01-11-2019, 09:08 | #1 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | Can anyone provide a working EXT CSD for N8000? EXT CSD looks like this Access mode: sector mode Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V) Card/BGA: BGA (Discrete embedded) - High density MMC Manufacturer ID: 0x15 (Samsung) Product name: MAG2GA (0x4d4147324741), rev: 0x15, serial number: 0xB9807EDB Manufacturing date: May 2013 CID: 1501004D 41473247 4115B980 7EDB50C4 CSD: D0270132 0F5903FF F6DBFFFF 8A404006 EXT_CSD revision: 1.5 (MMC v4.41) Partition info: Boot1: 2048 KiB Boot2: 2048 KiB RPMB: 128 KiB User area: 14.56 GiB(15,634,268,160 bytes) Partition configuration: 0x48 Boot acknowledge is sent during the boot operation Boot partition 1 is enabled for boot Partitioning support: 0x03 Device support partitioning feature Device can have enhanced technological features Device partitioning possible Boot configuration protection: 0x00 Boot bus conditions: 0x01 Bus width: x4 (sdr/ddr), boot mode: sdr(default), reset bus width to x1 sdr(default) Boot area write protection: 0x00 Power-on write protection: possible Permanent write protection: possible Lock status: not locked Is that correct? I found others that are different see EXT CSD info: EXT_CSD revision: 1.5 (MMC v4.41) Partition info: Boot1: 2048 KiB Boot2: 2048 KiB RPMB: 128 KiB User area: 14.68 GiB(15,758,000,128 bytes) Partition configuration: 0x00 No boot acknowledge is sent (default) Device is not boot-enabled (default) Partitioning support: 0x03 Device support partitioning feature Device can have enhanced technological features Device partitioning possible Boot configuration protection: 0x00 Boot bus conditions: 0x00 Boot area write protection: 0x00 and EXT CSD info: EXT_CSD revision: 1.5 (MMC v4.41) Partition info: Boot1: 512 KiB Boot2: 512 KiB RPMB: 128 KiB User area: 14.68 GiB(15,758,000,128 bytes) Partition configuration: 0x48 Boot acknowledge is sent during the boot operation Boot partition 1 is enabled for boot Partitioning support: 0x03 Device support partitioning feature Device can have enhanced technological features Device partitioning possible Boot configuration protection: 0x00 Boot bus conditions: 0x01 Bus width: x4 (sdr/ddr), boot mode: sdr(default), reset bus width to x1 sdr(default) Boot area write protection: 0x00 Which one should I use? Thanks for help |
01-11-2019, 09:53 | #2 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Russia,Yekaterinburg
Member: 1363017 Status: Offline Thanks Meter: 44 | EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled |
The Following User Says Thank You to andrei_d1978 For This Useful Post: |
