09-20-2016, 06:23 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Pakistan Age: 41
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | Can't init EMMC, Reason: DATA RCV CRC Error Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0100101C23C20968, ,FW Ver.: 01.55CMD Pullup Level:752 mV CMD Active Level:2248 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ----------EMMC CID : 15010056545530304DF1881440E77F34 EMMC CSD : D02701320F5903FFF6DBFFFF8E406008 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 Rev.0xF1 EMMC NAME: VTU00M , S/N: 2283028711 EMMC NAME (HEX): 56545530304D00 Can't init EMMC, Reason: DATA RCV CRC Error Check Data Line! Done. |
09-20-2016, 17:36 | #2 (permalink) | |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Quote:
Try to select different eMMC Voltage settings in software (1.8, 2.8, 3.3), make sure that GND line is short and has low resistance. Also in some cases pull-up resistor is helpfull: https://gyazo.com/02760615915efa1289934b4dc3530017 Best Regards Best Regards | |
12-28-2019, 13:37 | #3 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | same Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0900301095CE53A5, ,FW Ver.: 01.63 Warning: CMD Pullup Level (268 mV) too low , check cables etc.! CMD Active Level:1815 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. |
12-28-2019, 14:56 | #4 (permalink) | |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | low resistor issu Quote:
wich adaptor u use its low resistor problems (268 mV) too low | |
12-28-2019, 15:29 | #5 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | today i work done 2 oppo phones this adaptor .... but this phone not detected ?? |
The Following User Says Thank You to pintu_das For This Useful Post: |
12-28-2019, 19:35 | #8 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Under the Sky
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | Can't init EMMC, Reason: DATA RCV CRC Error Quote:
It is a big deal believe me specially cmd and gnd lines must be short as possible and make sure your pinout is correct, also could be a dead emmc or need pull up resistors, what is the condition of the phone Sent from my iPhone using Tapatalk | |
The Following 2 Users Say Thank You to oktay50000 For This Useful Post: |
12-29-2019, 07:05 | #9 (permalink) | |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Quote:
wire now very small but same | |
12-29-2019, 09:43 | #10 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | one more done now, Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0900301095CE53A5, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:2619 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4204E03EE45C26C6 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2019 Rev.0x4 eMMC NAME: QE63MB , S/N: 3762218076 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 55216 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. but this phone not detected ?? |
12-29-2019, 13:58 | #13 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
http://forum.gsmhosting.com/vbb/f672.../#post13909542 | |
The Following User Says Thank You to layder For This Useful Post: |
12-29-2019, 15:06 | #14 (permalink) | |
Short 4 CLK wires together can i use it now ??????? | |
