Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 12-29-2019, 18:14   #16 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 1,794
sir
Originally Posted by layder View Post
Do you need my permission to do as in the diagram drawn?
sir,
i have no idea for old adapter modify
if you say i will try....
Old 01-12-2020, 07:38   #17 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 1,794
Z3X EasyJtag Software ver. 3.6.2.0
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 0900301095CE53A5, ,FW Ver.: 01.63
CMD Pullup Level:2052 mV
CMD Active Level:3083 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 90014A68423861503E03C720EAB6B584
eMMC CSD : D02700328F5903FFFFFFFFEF8E400042
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 11/2018 Rev.0x3
eMMC NAME: hB8aP> , S/N: 3340823222
eMMC NAME (HEX): 68423861503E
Can't init EMMC, Reason: DATA RCV CRC Error
Check Data Line!
Done.
Old 01-12-2020, 09:10   #18 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 183
Originally Posted by oktay50000 View Post
Wires are too long
Sent from my iPhone using Tapatalk
first of all full clean your isp adopter
2-use external power cable
3-use shorter wires some of mobiles boards uses high power
Old 01-12-2020, 10:10   #19 (permalink)
Member: 13148
Thanks Meter: 1,460
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Check Data Line!
Done.
You can't read this text?
Check you wires connection
The Following User Says Thank You to layder For This Useful Post:
Old 01-12-2020, 17:32   #20 (permalink)
MDK23's Avatar
Member: 467636
Sonork: Double Kanon
Thanks Meter: 2,642
cant connect j110h
HiPower mode is ON
Setting frequence to 21 MHz
CMD Pullup Level: 1742 mV
CMD Active Level: 1804 mV
Can't init device. Reason: CMD Timeout Error
HiPower mode is ON
CMD Pullup Level: 65535 mV
CMD Active Level: 65535 mV
Can't init device. Reason: -12 Unknown error
Page generated in 0.24865 seconds with 7 queries
