02-01-2015, 01:06 | #1 (permalink) | ||
No Life Poster Join Date: Jan 2008 Location: Under the Sky
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | cant repair htc sensation xe i flashed with rcp file but phone still dead and now when connecting usb cable it detects qloader 9008 after rapair and now cant connect to easy jtag what should i do now? this is log before flashing with easy jtag Quote:
02-01-2015, 12:46 | #2 (permalink) |
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | also cant erase jtag says flash not supported EasyJtag Suite ver.: 1.7.0.0 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 8 (build 9200), 64-bit edition. For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security...OK Initialising: HTC Z710e Sensation (PG58130) Config ver.:1.00 I/O Level set to : 2200 mV Box S/N: 070090096D4A6295 ,FW Ver.: 01.51 Connecting to Target... Code: JTAG device: MSM8260. CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4 CPU Manufacturer: Samsung , CPU Name: ARM7GEN JTAG device: MSM8260. CPU IDCODE : 0x104210E1 Mfg.: 0x070, Part: 0x0421, Ver.: 0x1 CPU Manufacturer: QUALCOMM , CPU Name: MSM8260 Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00000015 Name : MLL00M Size : 2.3 G , (4718592) Blocks EMMC #1 : ID : 0x00000000 Name : MLL00M Size : 512.0 K , (1024) Blocks eMMC flash device(s) found, Device ID : 0x00150000 Erasing memory from 00000000 length 00100000 This flash memory device are not supported... |
