04-19-2017, 12:59 | #1 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2473272 Status: Offline Thanks Meter: 0 | Can't init EMMC, Reason: CARD Data FIFO Timeout Error EasyJtag Suite Classic ver.: 2.5.0.8 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Admin rights FAIL undefined Android Explorer ver.: 1.0.0.23 eMMC ODIN ver.: 1.0.11.2 Successfully connected to box on COM112 Box S/N: 0CFFB0178B16EC78, ,FW Ver.: 01.58 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA35-945B , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 0CFFB0178B16EC78, ,FW Ver.: 01.58 CMD Pullup Level:1711 mV CMD Active Level:1763 mV Box IO Level:1850 mV CLK Rate:3000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A2058494E594816A1945800708C EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2013 Rev.0x16 EMMC NAME: XINYH , S/N: 2710853632 EMMC NAME (HEX): 2058494E594800 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0CFFB0178B16EC78, ,FW Ver.: 01.58 CMD Pullup Level:2072 mV CMD Active Level:2299 mV Box IO Level:2800 mV CLK Rate:3000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A2058494E594816A1945800708C EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2013 Rev.0x16 EMMC NAME: XINYH , S/N: 2710853632 EMMC NAME (HEX): 2058494E594800 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0CFFB0178B16EC78, ,FW Ver.: 01.58 CMD Pullup Level:2072 mV CMD Active Level:2299 mV Box IO Level:2800 mV CLK Rate:7000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A2058494E594816A1945800708C EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2013 Rev.0x16 EMMC NAME: XINYH , S/N: 2710853632 EMMC NAME (HEX): 2058494E594800 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0CFFB0178B16EC78, ,FW Ver.: 01.58 CMD Pullup Level:2093 mV CMD Active Level:2299 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A2058494E594816A1945800708C EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2013 Rev.0x16 EMMC NAME: XINYH , S/N: 2710853632 EMMC NAME (HEX): 2058494E594800 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0CFFB0178B16EC78, ,FW Ver.: 01.58 CMD Pullup Level:2062 mV CMD Active Level:2289 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A2058494E594816A1945800708C EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2013 Rev.0x16 EMMC NAME: XINYH , S/N: 2710853632 EMMC NAME (HEX): 2058494E594800 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0CFFB0178B16EC78, ,FW Ver.: 01.58 CMD Pullup Level:2083 mV CMD Active Level:2557 mV Box IO Level:3300 mV CLK Rate:21000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A2058494E594816A1945800708C EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2013 Rev.0x16 EMMC NAME: XINYH , S/N: 2710853632 EMMC NAME (HEX): 2058494E594800 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0CFFB0178B16EC78, ,FW Ver.: 01.58 CMD Pullup Level:2083 mV CMD Active Level:2505 mV Box IO Level:3300 mV CLK Rate:21000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 90014A2058494E594816A1945800708C EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2013 Rev.0x16 EMMC NAME: XINYH , S/N: 2710853632 EMMC NAME (HEX): 2058494E594800 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0CFFB0178B16EC78, ,FW Ver.: 01.58 CMD Pullup Level:2093 mV CMD Active Level:2495 mV Box IO Level:3300 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A2058494E594816A1945800708C EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2013 Rev.0x16 EMMC NAME: XINYH , S/N: 2710853632 EMMC NAME (HEX): 2058494E594800 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. |
