03-01-2017, 22:41 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gizah/Egypt Age: 33
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | (CMD Timeout Error) .. A Common Problem That I Need to Understand! I get this error with most eMMC i try to repair, Although, i can detect and repair alot of others eMMC, I just don't know what this error refers to, and how to deal with it, The error: My adapter: At first, i thought it's related to bad wire soldering, but i've checked "alot" and i've found that every single wire is connected to it's pin, I've also applied 2res from 1.8v to D0 and CMD but that didn't help, Today, i repaired J100H and N8000, but i have H818p and I9200 which i can't repair since i can't detect because of that error, Now, i just need an explanation, Why i'm getting that error?, What it's refers to?, How to deal with it?, Thanks in advance |
03-01-2017, 23:07 | #3 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
I offer to you for use eMate Pro because it's very easy and stable Anyway for Exynos you need connect VCC/VCCQ but for Qualcomm you don't need connect VCC/VCCQ,You must connect USB Cable | |
The Following 3 Users Say Thank You to BABAK NURI For This Useful Post: |
03-01-2017, 23:17 | #4 (permalink) | |
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | (CMD Timeout Error) .. A Common Problem That I Need to Understand! Quote:
But since i can detect and repair alot of eMMCs, then i think it's not an adapter related issue, is it?, Thanks for the tip sir, it's very useful. Still seeking for an explanation here .... Last edited by MiRoOo; 03-02-2017 at 01:18. | |
03-02-2017, 06:22 | #5 (permalink) | |
Freak Poster Join Date: Jun 2014
Member: 2213928 Status: Offline Thanks Meter: 440 | Quote:
just chsck you're adpter by multimiter put v3 cable chsck volter 1.8 = 1.78 to2.5 volt sohow and 2.8 = 2.8 to 4 volt show then you're adpter is OK if 1.8 an 2.8 show olny 1.78 it is manfutucrer defetecd so change u2 IC po put 3.3 volt u2 and chsck agin | |
The Following 2 Users Say Thank You to yuvraj9x2 For This Useful Post: |
03-03-2017, 00:31 | #6 (permalink) |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | for i9200 if emmc sandisk must change by new samsung emmc,for lg h818p if it is hynix emmc try another adaptor or change emmc also... |
