10-09-2018, 09:50 | #1 (permalink) |
Freak Poster Join Date: Jul 2014 Location: philippines
Member: 2226456 Status: Offline Sonork: jerrenn Thanks Meter: 83 | SM-G532G dead successfully back in to life via replace emmc and easy jtag flash 10/8/2018 11:08:31 PM> Setting interface to EasyJtag2/ISP_HiPower 10/8/2018 11:08:31 PM> Setting bus width to 1 Bit 10/8/2018 11:08:31 PM> HiPower mode is ON 10/8/2018 11:08:31 PM> Setting frequence to 24 Mhz 10/8/2018 11:08:31 PM> CMD Pullup Level: 2115 mV 10/8/2018 11:08:31 PM> CMD Active Level: 2663 mV 10/8/2018 11:08:31 PM> eMMC Init returned = 0 10/8/2018 11:08:31 PM> EMMC Device Information : 10/8/2018 11:08:31 PM> EMMC CID: 90014A4838473475920133A5DC5D5459 10/8/2018 11:08:31 PM> EMMC CSD: D02701320F5903FFFFFFFFE78A40002B 10/8/2018 11:08:31 PM> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 33A5DC5D , rev. 0x01 10/8/2018 11:08:31 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 5/2017 10/8/2018 11:08:31 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 10/8/2018 11:08:31 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 10/8/2018 11:08:31 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 10/8/2018 11:08:32 PM> EMMC Permanent Write Protection: No 10/8/2018 11:08:32 PM> EMMC Temporary Write Protection: No 10/8/2018 11:08:32 PM> Extended CSD Information : 10/8/2018 11:08:32 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 10/8/2018 11:08:32 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 10/8/2018 11:08:32 PM> Boot Bus Config: 0x00 , width 1bit 10/8/2018 11:08:32 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 10/8/2018 11:08:32 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 10/8/2018 11:08:32 PM> Device supports partitioning features 10/8/2018 11:08:32 PM> Device can have enhanced technological features in partitions and user data area 10/8/2018 11:08:32 PM> Device can have extended partitions attribute 10/8/2018 11:08:32 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 10/8/2018 11:08:32 PM> Backup saved: H8G4u_33A5DC5D_20181008_230832.extcsd 10/8/2018 11:08:32 PM> EMMC Init completed. 10/8/2018 11:08:32 PM> 10/8/2018 11:08:32 PM> Operation: Write by vendor (Samsung) 10/8/2018 11:08:32 PM> 10/8/2018 11:08:32 PM> Creating GPT-partitioninig 10/8/2018 11:08:32 PM> Writing PrimaryGPT at address: 000000000000 10/8/2018 11:08:32 PM> Writing BackupGPT at address: 0001D1FFBE00 10/8/2018 11:08:32 PM> Writing PIT at address: 000000004400 10/8/2018 11:08:32 PM> GPT-partitioning done 10/8/2018 11:08:32 PM> 10/8/2018 11:08:32 PM> Unpacking file: preloader.img 10/8/2018 11:08:32 PM> Unpacking file: lk.bin 10/8/2018 11:08:32 PM> Unpacking file: efuse.img 10/8/2018 11:08:32 PM> Unpacking file: trustzone.bin 10/8/2018 11:08:32 PM> Unpacking file: param.bin 10/8/2018 11:08:32 PM> 10/8/2018 11:08:32 PM> Partition name: BOOTLOADER 10/8/2018 11:08:32 PM> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes 10/8/2018 11:08:32 PM> eMMC switching to ROM2 10/8/2018 11:08:32 PM> Erasing partition... 10/8/2018 11:08:37 PM> Writing partition... 10/8/2018 11:08:37 PM> Done writing partition. Write speed: 563.58 KB/s 10/8/2018 11:08:37 PM> Partition name: LK 10/8/2018 11:08:37 PM> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes 10/8/2018 11:08:37 PM> eMMC switching to ROM1 10/8/2018 11:08:38 PM> Erasing partition... 10/8/2018 11:08:39 PM> Writing partition... 10/8/2018 11:08:39 PM> Done writing partition. Write speed: 1366.79 KB/s 10/8/2018 11:08:39 PM> Partition name: EFUSE 10/8/2018 11:08:39 PM> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes 10/8/2018 11:08:39 PM> eMMC switching to ROM1 10/8/2018 11:08:40 PM> Erasing partition... 10/8/2018 11:08:40 PM> Writing partition... 10/8/2018 11:08:40 PM> Done writing partition. Write speed: 22.41 KB/s 10/8/2018 11:08:40 PM> Partition name: TEE1 10/8/2018 11:08:40 PM> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes 10/8/2018 11:08:40 PM> eMMC switching to ROM1 10/8/2018 11:08:41 PM> Erasing partition... 10/8/2018 11:08:41 PM> Writing partition... 10/8/2018 11:08:41 PM> Done writing partition. Write speed: 2247.58 KB/s 10/8/2018 11:08:41 PM> Partition name: PARAM 10/8/2018 11:08:41 PM> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes 10/8/2018 11:08:41 PM> eMMC switching to ROM1 10/8/2018 11:08:42 PM> Erasing partition... 10/8/2018 11:08:42 PM> Writing partition... 10/8/2018 11:08:43 PM> Done writing partition. Write speed: 2367.71 KB/s 10/8/2018 11:08:43 PM> 10/8/2018 11:08:43 PM> Check BootConfig for the selected vendor 10/8/2018 11:08:43 PM> 10/8/2018 11:08:43 PM> All done time: [00:00:11:239] 10/8/2018 11:08:43 PM> |
The Following User Says Thank You to jennydahan For This Useful Post: |
10-11-2018, 09:28 | #2 (permalink) |
Freak Poster Join Date: Feb 2015 Location: Libya
Member: 2340647 Status: Offline Thanks Meter: 69 | G532F Boot Repair Done G532F Boot Repair Done By Easy Jtag Plus Code: 10/10/2018 09:36:26 م> Operation: Write by vendor (Samsung) 10/10/2018 09:36:26 م> 10/10/2018 09:36:26 م> Creating GPT-partitioninig 10/10/2018 09:36:26 م> Writing PrimaryGPT at address: 000000000000 10/10/2018 09:36:26 م> Error writing at address: 000000000000 , error: -1 , CMD Timeout Error ... Retry #1 10/10/2018 09:36:26 م> Error writing at address: 000000000000 , error: -1 , CMD Timeout Error ... Retry #2 10/10/2018 09:36:26 م> Error writing at address: 000000000000 , error: -1 , CMD Timeout Error ... Retry #3 10/10/2018 09:36:26 م> Too many errors. Writing has been stopped 10/10/2018 09:36:27 م> 10/10/2018 09:36:29 م> Looking for EasyJTAG box... 10/10/2018 09:36:29 م> EasyJTAG API ver. 2100 10/10/2018 09:36:29 م> Setting IO Levels to 2.8V 10/10/2018 09:36:29 م> Setting frequence to 36 Mhz 10/10/2018 09:36:29 م> EasyJTAG Box Serial = FBE84B4C2A0EC2BE 10/10/2018 09:36:29 م> EasyJTAG Box Firmware = 2.30 10/10/2018 09:36:29 م> Setting interface to EasyJtag2/ISP_HiPower 10/10/2018 09:36:29 م> Setting bus width to 1 Bit 10/10/2018 09:36:29 م> HiPower mode is ON 10/10/2018 09:36:29 م> Setting frequence to 36 Mhz 10/10/2018 09:36:29 م> CMD Pullup Level: 2083 mV 10/10/2018 09:36:29 م> CMD Active Level: 2636 mV 10/10/2018 09:36:30 م> eMMC Init returned = 0 10/10/2018 09:36:30 م> EMMC Device Information : 10/10/2018 09:36:30 م> EMMC CID: 90014A4838473475920120219807B4D3 10/10/2018 09:36:30 م> EMMC CSD: D02701320F5903FFFFFFFFE78A40002B 10/10/2018 09:36:30 م> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 20219807 , rev. 0x01 10/10/2018 09:36:30 م> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 11/2017 10/10/2018 09:36:30 م> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 10/10/2018 09:36:30 م> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 10/10/2018 09:36:30 م> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 10/10/2018 09:36:30 م> EMMC Permanent Write Protection: No 10/10/2018 09:36:30 م> EMMC Temporary Write Protection: No 10/10/2018 09:36:30 م> Extended CSD Information : 10/10/2018 09:36:30 م> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 10/10/2018 09:36:30 م> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 10/10/2018 09:36:30 م> Boot Bus Config: 0x00 , width 1bit 10/10/2018 09:36:30 م> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 10/10/2018 09:36:30 م> Supported partition features [PARTITIONING_SUPPORT]: 0x07 10/10/2018 09:36:30 م> Device supports partitioning features 10/10/2018 09:36:30 م> Device can have enhanced technological features in partitions and user data area 10/10/2018 09:36:30 م> Device can have extended partitions attribute 10/10/2018 09:36:30 م> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 10/10/2018 09:36:30 م> Backup saved: H8G4u_20219807_20181010_213630.extcsd 10/10/2018 09:36:30 م> EMMC Init completed. 10/10/2018 09:36:30 م> 10/10/2018 09:36:30 م> Operation: Write by vendor (Samsung) 10/10/2018 09:36:30 م> 10/10/2018 09:36:30 م> Creating GPT-partitioninig 10/10/2018 09:36:30 م> Writing PrimaryGPT at address: 000000000000 10/10/2018 09:36:30 م> Writing BackupGPT at address: 0001D1FFBE00 10/10/2018 09:36:30 م> Writing PIT at address: 000000004400 10/10/2018 09:36:30 م> GPT-partitioning done 10/10/2018 09:36:30 م> 10/10/2018 09:36:30 م> Unpacking file: preloader.img 10/10/2018 09:36:30 م> Unpacking file: lk.bin 10/10/2018 09:36:30 م> Unpacking file: efuse.img 10/10/2018 09:36:30 م> Unpacking file: trustzone.bin 10/10/2018 09:36:30 م> Unpacking file: param.bin 10/10/2018 09:36:30 م> 10/10/2018 09:36:30 م> Partition name: BOOTLOADER 10/10/2018 09:36:31 م> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes 10/10/2018 09:36:31 م> eMMC switching to ROM2 10/10/2018 09:36:31 م> Erasing partition... 10/10/2018 09:36:34 م> Writing partition... 10/10/2018 09:36:34 م> Done writing partition. Write speed: 648.42 KB/s 10/10/2018 09:36:34 م> Partition name: LK 10/10/2018 09:36:34 م> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes 10/10/2018 09:36:34 م> eMMC switching to ROM1 10/10/2018 09:36:34 م> Erasing partition... 10/10/2018 09:36:36 م> Writing partition... 10/10/2018 09:36:36 م> Done writing partition. Write speed: 1925.05 KB/s 10/10/2018 09:36:36 م> Partition name: EFUSE 10/10/2018 09:36:36 م> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes 10/10/2018 09:36:36 م> eMMC switching to ROM1 10/10/2018 09:36:36 م> Erasing partition... 10/10/2018 09:36:37 م> Writing partition... 10/10/2018 09:36:37 م> Done writing partition. Write speed: 19.98 KB/s 10/10/2018 09:36:37 م> Partition name: TEE1 10/10/2018 09:36:37 م> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes 10/10/2018 09:36:37 م> eMMC switching to ROM1 10/10/2018 09:36:37 م> Erasing partition... 10/10/2018 09:36:38 م> Writing partition... 10/10/2018 09:36:38 م> Done writing partition. Write speed: 3244.68 KB/s 10/10/2018 09:36:38 م> Partition name: PARAM 10/10/2018 09:36:38 م> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes 10/10/2018 09:36:38 م> eMMC switching to ROM1 10/10/2018 09:36:38 م> Erasing partition... 10/10/2018 09:36:39 م> Writing partition... 10/10/2018 09:36:39 م> Done writing partition. Write speed: 3625.56 KB/s 10/10/2018 09:36:39 م> 10/10/2018 09:36:40 م> Check BootConfig for the selected vendor 10/10/2018 09:36:40 م> 10/10/2018 09:36:40 م> All done time: [00:00:09:370] 10/10/2018 09:36:40 م> 10/10/2018 09:37:01 م> Looking for EasyJTAG box... 10/10/2018 09:37:01 م> EasyJTAG API ver. 2100 10/10/2018 09:37:01 م> Setting IO Levels to 2.8V 10/10/2018 09:37:01 م> Setting frequence to 36 Mhz 10/10/2018 09:37:01 م> EasyJTAG Box Serial = FBE84B4C2A0EC2BE 10/10/2018 09:37:01 م> EasyJTAG Box Firmware = 2.30 10/10/2018 09:37:01 م> Setting interface to EasyJtag2/ISP_HiPower 10/10/2018 09:37:01 م> Setting bus width to 1 Bit 10/10/2018 09:37:01 م> HiPower mode is ON 10/10/2018 09:37:01 م> Setting frequence to 36 Mhz 10/10/2018 09:37:01 م> CMD Pullup Level: 2084 mV 10/10/2018 09:37:01 م> CMD Active Level: 2628 mV 10/10/2018 09:37:01 م> eMMC Init returned = 0 10/10/2018 09:37:01 م> EMMC Device Information : 10/10/2018 09:37:01 م> EMMC CID: 90014A4838473475920120219807B4D3 10/10/2018 09:37:01 م> EMMC CSD: D02701320F5903FFFFFFFFE78A40002B 10/10/2018 09:37:01 م> EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 20219807 , rev. 0x01 10/10/2018 09:37:01 م> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 11/2017 10/10/2018 09:37:01 م> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 10/10/2018 09:37:01 م> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 10/10/2018 09:37:01 م> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 10/10/2018 09:37:01 م> EMMC Permanent Write Protection: No 10/10/2018 09:37:01 م> EMMC Temporary Write Protection: No 10/10/2018 09:37:01 م> Extended CSD Information : 10/10/2018 09:37:01 م> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 10/10/2018 09:37:02 م> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 10/10/2018 09:37:02 م> Boot Bus Config: 0x00 , width 1bit 10/10/2018 09:37:02 م> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 10/10/2018 09:37:02 م> Supported partition features [PARTITIONING_SUPPORT]: 0x07 10/10/2018 09:37:02 م> Device supports partitioning features 10/10/2018 09:37:02 م> Device can have enhanced technological features in partitions and user data area 10/10/2018 09:37:02 م> Device can have extended partitions attribute 10/10/2018 09:37:02 م> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 10/10/2018 09:37:02 م> Backup saved: H8G4u_20219807_20181010_213702.extcsd 10/10/2018 09:37:02 م> EMMC Init completed. 10/10/2018 09:37:02 م> 10/10/2018 09:37:02 م> Operation: Write by vendor (Samsung) 10/10/2018 09:37:02 م> 10/10/2018 09:37:02 م> Creating GPT-partitioninig 10/10/2018 09:37:02 م> Writing PrimaryGPT at address: 000000000000 10/10/2018 09:37:02 م> Writing BackupGPT at address: 0001D1FFBE00 10/10/2018 09:37:02 م> Writing PIT at address: 000000004400 10/10/2018 09:37:02 م> GPT-partitioning done 10/10/2018 09:37:02 م> 10/10/2018 09:37:02 م> Unpacking file: preloader.img 10/10/2018 09:37:02 م> Unpacking file: lk.bin 10/10/2018 09:37:02 م> Unpacking file: efuse.img 10/10/2018 09:37:02 م> Unpacking file: trustzone.bin 10/10/2018 09:37:02 م> Unpacking file: param.bin 10/10/2018 09:37:02 م> 10/10/2018 09:37:02 م> Partition name: BOOTLOADER 10/10/2018 09:37:02 م> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes 10/10/2018 09:37:02 م> eMMC switching to ROM2 10/10/2018 09:37:02 م> Erasing partition... 10/10/2018 09:37:06 م> Writing partition... 10/10/2018 09:37:06 م> Done writing partition. Write speed: 987.56 KB/s 10/10/2018 09:37:06 م> Partition name: LK 10/10/2018 09:37:06 م> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes 10/10/2018 09:37:06 م> eMMC switching to ROM1 10/10/2018 09:37:06 م> Erasing partition... 10/10/2018 09:37:07 م> Writing partition... 10/10/2018 09:37:07 م> Done writing partition. Write speed: 1946.66 KB/s 10/10/2018 09:37:07 م> Partition name: EFUSE 10/10/2018 09:37:07 م> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes 10/10/2018 09:37:08 م> eMMC switching to ROM1 10/10/2018 09:37:08 م> Erasing partition... 10/10/2018 09:37:08 م> Writing partition... 10/10/2018 09:37:08 م> Done writing partition. Write speed: 20.00 KB/s 10/10/2018 09:37:08 م> Partition name: TEE1 10/10/2018 09:37:09 م> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes 10/10/2018 09:37:09 م> eMMC switching to ROM1 10/10/2018 09:37:09 م> Erasing partition... 10/10/2018 09:37:10 م> Writing partition... 10/10/2018 09:37:10 م> Done writing partition. Write speed: 2928.36 KB/s 10/10/2018 09:37:10 م> Partition name: PARAM 10/10/2018 09:37:10 م> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes 10/10/2018 09:37:10 م> eMMC switching to ROM1 10/10/2018 09:37:10 م> Erasing partition... 10/10/2018 09:37:11 م> Writing partition... 10/10/2018 09:37:11 م> Done writing partition. Write speed: 3617.61 KB/s 10/10/2018 09:37:11 م> 10/10/2018 09:37:12 م> Check BootConfig for the selected vendor 10/10/2018 09:37:12 م> 10/10/2018 09:37:12 م> All done time: [00:00:09:409] 10/10/2018 09:37:12 م> |
