02-06-2014, 09:28 | #1 (permalink) |
No Life Poster Join Date: Apr 2012
Member: 1743727 Status: Offline Thanks Meter: 76 | can not read full dump from working htc wildfire-s hear is mine screen shot i try on win 8 on my laptop but faild i try all thing (with battry battry+usb) but didnt get any success i try 2-3 samsung and 2-3 htc but allways faild to red write full dump i m using easy jteg pro (is there any problem with mine box) hope i will get the solution from team regards :- rocky |
02-06-2014, 12:42 | #2 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | looks like problem on your side. i found lot of positive report about success repair of this device. check wires. use good quality wires. check or GND is property connected. check other pins like Nrst(system reset) try on other pc. if you have same problem with other phones - then search problem exactly on your side. if you have anyone with easy-jtag in your city check with them, i think remoted catch such problem impossible. |
02-06-2014, 12:48 | #3 (permalink) |
Member: 1743727 Status: Offline Thanks Meter: 76 | same wires works with other jteg perfectly i use very thik wire for gnd so no pb with gnd nad nrst i also try on my laptop but still same and yes i also have some test reports but not getting any success with full dump read or write |
02-06-2014, 13:00 | #4 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
no way check your problem remoted. JTAG reading-writing very complicated thing and unstable, even some impulse by power supply of pc can make error. Try find easy-jtag in your city and compare job. no other idea. Last edited by blang; 02-06-2014 at 13:08. | |
02-06-2014, 13:08 | #5 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | if you use same cable for all jtags, then do not know exactly but very similar like problem exactly in cable. EASY-JTAG PINOUT IS NOT FULLY SIMILAR TO OTHER JTAGs!!!!! EASY-JTAG have only 1 GND pin. other JTAGS have many GNS pins and very possible that GND pin on cable connected not to GND pin on easy-jtag. In JTAG in each picture of pinouts exist exactly pinout of each EASY-JTAG pins. And only 1 of them GND. |
02-06-2014, 13:13 | #6 (permalink) |
02-06-2014, 13:16 | #7 (permalink) | |
Member: 1743727 Status: Offline Thanks Meter: 76 | Quote:
i have 2 jteg wire 1 comes with easy jteg 2nd with ort and in repair 4-5 cdma phone with easy jteg using ort cable i try both wires 1by1 and every time i face error and there is no user of easy jteg in my city | |
02-06-2014, 13:22 | #8 (permalink) | |
check where in your cable connected GND. if jtag made by gpg, possible than the did mistake in GND, i have post about cable modify in sticked thread. if you sure all right with GND, then no idea. may be you not lucky to use easy-jtag, refund easy-jtag to reseller and use other jtags. | |
