04-21-2020, 09:35 | #1 (permalink) |
Crazy Poster Join Date: Dec 2014 Location: Walling,syangja,nepal
Member: 2308721 Status: Offline Sonork: [email protected] Thanks Meter: 12 | can't write dump backup from working phone how can i solve it tried shell dump but same error here is the log Code: Processing file...C:\Users\Apex\Desktop\g532 on\EMMC_ROM1_H8G4u_867951882_00000000_20000000.bin Writing as RAW data Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware CMD Pullup Level:2670 mV CMD Active Level:2774 mV Input file : C:\Users\Apex\Desktop\g532 on\EMMC_ROM1_H8G4u_867951882_00000000_20000000.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Write Block Failed, Reason: Write Block Verify Error Done. Done with error(s) i don't have easy jtag plus to write bootloder i have old one so |
04-21-2020, 09:37 | #2 (permalink) |
Member: 2308721 Status: Offline Sonork: [email protected] Thanks Meter: 12 | infi is here Code: Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0100C01CD5DD0243, ,FW Ver.: 01.63 CMD Pullup Level:2660 mV CMD Active Level:2763 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A483847347592011D4980F715BE eMMC CSD : D02701320F5903FFFFFFFFE78A40002A eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 01/2018 Rev.0x1 eMMC NAME: H8G4u , S/N: 491356407 eMMC NAME (HEX): 483847347520 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 0 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H8G4u_ 491356407_20200421_1421.extcsd Partition info not found Done. Selected eMMC Interface Failed to load partition |
