coolpad 8297l-100 deadboot repair error help plz hi there i have coolpad 8297l-100 detect qcom driver only i try with easy jtag but i got error help plz https://s8.postimg.org/gkzamnnp1/Untitled.jpg |
11/19/2017 3:16:37 PM> Looking for EasyJTAG box... 11/19/2017 3:16:37 PM> EasyJTAG API ver. 2008 11/19/2017 3:16:37 PM> Setting IO Levels to 3.3V 11/19/2017 3:16:37 PM> Setting frequence to 14 Mhz 11/19/2017 3:16:37 PM> HiPower mode is OFF 11/19/2017 3:16:39 PM> OpenUSB returned = 0 11/19/2017 3:16:39 PM> Power Controller returned = 0 11/19/2017 3:16:40 PM> EasyJTAG Box Serial = 11/19/2017 3:16:40 PM> EasyJTAG Box Firmware = 01.58 11/19/2017 3:16:40 PM> HiPower mode is OFF 11/19/2017 3:16:40 PM> Frequence: 14 Mhz 11/19/2017 3:16:40 PM> CMD Pullup Level: 3104 mV 11/19/2017 3:16:40 PM> CMD Active Level: 3227 mV 11/19/2017 3:16:40 PM> eMMC Init returned = 0 11/19/2017 3:16:40 PM> EMMC Device Information : 11/19/2017 3:16:40 PM> EMMC CID: 90014A48384731650507CA16911A5210 11/19/2017 3:16:40 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 11/19/2017 3:16:40 PM> EMMC Manufacture Name: SKHYNIX 11/19/2017 3:16:40 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A 11/19/2017 3:16:40 PM> EMMC Manufacture Date: 5/2015 , Rev: 07 11/19/2017 3:16:40 PM> EMMC NAME: H8G1e , , rev. 07 11/19/2017 3:16:40 PM> EMMC NAME (HEX): 483847316505 11/19/2017 3:16:40 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 11/19/2017 3:16:40 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/19/2017 3:16:40 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 11/19/2017 3:16:40 PM> EMMC Permanent Write Protection: No 11/19/2017 3:16:40 PM> EMMC Temporary Write Protection: No 11/19/2017 3:16:40 PM> Extended CSD Information : 11/19/2017 3:16:40 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 11/19/2017 3:16:40 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 11/19/2017 3:16:40 PM> Boot Bus Config: 0x00 , width 1bit 11/19/2017 3:16:40 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 11/19/2017 3:16:40 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/19/2017 3:16:40 PM> Device supports partitioning features 11/19/2017 3:16:41 PM> Device can have enhanced technological features in partitions and user data area 11/19/2017 3:16:41 PM> Device can have extended partitions attribute 11/19/2017 3:16:41 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 11/19/2017 3:16:41 PM> Backup saved: H8G1e_CA16911A_20171119_151641.extcsd 11/19/2017 3:16:41 PM> EMMC Init completed. 11/19/2017 3:16:41 PM> 11/19/2017 3:16:45 PM> Looking for EasyJTAG box... 11/19/2017 3:16:45 PM> EasyJTAG API ver. 2008 11/19/2017 3:16:45 PM> Setting IO Levels to 3.3V 11/19/2017 3:16:45 PM> Setting frequence to 14 Mhz 11/19/2017 3:16:45 PM> HiPower mode is OFF 11/19/2017 3:16:46 PM> OpenUSB returned = 0 11/19/2017 3:16:46 PM> Power Controller returned = 0 11/19/2017 3:16:47 PM> EasyJTAG Box Serial = 0200402021DF307E 11/19/2017 3:16:47 PM> EasyJTAG Box Firmware = 01.58 11/19/2017 3:16:47 PM> HiPower mode is OFF 11/19/2017 3:16:48 PM> Frequence: 14 Mhz 11/19/2017 3:16:48 PM> CMD Pullup Level: 3104 mV 11/19/2017 3:16:48 PM> CMD Active Level: 3227 mV 11/19/2017 3:16:48 PM> eMMC Init returned = 0 11/19/2017 3:16:48 PM> EMMC Device Information : 11/19/2017 3:16:48 PM> EMMC CID: 90014A48384731650507CA16911A5210 11/19/2017 3:16:48 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 11/19/2017 3:16:48 PM> EMMC Manufacture Name: SKHYNIX 11/19/2017 3:16:48 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A 11/19/2017 3:16:48 PM> EMMC Manufacture Date: 5/2015 , Rev: 07 11/19/2017 3:16:48 PM> EMMC NAME: H8G1e , S/N: CA16911A , rev. 07 11/19/2017 3:16:48 PM> EMMC NAME (HEX): 483847316505 11/19/2017 3:16:48 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 11/19/2017 3:16:48 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 11/19/2017 3:16:48 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 11/19/2017 3:16:48 PM> EMMC Permanent Write Protection: No 11/19/2017 3:16:48 PM> EMMC Temporary Write Protection: No 11/19/2017 3:16:48 PM> Extended CSD Information : 11/19/2017 3:16:48 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 11/19/2017 3:16:48 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 11/19/2017 3:16:48 PM> Boot Bus Config: 0x00 , width 1bit 11/19/2017 3:16:48 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 11/19/2017 3:16:48 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 11/19/2017 3:16:48 PM> Device supports partitioning features 11/19/2017 3:16:48 PM> Device can have enhanced technological features in partitions and user data area 11/19/2017 3:16:48 PM> Device can have extended partitions attribute 11/19/2017 3:16:48 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 11/19/2017 3:16:48 PM> Backup saved: H8G1e_CA16911A_20171119_151648.extcsd 11/19/2017 3:16:48 PM> EMMC Init completed. 11/19/2017 3:16:48 PM> 11/19/2017 3:16:48 PM> Operation: Write by vendor (Qualcomm/HiSilicon) 11/19/2017 3:16:48 PM> 11/19/2017 3:16:48 PM> Creating GPT-partitioninig 11/19/2017 3:16:48 PM> GPT-partitioning done 11/19/2017 3:16:48 PM> 11/19/2017 3:16:56 PM> Partition name: modem 11/19/2017 3:16:56 PM> Filename: NON-HLOS.bin , Offset: 000002000000 , filesize: 47793664 bytes 11/19/2017 3:16:56 PM> eMMC switching to ROM1 11/19/2017 3:16:56 PM> Erasing partition... 11/19/2017 3:17:02 PM> Writing partition... 11/19/2017 3:18:01 PM> Done writing partition. Write speed: 787.56 Kb/s 11/19/2017 3:18:01 PM> Partition name: sbl1 11/19/2017 3:18:01 PM> Filename: sbl1.mbn , Offset: 000006000000 , filesize: 250664 bytes 11/19/2017 3:18:01 PM> eMMC switching to ROM1 11/19/2017 3:18:02 PM> Erasing partition... 11/19/2017 3:18:02 PM> Writing partition... 11/19/2017 3:18:03 PM> Done writing partition. Write speed: 682.21 Kb/s 11/19/2017 3:18:03 PM> Partition name: sbl1bak 11/19/2017 3:18:03 PM> Filename: sbl1.mbn , Offset: 000006080000 , filesize: 250664 bytes 11/19/2017 3:18:03 PM> eMMC switching to ROM1 11/19/2017 3:18:03 PM> Erasing partition... 11/19/2017 3:18:03 PM> Writing partition... 11/19/2017 3:18:04 PM> Done writing partition. Write speed: 694.56 Kb/s 11/19/2017 3:18:04 PM> Partition name: aboot 11/19/2017 3:18:04 PM> Filename: emmc_appsboot.mbn , Offset: 000006100000 , filesize: 2255244 bytes 11/19/2017 3:18:04 PM> eMMC switching to ROM1 11/19/2017 3:18:04 PM> Erasing partition... 11/19/2017 3:18:06 PM> Writing partition... 11/19/2017 3:18:08 PM> Done writing partition. Write speed: 919.20 Kb/s 11/19/2017 3:18:08 PM> Partition name: abootbak 11/19/2017 3:18:08 PM> Filename: emmc_appsboot.mbn , Offset: 000007000000 , filesize: 2255244 bytes 11/19/2017 3:18:08 PM> eMMC switching to ROM1 11/19/2017 3:18:09 PM> Erasing partition... 11/19/2017 3:18:10 PM> Writing partition... 11/19/2017 3:18:12 PM> Done writing partition. Write speed: 921.84 Kb/s 11/19/2017 3:18:12 PM> Partition name: rpm 11/19/2017 3:18:12 PM> Filename: rpm.mbn , Offset: 000007F00000 , filesize: 150848 bytes 11/19/2017 3:18:12 PM> eMMC switching to ROM1 11/19/2017 3:18:13 PM> Erasing partition... 11/19/2017 3:18:13 PM> Writing partition... 11/19/2017 3:18:14 PM> Done writing partition. Write speed: 643.30 Kb/s 11/19/2017 3:18:14 PM> Partition name: rpmbak 11/19/2017 3:18:14 PM> Filename: rpm.mbn , Offset: 000007F80000 , filesize: 150848 bytes 11/19/2017 3:18:14 PM> eMMC switching to ROM1 11/19/2017 3:18:14 PM> Erasing partition... 11/19/2017 3:18:14 PM> Writing partition... 11/19/2017 3:18:15 PM> Done writing partition. Write speed: 640.21 Kb/s 11/19/2017 3:18:15 PM> Partition name: tz 11/19/2017 3:18:15 PM> Filename: tz.mbn , Offset: 000008000000 , filesize: 387016 bytes 11/19/2017 3:18:15 PM> eMMC switching to ROM1 11/19/2017 3:18:15 PM> Erasing partition... 11/19/2017 3:18:16 PM> Writing partition... 11/19/2017 3:18:16 PM> Done writing partition. Write speed: 853.03 Kb/s 11/19/2017 3:18:16 PM> Partition name: tzbak 11/19/2017 3:18:16 PM> Filename: tz.mbn , Offset: 000008080000 , filesize: 387016 bytes 11/19/2017 3:18:16 PM> eMMC switching to ROM1 11/19/2017 3:18:16 PM> Erasing partition... 11/19/2017 3:18:17 PM> Writing partition... 11/19/2017 3:18:17 PM> Done writing partition. Write speed: 854.77 Kb/s 11/19/2017 3:18:17 PM> Partition name: hyp 11/19/2017 3:18:17 PM> Filename: hyp.mbn , Offset: 000008100000 , filesize: 20520 bytes 11/19/2017 3:18:17 PM> eMMC switching to ROM1 11/19/2017 3:18:18 PM> Erasing partition... 11/19/2017 3:18:18 PM> Writing partition... 11/19/2017 3:18:18 PM> Done writing partition. Write speed: 263.36 Kb/s 11/19/2017 3:18:18 PM> Partition name: hypbak 11/19/2017 3:18:18 PM> Filename: hyp.mbn , Offset: 000008180000 , filesize: 20520 bytes 11/19/2017 3:18:18 PM> eMMC switching to ROM1 11/19/2017 3:18:19 PM> Erasing partition... 11/19/2017 3:18:19 PM> Writing partition... 11/19/2017 3:18:19 PM> Done writing partition. Write speed: 263.08 Kb/s 11/19/2017 3:18:19 PM> Partition name: modemst1 11/19/2017 3:18:19 PM> Filename: dummy.bin , Offset: 000008300000 , filesize: 1572864 bytes 11/19/2017 3:18:19 PM> eMMC switching to ROM1 11/19/2017 3:18:20 PM> Erasing partition... 11/19/2017 3:18:20 PM> Writing partition... 11/19/2017 3:18:22 PM> Done writing partition. Write speed: 1393.93 Kb/s 11/19/2017 3:18:22 PM> Partition name: modemst2 11/19/2017 3:18:22 PM> Filename: dummy.bin , Offset: 000008480000 , filesize: 1572864 bytes 11/19/2017 3:18:22 PM> eMMC switching to ROM1 11/19/2017 3:18:22 PM> Erasing partition... 11/19/2017 3:18:22 PM> Writing partition... 11/19/2017 3:18:24 PM> Done writing partition. Write speed: 1393.22 Kb/s 11/19/2017 3:18:24 PM> Partition name: misc 11/19/2017 3:18:24 PM> Filename: MISC.img , Offset: 000008600000 , filesize: 1048576 bytes 11/19/2017 3:18:24 PM> eMMC switching to ROM1 11/19/2017 3:18:24 PM> Erasing partition... 11/19/2017 3:18:25 PM> Writing partition... 11/19/2017 3:18:25 PM> Done writing partition. Write speed: 1381.41 Kb/s 11/19/2017 3:18:25 PM> Partition name: fsg 11/19/2017 3:18:25 PM> Filename: nv.tar.mbn , Offset: 00000A008000 , filesize: 77608 bytes 11/19/2017 3:18:25 PM> eMMC switching to ROM1 11/19/2017 3:18:26 PM> Erasing partition... 11/19/2017 3:18:26 PM> Writing partition... 11/19/2017 3:18:26 PM> Done writing partition. Write speed: 507.58 Kb/s 11/19/2017 3:18:26 PM> Partition name: sec 11/19/2017 3:18:26 PM> Filename: sec.dat , Offset: 00000A188000 , filesize: 428 bytes 11/19/2017 3:18:26 PM> eMMC switching to ROM1 11/19/2017 3:18:27 PM> Erasing partition... 11/19/2017 3:18:27 PM> Writing partition... 11/19/2017 3:18:27 PM> Done writing partition. Write speed: 17.87 Kb/s 11/19/2017 3:18:27 PM> Partition name: boot 11/19/2017 3:18:27 PM> Filename: boot.img , Offset: 00000A18C000 , filesize: 8366080 bytes 11/19/2017 3:18:27 PM> eMMC switching to ROM1 11/19/2017 3:18:28 PM> Erasing partition... 11/19/2017 3:18:30 PM> Writing partition... 11/19/2017 3:18:40 PM> Done writing partition. Write speed: 781.76 Kb/s 11/19/2017 3:18:40 PM> Partition name: params 11/19/2017 3:18:40 PM> Filename: param.bin , Offset: 00000C000000 , filesize: 10752 bytes 11/19/2017 3:18:40 PM> eMMC switching to ROM1 11/19/2017 3:18:40 PM> Erasing partition... 11/19/2017 3:18:41 PM> Writing partition... 11/19/2017 3:18:41 PM> Done writing partition. Write speed: 265.53 Kb/s 11/19/2017 3:18:41 PM> Partition name: panic 11/19/2017 3:18:41 PM> Filename: panic.img , Offset: 00000C100000 , filesize: 4579328 bytes 11/19/2017 3:18:41 PM> eMMC switching to ROM1 11/19/2017 3:18:41 PM> Erasing partition... 11/19/2017 3:18:43 PM> Writing partition... 11/19/2017 3:18:46 PM> Done writing partition. Write speed: 1383.32 Kb/s 11/19/2017 3:18:46 PM> Partition name: system 11/19/2017 3:18:46 PM> Filename: system.img , Offset: 00000E000000 , filesize: 1509090124 bytes 11/19/2017 3:18:46 PM> eMMC switching to ROM1 11/19/2017 3:18:47 PM> Erasing partition... 11/19/2017 3:21:04 PM> Writing partition... 11/19/2017 3:21:05 PM> Sparse image found v.1.0 Total chunks: 3140 11/19/2017 3:53:31 PM> Done writing partition. Write speed: 757.24 Kb/s 11/19/2017 3:53:31 PM> Partition name: persist 11/19/2017 3:53:31 PM> Filename: persist.img , Offset: 00008E000000 , filesize: 4427960 bytes 11/19/2017 3:53:31 PM> eMMC switching to ROM1 11/19/2017 3:53:31 PM> Erasing partition... 11/19/2017 3:53:33 PM> Writing partition... 11/19/2017 3:53:33 PM> Sparse image found v.1.0 Total chunks: 13 11/19/2017 3:53:36 PM> Done writing partition. Write speed: 1250.77 Kb/s 11/19/2017 3:53:36 PM> Partition name: cache 11/19/2017 3:53:36 PM> Filename: cache.img , Offset: 00008EA00000 , filesize: 6348948 bytes 11/19/2017 3:53:36 PM> eMMC switching to ROM1 11/19/2017 3:53:36 PM> Erasing partition... 11/19/2017 3:53:45 PM> Writing partition... 11/19/2017 3:53:45 PM> Sparse image found v.1.0 Total chunks: 10 11/19/2017 3:53:50 PM> Done writing partition. Write speed: 1328.07 Kb/s 11/19/2017 3:53:50 PM> Partition name: recovery 11/19/2017 3:53:50 PM> Filename: recovery.img , Offset: 000096A00000 , filesize: 8953856 bytes 11/19/2017 3:53:50 PM> eMMC switching to ROM1 11/19/2017 3:53:50 PM> Erasing partition... 11/19/2017 3:53:52 PM> Writing partition... 11/19/2017 3:54:03 PM> Done writing partition. Write speed: 783.59 Kb/s 11/19/2017 3:54:03 PM> Partition name: userdata 11/19/2017 3:54:03 PM> Filename: userdata.img , Offset: 000097E00000 , filesize: 259079868 bytes 11/19/2017 3:54:03 PM> eMMC switching to ROM1 11/19/2017 3:54:04 PM> Erasing partition... 11/19/2017 3:59:36 PM> Writing partition... 11/19/2017 3:59:36 PM> Sparse image found v.1.0 Total chunks: 312 11/19/2017 4:04:11 PM> Done writing partition. Write speed: 920.88 Kb/s 11/19/2017 4:04:11 PM> 11/19/2017 4:04:11 PM> All done 11/19/2017 4:04:11 PM> DONE |
coolpad 8297l-100 deadboot repair error help plz Quote:
Emmc adaptor pic plzzz send me Sent from my iPhone using Tapatalk |
