Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 11-18-2017, 12:10   #1 (permalink)
Member: 1906916
Sonork: unlocker_007
Thanks Meter: 8
coolpad 8297l-100 deadboot repair error help plz
hi there
i have coolpad 8297l-100 detect qcom driver only i try with easy jtag but i got error help plz
Old 11-20-2017, 11:17   #2 (permalink)
Member: 1906916
Thanks Meter: 8
11/19/2017 3:16:37 PM> Looking for EasyJTAG box...
11/19/2017 3:16:37 PM> EasyJTAG API ver. 2008
11/19/2017 3:16:37 PM> Setting IO Levels to 3.3V
11/19/2017 3:16:37 PM> Setting frequence to 14 Mhz
11/19/2017 3:16:37 PM> HiPower mode is OFF
11/19/2017 3:16:39 PM> OpenUSB returned = 0
11/19/2017 3:16:39 PM> Power Controller returned = 0
11/19/2017 3:16:40 PM> EasyJTAG Box Serial =
11/19/2017 3:16:40 PM> EasyJTAG Box Firmware = 01.58
11/19/2017 3:16:40 PM> HiPower mode is OFF
11/19/2017 3:16:40 PM> Frequence: 14 Mhz
11/19/2017 3:16:40 PM> CMD Pullup Level: 3104 mV
11/19/2017 3:16:40 PM> CMD Active Level: 3227 mV
11/19/2017 3:16:40 PM> eMMC Init returned = 0
11/19/2017 3:16:40 PM> EMMC Device Information :
11/19/2017 3:16:40 PM> EMMC CID: 90014A48384731650507CA16911A5210
11/19/2017 3:16:40 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2
11/19/2017 3:16:40 PM> EMMC Manufacture Name: SKHYNIX
11/19/2017 3:16:40 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
11/19/2017 3:16:40 PM> EMMC Manufacture Date: 5/2015 , Rev: 07
11/19/2017 3:16:40 PM> EMMC NAME: H8G1e , , rev. 07
11/19/2017 3:16:40 PM> EMMC NAME (HEX): 483847316505
11/19/2017 3:16:40 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
11/19/2017 3:16:40 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
11/19/2017 3:16:40 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
11/19/2017 3:16:40 PM> EMMC Permanent Write Protection: No
11/19/2017 3:16:40 PM> EMMC Temporary Write Protection: No
11/19/2017 3:16:40 PM> Extended CSD Information :
11/19/2017 3:16:40 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
11/19/2017 3:16:40 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
11/19/2017 3:16:40 PM> Boot Bus Config: 0x00 , width 1bit
11/19/2017 3:16:40 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
11/19/2017 3:16:40 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
11/19/2017 3:16:40 PM> Device supports partitioning features
11/19/2017 3:16:41 PM> Device can have enhanced technological features in partitions and user data area
11/19/2017 3:16:41 PM> Device can have extended partitions attribute
11/19/2017 3:16:41 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
11/19/2017 3:16:41 PM> Backup saved: H8G1e_CA16911A_20171119_151641.extcsd
11/19/2017 3:16:41 PM> EMMC Init completed.
11/19/2017 3:16:45 PM> Looking for EasyJTAG box...
11/19/2017 3:16:45 PM> EasyJTAG API ver. 2008
11/19/2017 3:16:45 PM> Setting IO Levels to 3.3V
11/19/2017 3:16:45 PM> Setting frequence to 14 Mhz
11/19/2017 3:16:45 PM> HiPower mode is OFF
11/19/2017 3:16:46 PM> OpenUSB returned = 0
11/19/2017 3:16:46 PM> Power Controller returned = 0
11/19/2017 3:16:47 PM> EasyJTAG Box Serial = 0200402021DF307E
11/19/2017 3:16:47 PM> EasyJTAG Box Firmware = 01.58
11/19/2017 3:16:47 PM> HiPower mode is OFF
11/19/2017 3:16:48 PM> Frequence: 14 Mhz
11/19/2017 3:16:48 PM> CMD Pullup Level: 3104 mV
11/19/2017 3:16:48 PM> CMD Active Level: 3227 mV
11/19/2017 3:16:48 PM> eMMC Init returned = 0
11/19/2017 3:16:48 PM> EMMC Device Information :
11/19/2017 3:16:48 PM> EMMC CID: 90014A48384731650507CA16911A5210
11/19/2017 3:16:48 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2
11/19/2017 3:16:48 PM> EMMC Manufacture Name: SKHYNIX
11/19/2017 3:16:48 PM> EMMC Manufacture ID: 0x90 , OEM ID: 014A
11/19/2017 3:16:48 PM> EMMC Manufacture Date: 5/2015 , Rev: 07
11/19/2017 3:16:48 PM> EMMC NAME: H8G1e , S/N: CA16911A , rev. 07
11/19/2017 3:16:48 PM> EMMC NAME (HEX): 483847316505
11/19/2017 3:16:48 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
11/19/2017 3:16:48 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
11/19/2017 3:16:48 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
11/19/2017 3:16:48 PM> EMMC Permanent Write Protection: No
11/19/2017 3:16:48 PM> EMMC Temporary Write Protection: No
11/19/2017 3:16:48 PM> Extended CSD Information :
11/19/2017 3:16:48 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
11/19/2017 3:16:48 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
11/19/2017 3:16:48 PM> Boot Bus Config: 0x00 , width 1bit
11/19/2017 3:16:48 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
11/19/2017 3:16:48 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
11/19/2017 3:16:48 PM> Device supports partitioning features
11/19/2017 3:16:48 PM> Device can have enhanced technological features in partitions and user data area
11/19/2017 3:16:48 PM> Device can have extended partitions attribute
11/19/2017 3:16:48 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
11/19/2017 3:16:48 PM> Backup saved: H8G1e_CA16911A_20171119_151648.extcsd
11/19/2017 3:16:48 PM> EMMC Init completed.
11/19/2017 3:16:48 PM> Operation: Write by vendor (Qualcomm/HiSilicon)
11/19/2017 3:16:48 PM> Creating GPT-partitioninig
11/19/2017 3:16:48 PM> GPT-partitioning done
11/19/2017 3:16:56 PM> Partition name: modem
11/19/2017 3:16:56 PM> Filename: NON-HLOS.bin , Offset: 000002000000 , filesize: 47793664 bytes
11/19/2017 3:16:56 PM> eMMC switching to ROM1
11/19/2017 3:16:56 PM> Erasing partition...
11/19/2017 3:17:02 PM> Writing partition...
11/19/2017 3:18:01 PM> Done writing partition. Write speed: 787.56 Kb/s
11/19/2017 3:18:01 PM> Partition name: sbl1
11/19/2017 3:18:01 PM> Filename: sbl1.mbn , Offset: 000006000000 , filesize: 250664 bytes
11/19/2017 3:18:01 PM> eMMC switching to ROM1
11/19/2017 3:18:02 PM> Erasing partition...
11/19/2017 3:18:02 PM> Writing partition...
11/19/2017 3:18:03 PM> Done writing partition. Write speed: 682.21 Kb/s
11/19/2017 3:18:03 PM> Partition name: sbl1bak
11/19/2017 3:18:03 PM> Filename: sbl1.mbn , Offset: 000006080000 , filesize: 250664 bytes
11/19/2017 3:18:03 PM> eMMC switching to ROM1
11/19/2017 3:18:03 PM> Erasing partition...
11/19/2017 3:18:03 PM> Writing partition...
11/19/2017 3:18:04 PM> Done writing partition. Write speed: 694.56 Kb/s
11/19/2017 3:18:04 PM> Partition name: aboot
11/19/2017 3:18:04 PM> Filename: emmc_appsboot.mbn , Offset: 000006100000 , filesize: 2255244 bytes
11/19/2017 3:18:04 PM> eMMC switching to ROM1
11/19/2017 3:18:04 PM> Erasing partition...
11/19/2017 3:18:06 PM> Writing partition...
11/19/2017 3:18:08 PM> Done writing partition. Write speed: 919.20 Kb/s
11/19/2017 3:18:08 PM> Partition name: abootbak
11/19/2017 3:18:08 PM> Filename: emmc_appsboot.mbn , Offset: 000007000000 , filesize: 2255244 bytes
11/19/2017 3:18:08 PM> eMMC switching to ROM1
11/19/2017 3:18:09 PM> Erasing partition...
11/19/2017 3:18:10 PM> Writing partition...
11/19/2017 3:18:12 PM> Done writing partition. Write speed: 921.84 Kb/s
11/19/2017 3:18:12 PM> Partition name: rpm
11/19/2017 3:18:12 PM> Filename: rpm.mbn , Offset: 000007F00000 , filesize: 150848 bytes
11/19/2017 3:18:12 PM> eMMC switching to ROM1
11/19/2017 3:18:13 PM> Erasing partition...
11/19/2017 3:18:13 PM> Writing partition...
11/19/2017 3:18:14 PM> Done writing partition. Write speed: 643.30 Kb/s
11/19/2017 3:18:14 PM> Partition name: rpmbak
11/19/2017 3:18:14 PM> Filename: rpm.mbn , Offset: 000007F80000 , filesize: 150848 bytes
11/19/2017 3:18:14 PM> eMMC switching to ROM1
11/19/2017 3:18:14 PM> Erasing partition...
11/19/2017 3:18:14 PM> Writing partition...
11/19/2017 3:18:15 PM> Done writing partition. Write speed: 640.21 Kb/s
11/19/2017 3:18:15 PM> Partition name: tz
11/19/2017 3:18:15 PM> Filename: tz.mbn , Offset: 000008000000 , filesize: 387016 bytes
11/19/2017 3:18:15 PM> eMMC switching to ROM1
11/19/2017 3:18:15 PM> Erasing partition...
11/19/2017 3:18:16 PM> Writing partition...
11/19/2017 3:18:16 PM> Done writing partition. Write speed: 853.03 Kb/s
11/19/2017 3:18:16 PM> Partition name: tzbak
11/19/2017 3:18:16 PM> Filename: tz.mbn , Offset: 000008080000 , filesize: 387016 bytes
11/19/2017 3:18:16 PM> eMMC switching to ROM1
11/19/2017 3:18:16 PM> Erasing partition...
11/19/2017 3:18:17 PM> Writing partition...
11/19/2017 3:18:17 PM> Done writing partition. Write speed: 854.77 Kb/s
11/19/2017 3:18:17 PM> Partition name: hyp
11/19/2017 3:18:17 PM> Filename: hyp.mbn , Offset: 000008100000 , filesize: 20520 bytes
11/19/2017 3:18:17 PM> eMMC switching to ROM1
11/19/2017 3:18:18 PM> Erasing partition...
11/19/2017 3:18:18 PM> Writing partition...
11/19/2017 3:18:18 PM> Done writing partition. Write speed: 263.36 Kb/s
11/19/2017 3:18:18 PM> Partition name: hypbak
11/19/2017 3:18:18 PM> Filename: hyp.mbn , Offset: 000008180000 , filesize: 20520 bytes
11/19/2017 3:18:18 PM> eMMC switching to ROM1
11/19/2017 3:18:19 PM> Erasing partition...
11/19/2017 3:18:19 PM> Writing partition...
11/19/2017 3:18:19 PM> Done writing partition. Write speed: 263.08 Kb/s
11/19/2017 3:18:19 PM> Partition name: modemst1
11/19/2017 3:18:19 PM> Filename: dummy.bin , Offset: 000008300000 , filesize: 1572864 bytes
11/19/2017 3:18:19 PM> eMMC switching to ROM1
11/19/2017 3:18:20 PM> Erasing partition...
11/19/2017 3:18:20 PM> Writing partition...
11/19/2017 3:18:22 PM> Done writing partition. Write speed: 1393.93 Kb/s
11/19/2017 3:18:22 PM> Partition name: modemst2
11/19/2017 3:18:22 PM> Filename: dummy.bin , Offset: 000008480000 , filesize: 1572864 bytes
11/19/2017 3:18:22 PM> eMMC switching to ROM1
11/19/2017 3:18:22 PM> Erasing partition...
11/19/2017 3:18:22 PM> Writing partition...
11/19/2017 3:18:24 PM> Done writing partition. Write speed: 1393.22 Kb/s
11/19/2017 3:18:24 PM> Partition name: misc
11/19/2017 3:18:24 PM> Filename: MISC.img , Offset: 000008600000 , filesize: 1048576 bytes
11/19/2017 3:18:24 PM> eMMC switching to ROM1
11/19/2017 3:18:24 PM> Erasing partition...
11/19/2017 3:18:25 PM> Writing partition...
11/19/2017 3:18:25 PM> Done writing partition. Write speed: 1381.41 Kb/s
11/19/2017 3:18:25 PM> Partition name: fsg
11/19/2017 3:18:25 PM> Filename: nv.tar.mbn , Offset: 00000A008000 , filesize: 77608 bytes
11/19/2017 3:18:25 PM> eMMC switching to ROM1
11/19/2017 3:18:26 PM> Erasing partition...
11/19/2017 3:18:26 PM> Writing partition...
11/19/2017 3:18:26 PM> Done writing partition. Write speed: 507.58 Kb/s
11/19/2017 3:18:26 PM> Partition name: sec
11/19/2017 3:18:26 PM> Filename: sec.dat , Offset: 00000A188000 , filesize: 428 bytes
11/19/2017 3:18:26 PM> eMMC switching to ROM1
11/19/2017 3:18:27 PM> Erasing partition...
11/19/2017 3:18:27 PM> Writing partition...
11/19/2017 3:18:27 PM> Done writing partition. Write speed: 17.87 Kb/s
11/19/2017 3:18:27 PM> Partition name: boot
11/19/2017 3:18:27 PM> Filename: boot.img , Offset: 00000A18C000 , filesize: 8366080 bytes
11/19/2017 3:18:27 PM> eMMC switching to ROM1
11/19/2017 3:18:28 PM> Erasing partition...
11/19/2017 3:18:30 PM> Writing partition...
11/19/2017 3:18:40 PM> Done writing partition. Write speed: 781.76 Kb/s
11/19/2017 3:18:40 PM> Partition name: params
11/19/2017 3:18:40 PM> Filename: param.bin , Offset: 00000C000000 , filesize: 10752 bytes
11/19/2017 3:18:40 PM> eMMC switching to ROM1
11/19/2017 3:18:40 PM> Erasing partition...
11/19/2017 3:18:41 PM> Writing partition...
11/19/2017 3:18:41 PM> Done writing partition. Write speed: 265.53 Kb/s
11/19/2017 3:18:41 PM> Partition name: panic
11/19/2017 3:18:41 PM> Filename: panic.img , Offset: 00000C100000 , filesize: 4579328 bytes
11/19/2017 3:18:41 PM> eMMC switching to ROM1
11/19/2017 3:18:41 PM> Erasing partition...
11/19/2017 3:18:43 PM> Writing partition...
11/19/2017 3:18:46 PM> Done writing partition. Write speed: 1383.32 Kb/s
11/19/2017 3:18:46 PM> Partition name: system
11/19/2017 3:18:46 PM> Filename: system.img , Offset: 00000E000000 , filesize: 1509090124 bytes
11/19/2017 3:18:46 PM> eMMC switching to ROM1
11/19/2017 3:18:47 PM> Erasing partition...
11/19/2017 3:21:04 PM> Writing partition...
11/19/2017 3:21:05 PM> Sparse image found v.1.0 Total chunks: 3140
11/19/2017 3:53:31 PM> Done writing partition. Write speed: 757.24 Kb/s
11/19/2017 3:53:31 PM> Partition name: persist
11/19/2017 3:53:31 PM> Filename: persist.img , Offset: 00008E000000 , filesize: 4427960 bytes
11/19/2017 3:53:31 PM> eMMC switching to ROM1
11/19/2017 3:53:31 PM> Erasing partition...
11/19/2017 3:53:33 PM> Writing partition...
11/19/2017 3:53:33 PM> Sparse image found v.1.0 Total chunks: 13
11/19/2017 3:53:36 PM> Done writing partition. Write speed: 1250.77 Kb/s
11/19/2017 3:53:36 PM> Partition name: cache
11/19/2017 3:53:36 PM> Filename: cache.img , Offset: 00008EA00000 , filesize: 6348948 bytes
11/19/2017 3:53:36 PM> eMMC switching to ROM1
11/19/2017 3:53:36 PM> Erasing partition...
11/19/2017 3:53:45 PM> Writing partition...
11/19/2017 3:53:45 PM> Sparse image found v.1.0 Total chunks: 10
11/19/2017 3:53:50 PM> Done writing partition. Write speed: 1328.07 Kb/s
11/19/2017 3:53:50 PM> Partition name: recovery
11/19/2017 3:53:50 PM> Filename: recovery.img , Offset: 000096A00000 , filesize: 8953856 bytes
11/19/2017 3:53:50 PM> eMMC switching to ROM1
11/19/2017 3:53:50 PM> Erasing partition...
11/19/2017 3:53:52 PM> Writing partition...
11/19/2017 3:54:03 PM> Done writing partition. Write speed: 783.59 Kb/s
11/19/2017 3:54:03 PM> Partition name: userdata
11/19/2017 3:54:03 PM> Filename: userdata.img , Offset: 000097E00000 , filesize: 259079868 bytes
11/19/2017 3:54:03 PM> eMMC switching to ROM1
11/19/2017 3:54:04 PM> Erasing partition...
11/19/2017 3:59:36 PM> Writing partition...
11/19/2017 3:59:36 PM> Sparse image found v.1.0 Total chunks: 312
11/19/2017 4:04:11 PM> Done writing partition. Write speed: 920.88 Kb/s
11/19/2017 4:04:11 PM> All done
DONE
Old 11-20-2017, 11:26   #3 (permalink)
Member: 1623444
Originally Posted by unlocker_007 View Post
hi there
Emmc adaptor pic plzzz send me
Sent from my iPhone using Tapatalk
Page generated in 0.27430 seconds with 7 queries
