05-23-2018, 05:22 | #17 (permalink) |
Insane Poster Join Date: Sep 2015 Location: NEPAL
Member: 2461218 Status: Offline Thanks Meter: 26 | [IMG]My Files[/IMG] pinout and repair done bl flashed but still dead c900f please help me blang http://www.mediafire.com/file/a750g4...oot+repair.jpg http://www.mediafire.com/file/q3n1kv....35.49+PM.jpeg |
The Following User Says Thank You to heartcrusted For This Useful Post: |
06-16-2018, 09:54 | #20 (permalink) | |
Crazy Poster Join Date: Jun 2010 Location: cold place
Member: 1316900 Status: Offline Sonork: none Thanks Meter: 30 | Quote: | |
07-03-2018, 05:08 | #21 (permalink) |
Insane Poster Join Date: Nov 2007 Location: NEPAL,POKHARA Age: 43
Member: 640856 Status: Offline Thanks Meter: 15 | c9 pro (c90000 ) jtag write done c9 pro (c90000 ) jtag write done but set is still dead i tried 3 different file and pit is from same set readed before dead all file write done but not set alive any one have tested solution? 6/29/2018 12:48:05 PM> 6/29/2018 1:00:57 PM> Looking for EasyJTAG box... 6/29/2018 1:00:57 PM> EasyJTAG API ver. 2100 6/29/2018 1:00:57 PM> Setting IO Levels to 1.8V 6/29/2018 1:00:57 PM> Setting frequence to 14 Mhz 6/29/2018 1:00:57 PM> EasyJTAG Box Serial = 1800E0058C7A7B89 6/29/2018 1:00:57 PM> EasyJTAG Box Firmware = 1.62 6/29/2018 1:00:59 PM> HiPower mode is ON 6/29/2018 1:00:59 PM> Setting frequence to 14 Mhz 6/29/2018 1:00:59 PM> CMD Pullup Level: 1732 mV 6/29/2018 1:00:59 PM> CMD Active Level: 1722 mV 6/29/2018 1:00:59 PM> eMMC Init returned = 0 6/29/2018 1:00:59 PM> EMMC Device Information : 6/29/2018 1:00:59 PM> EMMC CID: 150100434A4E423452102D89B42E9486 6/29/2018 1:00:59 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C 6/29/2018 1:00:59 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: CJNB4R , HEX: 434A4E423452 , S/N: 2D89B42E , rev. 0x10 6/29/2018 1:00:59 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2017 6/29/2018 1:00:59 PM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) 6/29/2018 1:00:59 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 6/29/2018 1:00:59 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 6/29/2018 1:00:59 PM> EMMC Permanent Write Protection: No 6/29/2018 1:00:59 PM> EMMC Temporary Write Protection: No 6/29/2018 1:00:59 PM> Extended CSD Information : 6/29/2018 1:00:59 PM> Extended CSD rev: 1.8 (MMC 5.1) 6/29/2018 1:00:59 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 6/29/2018 1:00:59 PM> Boot Bus Config: 0x00 , width 1bit 6/29/2018 1:00:59 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 6/29/2018 1:00:59 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 6/29/2018 1:00:59 PM> Device supports partitioning features 6/29/2018 1:00:59 PM> Device can have enhanced technological features in partitions and user data area 6/29/2018 1:00:59 PM> Device can have extended partitions attribute 6/29/2018 1:00:59 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 6/29/2018 1:00:59 PM> Backup saved: CJNB4R_2D89B42E_20180629_130059.extcsd 6/29/2018 1:00:59 PM> EMMC Init completed. 6/29/2018 1:00:59 PM> 6/29/2018 1:01:58 PM> Looking for EasyJTAG box... 6/29/2018 1:01:58 PM> EasyJTAG API ver. 2100 6/29/2018 1:01:58 PM> Setting IO Levels to 3.3V 6/29/2018 1:01:58 PM> Setting frequence to 14 Mhz 6/29/2018 1:01:58 PM> EasyJTAG Box Serial = 1800E0058C7A7B89 6/29/2018 1:01:58 PM> EasyJTAG Box Firmware = 1.62 6/29/2018 1:02:00 PM> HiPower mode is ON 6/29/2018 1:02:00 PM> Setting frequence to 14 Mhz 6/29/2018 1:02:00 PM> CMD Pullup Level: 1815 mV 6/29/2018 1:02:00 PM> CMD Active Level: 2505 mV 6/29/2018 1:02:00 PM> eMMC Init returned = 0 6/29/2018 1:02:00 PM> EMMC Device Information : 6/29/2018 1:02:00 PM> EMMC CID: 150100434A4E423452102D89B42E9486 6/29/2018 1:02:00 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C 6/29/2018 1:02:01 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: CJNB4R , HEX: 434A4E423452 , S/N: 2D89B42E , rev. 0x10 6/29/2018 1:02:01 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2017 6/29/2018 1:02:01 PM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) 6/29/2018 1:02:01 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 6/29/2018 1:02:01 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 6/29/2018 1:02:01 PM> EMMC Permanent Write Protection: No 6/29/2018 1:02:01 PM> EMMC Temporary Write Protection: No 6/29/2018 1:02:01 PM> Extended CSD Information : 6/29/2018 1:02:01 PM> Extended CSD rev: 1.8 (MMC 5.1) 6/29/2018 1:02:01 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 6/29/2018 1:02:01 PM> Boot Bus Config: 0x00 , width 1bit 6/29/2018 1:02:01 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 6/29/2018 1:02:01 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 6/29/2018 1:02:01 PM> Device supports partitioning features 6/29/2018 1:02:01 PM> Device can have enhanced technological features in partitions and user data area 6/29/2018 1:02:01 PM> Device can have extended partitions attribute 6/29/2018 1:02:01 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 6/29/2018 1:02:01 PM> Backup saved: CJNB4R_2D89B42E_20180629_130201.extcsd 6/29/2018 1:02:01 PM> EMMC Init completed. 6/29/2018 1:02:01 PM> 6/29/2018 1:02:01 PM> Opening file: F:\C9LTE_CHN_OPEN.pit 6/29/2018 1:02:01 PM> 6/29/2018 1:02:01 PM> Pit: C9LTE_CHN_OPEN.pit 6/29/2018 1:02:01 PM> Entry count: 45 6/29/2018 1:02:01 PM> 6/29/2018 1:02:01 PM> The size of the last section has been updated 6/29/2018 1:02:15 PM> Selected file: F:\BL_C9000ZHU1BRC2_CL12584624_QB17539921_REV00_us er_low_ship_MULTI_CERT.tar.md5 6/29/2018 1:02:15 PM> 6/29/2018 1:02:15 PM> BL_C9000ZHU1BRC2_CL12584624_QB17539921_REV00_user_ low_ship_MULTI_CERT.tar.md5 6/29/2018 1:02:15 PM> The list of files in the firmware: 6/29/2018 1:02:15 PM> aboot.mbn 6/29/2018 1:02:15 PM> sbl1.mbn 6/29/2018 1:02:15 PM> rpm.mbn 6/29/2018 1:02:15 PM> tz.mbn 6/29/2018 1:02:15 PM> devcfg.mbn 6/29/2018 1:02:15 PM> non-hlos.bin 6/29/2018 1:02:15 PM> cmnlib.mbn 6/29/2018 1:02:15 PM> keymaster.mbn 6/29/2018 1:02:15 PM> apdp.mbn 6/29/2018 1:02:15 PM> msadp.mbn 6/29/2018 1:02:15 PM> sec.dat 6/29/2018 1:02:15 PM> lksecapp.mbn 6/29/2018 1:02:15 PM> 6/29/2018 1:02:20 PM> Looking for EasyJTAG box... 6/29/2018 1:02:20 PM> EasyJTAG API ver. 2100 6/29/2018 1:02:20 PM> Setting IO Levels to 3.3V 6/29/2018 1:02:20 PM> Setting frequence to 14 Mhz 6/29/2018 1:02:20 PM> EasyJTAG Box Serial = 1800E0058C7A7B89 6/29/2018 1:02:20 PM> EasyJTAG Box Firmware = 1.62 6/29/2018 1:02:21 PM> HiPower mode is ON 6/29/2018 1:02:21 PM> Setting frequence to 14 Mhz 6/29/2018 1:02:21 PM> CMD Pullup Level: 1815 mV 6/29/2018 1:02:21 PM> CMD Active Level: 2485 mV 6/29/2018 1:02:22 PM> eMMC Init returned = 0 6/29/2018 1:02:22 PM> EMMC Device Information : 6/29/2018 1:02:22 PM> EMMC CID: 150100434A4E423452102D89B42E9486 6/29/2018 1:02:22 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C 6/29/2018 1:02:22 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: CJNB4R , HEX: 434A4E423452 , S/N: 2D89B42E , rev. 0x10 6/29/2018 1:02:22 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2017 6/29/2018 1:02:22 PM> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) 6/29/2018 1:02:22 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 6/29/2018 1:02:22 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 6/29/2018 1:02:22 PM> EMMC Permanent Write Protection: No 6/29/2018 1:02:22 PM> EMMC Temporary Write Protection: No 6/29/2018 1:02:22 PM> Extended CSD Information : 6/29/2018 1:02:22 PM> Extended CSD rev: 1.8 (MMC 5.1) 6/29/2018 1:02:22 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 6/29/2018 1:02:22 PM> Boot Bus Config: 0x00 , width 1bit 6/29/2018 1:02:22 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 6/29/2018 1:02:22 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 6/29/2018 1:02:22 PM> Device supports partitioning features 6/29/2018 1:02:22 PM> Device can have enhanced technological features in partitions and user data area 6/29/2018 1:02:22 PM> Device can have extended partitions attribute 6/29/2018 1:02:22 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 6/29/2018 1:02:22 PM> Backup saved: CJNB4R_2D89B42E_20180629_130222.extcsd 6/29/2018 1:02:22 PM> EMMC Init completed. 6/29/2018 1:02:22 PM> 6/29/2018 1:02:22 PM> Operation: Write by vendor (Samsung) 6/29/2018 1:02:22 PM> 6/29/2018 1:02:22 PM> Creating GPT-partitioninig 6/29/2018 1:02:22 PM> Writing PrimaryGPT at address: 000000000000 6/29/2018 1:02:22 PM> Writing BackupGPT at address: 000E8F7FBE00 6/29/2018 1:02:22 PM> Writing PIT at address: 000000004400 6/29/2018 1:02:22 PM> GPT-partitioning done 6/29/2018 1:02:22 PM> 6/29/2018 1:02:22 PM> Unpacking file: sbl1.mbn 6/29/2018 1:02:22 PM> Unpacking file: aboot.mbn 6/29/2018 1:02:22 PM> Unpacking file: rpm.mbn 6/29/2018 1:02:22 PM> Unpacking file: tz.mbn 6/29/2018 1:02:22 PM> Unpacking file: sec.dat 6/29/2018 1:02:22 PM> Unpacking file: keymaster.mbn 6/29/2018 1:02:23 PM> Unpacking file: cmnlib.mbn 6/29/2018 1:02:23 PM> Unpacking file: lksecapp.mbn 6/29/2018 1:02:23 PM> Unpacking file: apdp.mbn 6/29/2018 1:02:23 PM> Unpacking file: msadp.mbn 6/29/2018 1:02:23 PM> Unpacking file: devcfg.mbn 6/29/2018 1:02:23 PM> Unpacking file: non-hlos.bin 6/29/2018 1:02:24 PM> 6/29/2018 1:02:24 PM> Partition name: SBL1 6/29/2018 1:02:24 PM> Filename: sbl1.mbn , Offset: 000000400000 , filesize: 404232 bytes 6/29/2018 1:02:24 PM> eMMC switching to ROM1 6/29/2018 1:02:24 PM> Erasing partition... 6/29/2018 1:02:25 PM> Writing partition... 6/29/2018 1:02:26 PM> Done writing partition. Write speed: 361.87 KB/s 6/29/2018 1:02:26 PM> Partition name: ABOOT 6/29/2018 1:02:26 PM> Filename: aboot.mbn , Offset: 000000510000 , filesize: 1703241 bytes 6/29/2018 1:02:26 PM> eMMC switching to ROM1 6/29/2018 1:02:26 PM> Erasing partition... 6/29/2018 1:02:28 PM> Writing partition... 6/29/2018 1:02:30 PM> Done writing partition. Write speed: 610.12 KB/s 6/29/2018 1:02:30 PM> Partition name: RPM 6/29/2018 1:02:30 PM> Filename: rpm.mbn , Offset: 000000710000 , filesize: 201080 bytes 6/29/2018 1:02:30 PM> eMMC switching to ROM1 6/29/2018 1:02:31 PM> Erasing partition... 6/29/2018 1:02:31 PM> Writing partition... 6/29/2018 1:02:31 PM> Done writing partition. Write speed: 606.85 KB/s 6/29/2018 1:02:32 PM> Partition name: TZ 6/29/2018 1:02:32 PM> Filename: tz.mbn , Offset: 000000790000 , filesize: 1547776 bytes 6/29/2018 1:02:32 PM> eMMC switching to ROM1 6/29/2018 1:02:32 PM> Erasing partition... 6/29/2018 1:02:32 PM> Writing partition... 6/29/2018 1:02:35 PM> Done writing partition. Write speed: 613.40 KB/s 6/29/2018 1:02:35 PM> Partition name: SEC 6/29/2018 1:02:35 PM> Filename: sec.dat , Offset: 000000D10000 , filesize: 692 bytes 6/29/2018 1:02:35 PM> eMMC switching to ROM1 6/29/2018 1:02:35 PM> Erasing partition... 6/29/2018 1:02:36 PM> Writing partition... 6/29/2018 1:02:36 PM> Done writing partition. Write speed: 31.70 KB/s 6/29/2018 1:02:36 PM> Partition name: KEYMASTER 6/29/2018 1:02:36 PM> Filename: keymaster.mbn , Offset: 000000D14000 , filesize: 259032 bytes 6/29/2018 1:02:36 PM> eMMC switching to ROM1 6/29/2018 1:02:36 PM> Erasing partition... 6/29/2018 1:02:36 PM> Writing partition... 6/29/2018 1:02:37 PM> Done writing partition. Write speed: 635.31 KB/s 6/29/2018 1:02:37 PM> Partition name: CMNLIB 6/29/2018 1:02:37 PM> Filename: cmnlib.mbn , Offset: 000000D94000 , filesize: 234304 bytes 6/29/2018 1:02:37 PM> eMMC switching to ROM1 6/29/2018 1:02:37 PM> Erasing partition... 6/29/2018 1:02:38 PM> Writing partition... 6/29/2018 1:02:38 PM> Done writing partition. Write speed: 532.38 KB/s 6/29/2018 1:02:38 PM> Partition name: LKSECAPP 6/29/2018 1:02:38 PM> Filename: lksecapp.mbn , Offset: 000000DD4000 , filesize: 270944 bytes 6/29/2018 1:02:38 PM> eMMC switching to ROM1 6/29/2018 1:02:38 PM> Erasing partition... 6/29/2018 1:02:39 PM> Writing partition... 6/29/2018 1:02:39 PM> Done writing partition. Write speed: 564.75 KB/s 6/29/2018 1:02:39 PM> Partition name: APDP 6/29/2018 1:02:39 PM> Filename: apdp.mbn , Offset: 000000E54000 , filesize: 46272 bytes 6/29/2018 1:02:39 PM> eMMC switching to ROM1 6/29/2018 1:02:39 PM> Erasing partition... 6/29/2018 1:02:40 PM> Writing partition... 6/29/2018 1:02:40 PM> Done writing partition. Write speed: 534.59 KB/s 6/29/2018 1:02:40 PM> Partition name: MSADP 6/29/2018 1:02:40 PM> Filename: msadp.mbn , Offset: 000000E74000 , filesize: 46272 bytes 6/29/2018 1:02:40 PM> eMMC switching to ROM1 6/29/2018 1:02:40 PM> Erasing partition... 6/29/2018 1:02:41 PM> Writing partition... 6/29/2018 1:02:41 PM> Done writing partition. Write speed: 536.37 KB/s 6/29/2018 1:02:41 PM> Partition name: DEVCFG 6/29/2018 1:02:41 PM> Filename: devcfg.mbn , Offset: 00000AE88000 , filesize: 70580 bytes 6/29/2018 1:02:41 PM> eMMC switching to ROM1 6/29/2018 1:02:41 PM> Erasing partition... 6/29/2018 1:02:42 PM> Writing partition... 6/29/2018 1:02:42 PM> Done writing partition. Write speed: 483.30 KB/s 6/29/2018 1:02:42 PM> Partition name: APNHLOS 6/29/2018 1:02:42 PM> Filename: non-hlos.bin , Offset: 000012700000 , filesize: 24712960 bytes 6/29/2018 1:02:42 PM> eMMC switching to ROM1 6/29/2018 1:02:42 PM> Erasing partition... 6/29/2018 1:02:44 PM> Writing partition... 6/29/2018 1:03:23 PM> Done writing partition. Write speed: 618.98 KB/s 6/29/2018 1:03:23 PM> 6/29/2018 1:03:24 PM> Partition USERDATA : formatting as EXT4. Please wait ... 6/29/2018 1:03:54 PM> Formatting completed 6/29/2018 1:03:55 PM> 6/29/2018 1:03:55 PM> Check BOOT_PARTITION_EN for the selected vendor 6/29/2018 1:03:55 PM> 6/29/2018 1:03:55 PM> All done time: [00:01:31:010] 6/29/2018 1:03:55 PM> read firmware info Get firmware version Brand = samsung Manufacturer = samsung Model = SM-C9000 Phone platform = msm8952 CPU Abi = arm64-v8a Android release = 7.1.1 Firmware version = NMF26X.C9000ZHU1BRC2 Firmware date = Thu Mar 29 16:44:25 KST 2018 |
07-03-2018, 09:34 | #22 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | this boy cheating even he never seen easy jtag box there is UFS used in c9 pro nor EMMC |
The Following User Says Thank You to ilyasrao For This Useful Post: |
07-21-2018, 19:35 | #25 (permalink) | |
Freak Poster Join Date: Nov 2012 Location: pune india Age: 45
Member: 1838311 Status: Offline Sonork: 100.1638474 Thanks Meter: 103 | Quote:
