08-21-2018, 15:00 | #5 (permalink) |
No Life Poster Join Date: Dec 2005 Location: malaysia Age: 41
Member: 205283 Status: Offline Thanks Meter: 80 | i remove emmc ic and connect with e-socket: Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 42 Mhz EMMC Device Information : EMMC CID: 150100523331314D420067A8D6B7C175 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: R311MB , HEX: 523331314D42 , S/N: xxxxxxxxxx, rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2014 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: R311MB_67A8D6B7_20180821_215654.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000 (15.0 MB) Partition: modem, [000001300000 - 000004C70000], size: 000003970000 (57.4 MB) Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000 (512. KB) Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000 (32.0 KB) Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000 (2.00 MB) Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000 (512. KB) Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000 (512. KB) Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000 (512. KB) Partition: fsg, [000005078000 - 000005378000], size: 000000300000 (3.00 MB) Partition: sec, [000005378000 - 00000537C000], size: 000000004000 (16.0 KB) Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000 (10.5 MB) Partition: param, [000005E00000 - 000006800000], size: 000000A00000 (10.0 MB) Partition: efs, [000006800000 - 000007600000], size: 000000E00000 (14.0 MB) Partition: modemst1, [000007600000 - 000007900000], size: 000000300000 (3.00 MB) Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000 (3.00 MB) Partition: boot, [000007C00000 - 000008900000], size: 000000D00000 (13.0 MB) Partition: recovery, [000008900000 - 000009800000], size: 000000F00000 (15.0 MB) Partition: fota, [000009800000 - 00000A4FF400], size: 000000CFF400 (13.0 MB) Partition: backup, [00000A4FF400 - 00000ABFD000], size: 0000006FDC00 (6.99 MB) Partition: fsc, [00000ABFD000 - 00000AEFD000], size: 000000300000 (3.00 MB) Partition: ssd, [00000AEFD000 - 00000AEFF000], size: 000000002000 (8.00 KB) Partition: persist, [00000AEFF000 - 00000B6FF000], size: 000000800000 (8.00 MB) Partition: persdata, [00000B6FF000 - 00000BFFF000], size: 000000900000 (9.00 MB) Partition: system, [00000BFFF000 - 00009BBFF000], size: 00008FC00000 (2.25 GB) Partition: cache, [00009BBFF000 - 0000AE7FF000], size: 000012C00000 (300. MB) Partition: hidden, [0000AE7FF000 - 0000B23FF000], size: 000003C00000 (60.0 MB) Partition: userdata, [0000B23FF000 - 0003AB3FBE00], size: 0002F8FFCE00 (11.8 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-A500F Phone platform = msm8916 CPU Abi = armeabi-v7a Android release = 6.0.1 Firmware version = MMB29M.A500FXXS1CQC5 Firmware date = Fri Mar 24 17:28:17 KST 2017 i download SM-A500F(LRX22G.A500FXXU1BOH4-5.0.2-LRX22G)[R311MB],how to use this file?where to put this file flash? |
08-21-2018, 18:09 | #6 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | If no connecting at ISP with 1,8 and 2,8v, try to connect via Hi-Power CLK mode with USB power and without 1,8 and 2,8v lines Quote:
2) Use eMMC_Tool Shuite 1.5.2 and write by vendor original firmware like this Last edited by layder; 08-21-2018 at 18:14. | |
The Following User Says Thank You to layder For This Useful Post: |
