sectors 7.3 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 096FC29F-29A3-CAA8-AE3B-686E70C5E401 First usable sector: 34 Last usable sector: 15253470 Found Data areas (firmware parts) count is: 10 Partition info successfully found --------------------------------------------- P0 (RESERVED) [0x4400 0x2f00000] Size: 47.0MB P1 (PANIC) [0x2f04400 0x800000] Size: 8.0MB P2 (FACTORY) [0x3704400 0x200000] Size: 2.0MB P3 (CONFIG) [0x3904400 0x1500000] Size: 21.0MB P4 (GAUGE) [0x4e04400 0x100000] Size: 1.0MB P5 (FIRMWARE) [0x4f04400 0x1500000] Size: 21.0MB P6 (ADF) [0x6404400 0x2000000] Size: 32.0MB P7 (CACHE) [0x8404400 0x1a200000] Size: 418.0MB P8 (SYSTEM) [0x22604400 0x48800000] Size: 1.132GB P9 (DATA) [0x6ae04400 0x1661fbc00] Size: 5.594GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0022604400 (1.132GB) Build ID: KVT49L Display Build ID: KVT49L.WW_fonepad-11.2.3.33-20150302 release-keys Release ID: 4.4.2 Device Model: K012 Device Name: WW_fonepad Architecture ABI: x86 Device manufacturer: asus Device Platform: clovertrail Product ID: K012 Build Description: WW_fonepad-user 4.4.2 KVT49L WW_fonepad-11.2.3.33-20150302 release-keys --------------------------------------------- Done. Its mean I can change GPx for one time because partion bit is "0x00" and when I want create GP1 give me: HW_PART error. Reason: Card already partitioned and when I want write GP1 dump give me : Operation: Write Dump The value of the start address is greater than the size of GP1 How can I write GP1 dump on this emmc? | |
11-02-2018, 12:41 | #4 (permalink) | |
post full logs of you operations as file from Log folder of program to analize it | |
The Following User Says Thank You to layder For This Useful Post: |
11-02-2018, 12:43 | #5 (permalink) | ||
I'll Send it tommarow Thanks Quote:
this is log from scan,write full dump,create GP1 and write GP1 dump: Code: http://www.mediafire.com/file/lll1gn1cpfgeze3/eMMC_Tool_Log_1.5.2.0_20181103_095341.zip/file****************************/file/lll1gn1cpfgeze3/eMMC_Tool_Log_1.5.2.0_20181103_095341.zip/file****************************/file/lll1gn1cpfgeze3/eMMC_Tool_Log_1.5.2.0_20181103_095341.zip/file****************************/file/lll1gn1cpfgeze3/eMMC_Tool_Log_1.5.2.0_20181103_095341.zip/file Last edited by layder; 11-03-2018 at 09:41. Reason: merge posts | ||
11-03-2018, 09:40 | #6 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | I see "Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01" at begin of log Post previous log, where are "Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00" |
11-06-2018, 07:24 | #12 (permalink) |
No Life Poster Join Date: Apr 2007 Location: India
Member: 481609 Status: Offline Sonork: 100.1659889 Thanks Meter: 367 | EMMC ROM 1 7448 MB (0001D1800000) EMMC ROM 2/3 4096 KB (000000400000) EMMC RPMB 4096 KB (000000400000) EMMC GP1 for kmvtu000lm-b503 40mb use kmvtu000lm-b503 1st format 2nd gpt 3rd write dump after write dump u can flash via many tool |
The Following 4 Users Say Thank You to ali_imran For This Useful Post: |
