Coolpad Dazen1 8297l-100 11% Error Solved By easy jtag JUST CONNCET EMMC AND WATC VIDEO |
bro emmc reapir file link help me |
Sir I have tried on 3 sets but no one's emmc has benn detected by easy jtag. please help......................... |
Sir problem solved. The power supply of my emmc adapter was bad.so i changed my adapter and problem solved. One more thing. After following your process imei of set becomes zero. Though i repaired imei but can i keep the imei of this set during this procedure??? |
Coolpad Dazen1 8297l-100 11% Error PROBLEM PLEASE HELP ME Coolpad Dazen1 8297l-100 11% Error PROBLEM I AM TRY EASY JTAG BOX BUT EMMC CONNECTION PROBLEM, Compression is ON Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 0A001019F1234785, ,FW Ver.: 01.62 CMD Pullup Level:1722 mV CMD Active Level:11830 mV Box IO Level:1850 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. I AM BUY NEW JTAG ADAPTER BUT MY PROBLEM NOT SOLVE PLASE HELP https://s5.postimg.org/ozqsvyf6v/WP_..._25_05_Pro.jpghttps://s5.postimg.org/4flyxgk07/WP_..._24_51_Pro.jpg |
Sir my problem is emmc not connect jtag always cmd time out error |
https://*********/YN_8MnYX7AE 100% tested me |
Sir link not working |
Sorry sorry sir link work thankx sir help for me |
https://*********/YN_8MnYX7AE SIR I AM TRY THIS PROCESS BUT SAME PROBLEM Compression is ON Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 0A001019F6043867, ,FW Ver.: 01.62 CMD Pullup Level:1732 mV CMD Active Level:11830 mV Box IO Level:1850 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. |
Try in easy jtag plus........................................ If fail plug usb jack for 5 sec then remove and connect............. Try and post result |
Sir my problem solve thnkx i am repair boot successful phone on but a new problem imei null i am full flashing ygdp tools but not solve please help me thanks |
