-   Easy-Jtag (http://forum.gsmhosting.com/vbb/f672/)
-   -   Blocks Reading Error (0x1B0000400 , 2 , Reason: DATA RCV Timeout Error ) (http://forum.gsmhosting.com/vbb/f672/blocks-reading-error-0x1b0000400-2-reason-data-rcv-timeout-error-2686016/)
LeGrim 09-10-2019 17:35
Can read all the partitions and dump all except for userdata...
Any advice ? i'm using the e-socket, there is the full log
"Z3X EasyJtag Software ver. 3.6.1.4
Loading eMMC GEN2 Firmware... IO: 2800 mV
Initial pull results:
clock: 102mV pin unconnected
command: 108mV pin unconnected
data0: 109mV pin unconnected
data1: 108mV pin unconnected
data2: 109mV pin unconnected
data3: 107mV pin unconnected
data4: 106mV pin unconnected
data5: 107mV pin unconnected
data6: 107mV pin unconnected
data7: 106mV pin unconnected
Box S/N: 1FB1A1A28FBA615C, ,FW Ver.: 02.44
Box IO Level:2800 mV
CLK Rate:42000 kHz
Bus Width:8bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 450100444434303634011317140315D9
eMMC CSD : D00F00328F5903FFFFFFFFEF8A404023
eMMC Manufacturer ID: 0045 , OEM ID: 0100
eMMC Date: 01/2018 Rev.0x1
eMMC NAME: DD4064 , S/N: 320279555
eMMC NAME (HEX): 444434303634
EMMC ROM1 (Main User Data) Capacity: 59640 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 82 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: DD4064_ 320279555_20190910_1831.extcsd
Caution: invalid backup GPT header, but valid main header!
Warning! Main and backup partition tables differ!n
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFDD sectors 58.2 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): F9F21FFF-A8D4-5F0E-9746-594869AEC34E
First usable sector: 34
Last usable sector: 122142719
Partition info successfully found
Found Data areas (firmware parts) count is: 57
P0 (VRL) [0x80000 0x40000] Size: 256.0KB
P1 (VRL_BACKUP) [0xc0000 0x40000] Size: 256.0KB
P2 (FW_LPM3) [0x100000 0x40000] Size: 256.0KB
P3 (FRP) [0x140000 0xc0000] Size: 768.0KB
P4 (FASTBOOT) [0x200000 0x400000] Size: 4.0MB
P5 (MODEMNVM_FACTORY) [0x600000 0x400000] Size: 4.0MB
P6 (NVME) [0xa00000 0x600000] Size: 6.0MB
P7 (OEMINFO) [0x1000000 0x4000000] Size: 64.0MB
P8 (RESERVED3) [0x5000000 0x400000] Size: 4.0MB
P9 (MODEMNVM_BACKUP) [0x5400000 0x400000] Size: 4.0MB
P10 (MODEMNVM_IMG) [0x5800000 0x800000] Size: 8.0MB
P11 (MODEMNVM_SYSTEM) [0x6000000 0x400000] Size: 4.0MB
P12 (SECURE_STORAGE) [0x6400000 0x2000000] Size: 32.0MB
P13 (RESERVED4) [0x8400000 0x200000] Size: 2.0MB
P14 (RESERVED5) [0x8600000 0x200000] Size: 2.0MB
P15 (PERSIST) [0x8800000 0x200000] Size: 2.0MB
P16 (MODEM_SECURE) [0x8a00000 0xe00000] Size: 14.0MB
P17 (MODEM_OM) [0x9800000 0x2000000] Size: 32.0MB
P18 (SPLASH2) [0xb800000 0x4000000] Size: 64.0MB
P19 (MISC) [0xf800000 0x200000] Size: 2.0MB
P20 (MODEMNVM_UPDATE) [0xfa00000 0x1800000] Size: 24.0MB
P21 (RESERVED2) [0x11200000 0x3c00000] Size: 60.0MB
P22 (TEEOS) [0x14e00000 0x400000] Size: 4.0MB
P23 (TRUSTFIRMWARE) [0x15200000 0x200000] Size: 2.0MB
P24 (SENSORHUB) [0x15400000 0x1000000] Size: 16.0MB
P25 (FW_HIFI) [0x16400000 0xc00000] Size: 12.0MB
P26 (ERECOVERY_KERNEL) [0x17000000 0x1800000] Size: 24.0MB
P27 (ERECOVERY_RAMDISK) [0x18800000 0x2000000] Size: 32.0MB
P28 (ERECOVERY_VENDOR) [0x1a800000 0x1000000] Size: 16.0MB
P29 (KERNEL) [0x1b800000 0x1800000] Size: 24.0MB
P30 (RAMDISK) [0x1d000000 0x1000000] Size: 16.0MB
P31 (RECOVERY_RAMDISK) [0x1e000000 0x2000000] Size: 32.0MB
P32 (RECOVERY_VENDOR) [0x20000000 0x1000000] Size: 16.0MB
P33 (DTS) [0x21000000 0x1c00000] Size: 28.0MB
P34 (DTO) [0x22c00000 0x400000] Size: 4.0MB
P35 (MODEM_FW) [0x23000000 0x6000000] Size: 96.0MB
P36 (RECOVERY_VBMETA) [0x29000000 0x100000] Size: 1.0MB
P37 (ERECOVERY_VBMETA) [0x29100000 0x100000] Size: 1.0MB
P38 (RESERVED8) [0x29200000 0x200000] Size: 2.0MB
P39 (DFX) [0x29400000 0x1000000] Size: 16.0MB
P40 (VBMETA) [0x2a400000 0x400000] Size: 4.0MB
P41 (CACHE) [0x2a800000 0x8000000] Size: 128.0MB
P42 (ODM) [0x32800000 0x8000000] Size: 128.0MB
P43 (HISITEST0) [0x3a800000 0x200000] Size: 2.0MB
P44 (HISITEST1) [0x3aa00000 0x200000] Size: 2.0MB
P45 (HISITEST2) [0x3ac00000 0x400000] Size: 4.0MB
P46 (PATCH) [0x3b000000 0x2000000] Size: 32.0MB
P47 (BOOTFAIL_INFO) [0x3d000000 0x200000] Size: 2.0MB
P48 (RRECORD) [0x3d200000 0x1000000] Size: 16.0MB
P49 (RESERVED9) [0x3e200000 0x1600000] Size: 22.0MB
P50 (PRELOAD) [0x3f800000 0x800000] Size: 8.0MB
P51 (SYSTEM) [0x40000000 0x125000000] Size: 4.578GB
P52 (CUST) [0x165000000 0xc000000] Size: 192.0MB
P53 (VERSION) [0x171000000 0x2000000] Size: 32.0MB
P54 (VENDOR) [0x173000000 0x31000000] Size: 784.0MB
P55 (PRODUCT) [0x1a4000000 0xc000000] Size: 192.0MB
P56 (USERDATA) [0x1b0000000 0xcdf800000] Size: 51.492GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0040000000 (4.578GB)
Build ID: OPR6.170623.010
Release Incremental ID: eng.jenkin.20190425.142545
Release Base ID: 8.0.0
Architecture ABI: arm64-v8a
Device manufacturer: unknown
Build Description: generic_a15-user 8.0.0 OPR6.170623.010 eng.jenkin.20190425.142545 test-keys
Display Build ID: System 8.0.0.046(0W50)
Detected USERDATA USERDATA : 0x01B0000000 (51.492GB)
Unable to mount USERDATA , code : 5
Done.
Selected eMMC Interface
Read partitions dump:
Checking security ...
Skip loading eMMC Addon Firmware
CLK Rate:42000 kHz
Bus Width:8bit,SDR
Reading 0x000CDF800000 (51.492GB) from 0x0001B0000000 ...ROM1 ( USER ROM)
Output file :C:\Program Files\Z3X\EASYJTAG\EMMC_DD4064_ 320279555_ROM1_0x1b0000000_USERDATA_0xcdf800000.bi n
Error reading address 0x1B0000000 Error Code:-3 Reason :DATA RCV Timeout Error
Retry reading address 0x1B0000000 (Attempt #1)
Page generated in 0.14273 seconds with 5 queries
