Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 03-28-2019, 14:18   #1 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 423
Beta software feauture RPMB status question
Respected Easy Jtag Team Need Help Please About This Error
" EMMC RPMB Status: 7, Reason: RPMB Authentication key not yet programmed "
I Tried Many Firmwares But Same Problem
Need Help Please
---------- eMMC Device Information ----------
eMMC CID : 150100525836344D4203F5DEC2883413
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 03/2017  Rev.0x3
eMMC NAME: RX64MB , S/N: 4125016712
eMMC NAME (HEX): 525836344D42
EMMC ROM1 (Main User Data)   Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: RX64MB_4125016712_20190328_1533.extcsd
Partition info successfully found
Found Data areas (firmware parts) count is: 36
P0 (BOOT_PARA) [0x8000 0x100000] Size: 1.0MB
P1 (RECOVERY) [0x108000 0x2000000] Size: 32.0MB
P2 (PARA) [0x2108000 0x80000] Size: 512.0KB
P3 (RESERVE1) [0x2188000 0x200000] Size: 2.0MB
P4 (RESERVE2) [0x2388000 0x1000000] Size: 16.0MB
P5 (RESERVE3) [0x3388000 0x200000] Size: 2.0MB
P6 (RESERVE4) [0x3588000 0x1000000] Size: 16.0MB
P7 (OPPO_CUSTOM) [0x4588000 0x100000] Size: 1.0MB
P8 (EXPDB) [0x4688000 0x1400000] Size: 20.0MB
P9 (FRP) [0x5a88000 0x100000] Size: 1.0MB
P10 (NVCFG) [0x5b88000 0x2000000] Size: 32.0MB
P11 (NVDATA) [0x7b88000 0x4000000] Size: 64.0MB
P12 (METADATA) [0xbb88000 0x2000000] Size: 32.0MB
P13 (PROTECT1) [0xdb88000 0x800000] Size: 8.0MB
P14 (PROTECT2) [0xe388000 0xc78000] Size: 12.468MB
P15 (SECCFG) [0xf000000 0x800000] Size: 8.0MB
P16 (PERSIST) [0xf800000 0x3000000] Size: 48.0MB
P17 (SEC1) [0x12800000 0x200000] Size: 2.0MB
P18 (PROINFO) [0x12a00000 0x300000] Size: 3.0MB
P19 (MD1IMG) [0x12d00000 0x4000000] Size: 64.0MB
P20 (MD1DSP) [0x16d00000 0x1000000] Size: 16.0MB
P21 (SPMFW) [0x17d00000 0x100000] Size: 1.0MB
P22 (SSPM_1) [0x17e00000 0x100000] Size: 1.0MB
P23 (SSPM_2) [0x17f00000 0x100000] Size: 1.0MB
P24 (GZ1) [0x18000000 0x1000000] Size: 16.0MB
P25 (GZ2) [0x19000000 0x1000000] Size: 16.0MB
P26 (NVRAM) [0x1a000000 0x4000000] Size: 64.0MB
P27 (LK) [0x1e000000 0x100000] Size: 1.0MB
P28 (LK2) [0x1e100000 0x100000] Size: 1.0MB
P29 (BOOT) [0x1e200000 0x2000000] Size: 32.0MB
P30 (LOGO) [0x20200000 0x800000] Size: 8.0MB
P31 (TEE1) [0x20a00000 0x500000] Size: 5.0MB
P32 (TEE2) [0x20f00000 0x500000] Size: 5.0MB
P33 (RESERVE_EXP1) [0x21400000 0x400000] Size: 4.0MB
P34 (SYSTEM) [0x21800000 0x158000000] Size: 5.375GB
P35 (RESERVE_EXP2) [0x179800000 0x400000] Size: 4.0MB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0021800000 (5.375GB)
Build ID:  N6F26Q
Release Incremental ID:  1510852707
Release Base ID:  7.1.1
Architecture ABI:  arm64-v8a
Device manufacturer:  OPPO
Device Platform:  mt6763
Build Description:  full_oppo6763_17031-user 7.1.1 N6F26Q 1510852707 release-keys
Device Model:  OPPO CPH1723
Device Name:  CPH1723
Product ID:  oppo6763_17031
Display Build ID:  CPH1723EX_11_A.07_171116
Done.
@NoName®
Respected Sir
Need Help Please
Thanks Anticipation
Old 03-28-2019, 21:15   #2 (permalink)
Member: 13148
Thanks Meter: 881
it's a test version. please wait release
Old 03-28-2019, 21:29   #3 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 423
Thanks For Reply Sir
Sir You Mean Bug In This Version ?
Old 03-28-2019, 22:01   #4 (permalink)
Member: 13148
Thanks Meter: 881
please, wait for release verison
this message is informed, for RPMB area used it or not, but this message is changed at release
RPMB area is need to be non-used for some phones with Exynos CPU, when eMMC is changed (like Samsung N8000 tablets).
Old 03-28-2019, 22:27   #5 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 423
Sir It's Oppo F5 CPH1723
Mediatek MT6763 Helio
I Flashed With Easy Jtag Plus
With Option Vendor MTK Scatter
Old 03-28-2019, 23:32   #6 (permalink)
Member: 13148
Thanks Meter: 881
something does not work for you? create a topic for a specific problem.
This is a test version, and I will not tell you here what and why it displays.
If you do not like this writing, use the latest release.
Old 03-29-2019, 14:43   #7 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 5,986
Question
Need Help Please
Build ID:  N6F26Q
Done.
@NoName®
Respected Sir
Need Help Please
Thanks Anticipation
Hello , did you found word error in log ? I dont see any error in your logs. Where is a error ?
Old 03-29-2019, 16:14   #8 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 423
Sir There Is No Word Error In Log
But That's Seems Something Strange In Log
I Tried Many Firmwares With Easy Jtag Plus
Vendor MTK Scatter Flashing
But Couldn't Alive This Subject
So I Made This Thread To Learn
Need Your Help Please
Thanks Anticipation I
Old 03-29-2019, 21:24   #9 (permalink)
Member: 13148
Thanks Meter: 881
this is debug message for testers.
You are is not a tester. And you do not need to create on the forum questions on the work of test builds, so as not to create confusion for other users of the program
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 03-30-2019, 10:29   #10 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 5,986
There is a many strange thing in log. But try to name threads in a correct wa
We assuming that error is a situation where something not working or
not connection or not starting after operation. If all works and you use
leaked beta software I thing you chould not confuse our users. I will rename
this topic.
Thanks.
The Following User Says Thank You to NoName® For This Useful Post:
Old 03-30-2019, 10:37   #11 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 423
this topic.
Thanks.
Thank You So Much Sir
Sir If There Is Any Other Version Available For Test
I Still Have This Fone In Hands
Old 03-31-2019, 08:58   #12 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 423
@NoName®
Sir I Have A Working/Alive Fone In Hands
Should I Try To Read EMMC With Test Version ?
Old 04-01-2019, 16:48   #13 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 423
Here Is Full Working/Alive Fone Info
@Respected Team
eMMC CID : 150100525836344D4203BFE7AAED24A3
eMMC Date: 02/2017  Rev.0x3
eMMC NAME: RX64MB , S/N: 3219630829
EMMC RPMB Counter: 0
Backup saved: RX64MB_3219630829_20190401_2008.extcsd
Found Data areas (firmware parts) count is: 40
P36 (RESERVE_EXP3) [0x179c00000 0x400000] Size: 4.0MB
P37 (CACHE) [0x17a000000 0x1b000000] Size: 432.0MB
P38 (USERDATA) [0x195000000 0x5b1bfbe00] Size: 22.776GB
P39 (FLASHINFO) [0x746bfbe00 0x1000000] Size: 16.0MB
Build ID:  N6F26Q
Detected USERDATA USERDATA : 0x0195000000 (22.776GB)
Unable to mount SYSTEM , code : 95
Done.
When Try To Read EMMC RPMB
Checking security ...
Z3X EasyJtag Software ver. 3.4.0.9
Skip loading eMMC Addon Firmware
CMD Pullup Level:1793 mV
CMD Active Level:1864 mV
Box IO Level:1800 mV
CLK Rate:126353 kHz
Bus Width:1bit,SDR
Access to current partition forbidden ( size=0 )
Done.
Old 04-01-2019, 23:43   #14 (permalink)
Member: 13148
Thanks Meter: 881
This line in the log is informational.
there is no point in posting logs here, for users on the forum, they don’t carry anything away, and they can be misleading
This forum is not intended to discuss beta software versions.
Old 04-13-2019, 13:40   #15 (permalink)
Member: 13148
Thanks Meter: 881
Read more at thread: RPMB section: what it is and what to do with it.
Page generated in 0.19812 seconds with 7 queries
