07-30-2019, 12:21 | #1 (permalink) |
Freak Poster Join Date: Nov 2009 Location: gonbad-iran
Member: 1155715 Status: Offline Sonork: ahmad.derakhshan61 Thanks Meter: 23 | asus z00ld__ze550kl__gpt damaged!!! I have a lot of problem with this device. its micron chip.bga 221.and not found dumps for b412 .jtmc emmc. Got used to micron emmc.and down dumps for it. info at downloaded dumps: Bus: 8 bit (HS SDR 52MHz) Access mode: sector mode Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V) Card/BGA: BGA (Discrete embedded) - High density MMC Manufacturer ID: 0x13 (Micron) Product name: R1J96N (0x52314a39364e), rev: 0x10, serial number: 0x6B26367C Manufacturing date: Aug 2015 CID: 13014E52 314A3936 4E106B26 367C829A CSD: D07F0132 0F5903FF FFFFFFEF 864000AC EXT_CSD revision: 1.7 (MMC v5.0, v5.01) Partition info: Boot1: 4096 KiB Boot2: 4096 KiB RPMB: 4096 KiB User area: 14.68 GiB(15,758,000,128 bytes) Cache size: 64 MiB Hardware reset function: 1 Partition configuration: 0x38 No boot acknowledge is sent (default) User area is enabled for boot Partitioning support: 0x07 Device support partitioning feature Device can have enhanced technological features Device partitioning possible Boot configuration protection: 0x00 Boot bus conditions: 0x00 Boot area write protection: 0x00 Power-on write protection: possible Permanent write protection: possible Lock status: not locked User area write protection: 0x10 Password protection features: enabled Power-on write protection: possible Permanent write protection: not possible Lock status: not locked i wrote it white easy jtag my written logs: Checking security ... Running:Repair extCSD... Z3X EasyJtag Software ver. 3.6.1.2 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:42000 kHz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.7 (MMC 5.0) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x00] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x00] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x03] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x03] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x32] Cache Size [CACHE_SIZE] is 65536 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x01] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00] FFU Argument [FFU_ARG: 0x0000ffff] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x01] i.e. 0% - 10% device life time used _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal Optimal read size [OPTIMAL_READ_SIZE: 0x00] Optimal write size [OPTIMAL_WRITE_SIZE: 0x40] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x07] Device version [DEVICE_VERSION: 0x00 - 0x00] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x11 [FIRMWARE_VERSION[259]]: 0x01 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x07 [FIRMWARE_VERSION[256]]: 0xdf [FIRMWARE_VERSION[255]]: 0x00 [FIRMWARE_VERSION[254]]: 0x82 Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0xff] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x32] Cache Size [CACHE_SIZE] is 65536 KiB Background operations status [BKOPS_STATUS: 0x03] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0xff] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0xff] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0xff] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0xff] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x2c] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x08] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x08] Sleep current (VCCQ) [S_C_VCCQ: 0x09] Sleep/awake timeout [S_A_TIMEOUT: 0x14] Sector Count [SEC_COUNT: 0x01d5a000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x2b] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x2b] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x24] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0xff] [PWR_CL_52_360: 0xff] [PWR_CL_26_195: 0xff] [PWR_CL_52_195: 0xff] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0f] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enabled No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x10 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x15 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0003a9 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00 Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0001 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 ------------Done parsing------------ Writing as extCSD 5.0 Done. Checking security ... Z3X EasyJtag Software ver. 3.6.1.2 Skip loading eMMC Addon Firmware Input file : K:\firmware\down abu\R1J96N_6B26367C\userarea.bin Writing 03AB400000 bytes to 0000000000... ROM1 (USER ROM) Done, time taken: 974 sec. Average Write Speed: 16218 kB/s Checking security ... Z3X EasyJtag Software ver. 3.6.1.2 Skip loading eMMC Addon Firmware Input file : K:\firmware\down abu\R1J96N_6B26367C\boot1.bin Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Done, time taken: 0.602 sec. Average Write Speed: 6887 kB/s Checking security ... Z3X EasyJtag Software ver. 3.6.1.2 Skip loading eMMC Addon Firmware Input file : K:\firmware\R1J96N_6B26367C\boot2.bin Writing 0000400000 bytes to 0000000000 ...ROM3 (BOOT2 ROM) Done, time taken: 0.627 sec. Average Write Speed: 6710 kB/s final check: Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:4bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 13014E52314A39364E103936A9F88289 eMMC CSD : D07F01320F5903FFFFFFFFEF864000AD eMMC Manufacturer ID: 0013 , OEM ID: 014E eMMC Date: 08/2015 Rev.0x10 eMMC NAME: R1J96N , S/N: 959883768 eMMC NAME (HEX): 52314A39364E IC Name: Micron , eMMC_MT29TZZZ5D6YKFAH-125/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 0 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 --------------------------------------------- Backup saved: R1J96N_ 959883768_20190730_1547.extcsd Caution: invalid main GPT header, but valid a backup header! Caution! After loading partitions, the CRC doesn't check out! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FF8 sectors 14.7 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 4 Last usable sector: 30777340 Partition info successfully found Found Data areas (firmware parts) count is: 8 --------------------------------------------- P0 (SBL1) [0x4400 0x140000] Size: 1.250MB P1 (SBL1BAK) [0x144400 0x140000] Size: 1.250MB P2 (RPM) [0x284400 0x80000] Size: 512.0KB P3 (RPMBAK) [0x304400 0x80000] Size: 512.0KB P4 (TZ) [0x384400 0x80000] Size: 512.0KB P5 (TZBAK) [0x404400 0x80000] Size: 512.0KB P6 (HYP) [0x484400 0x80000] Size: 512.0KB P7 (HYPBAK) [0x504400 0x80000] Size: 512.0KB Done. Selected eMMC Interface please help me |
