Old 08-26-2017, 09:28   #1 (permalink)
yuvraj9x2's Avatar
Member: 2213928
Thanks Meter: 440
Coolpad Dazen1 8297l-100 11% Error Solved By easy jtag
JUST CONNCET EMMC AND WATC VIDEO
http://www.youtube.com/watch?v=eDHVTMBKhJQ
https://www.youtube.com/watch?v=eDHVTMBKhJQ&fs=1&hd=1" width="858" height="508">https://www.youtube.com/watch?v=eDHVTMBKhJQ&fs=1&hd=1" />https://www.youtube.com/watch?v=eDHVTMBKhJQ">http://www.youtube.com/watch?v=https://www.youtube.com/watch?v=eDHVTMBKhJQ
The Following 3 Users Say Thank You to yuvraj9x2 For This Useful Post:
Old 09-02-2017, 18:47   #2 (permalink)
Member: 2557144
bro emmc reapir file link
help me
Old 11-22-2017, 14:40   #3 (permalink)
Member: 1001635
Thanks Meter: 63
Sir I have tried on 3 sets but no one's emmc has benn detected by easy jtag.
please help.........................
Old 11-23-2017, 06:38   #4 (permalink)
yuvraj9x2's Avatar
Member: 2213928
Thanks Meter: 440
Read same basic info about easy jtag post same sceen shot what eorro come
Old 11-25-2017, 14:12   #5 (permalink)
Member: 1001635
Thanks Meter: 63
Sir
problem solved. The power supply of my emmc adapter was bad.so i changed my adapter and problem solved.
One more thing.
After following your process imei of set becomes zero. Though i repaired imei but can i keep the imei of this set during this procedure???
Old 12-28-2017, 09:19   #6 (permalink)
Member: 2620337
Thanks Meter: 13
Coolpad Dazen1 8297l-100 11% Error PROBLEM PLEASE HELP ME
Coolpad Dazen1 8297l-100 11% Error PROBLEM I AM TRY EASY JTAG BOX
BUT EMMC CONNECTION PROBLEM,
Compression is ON
Z3X EasyJtag Software ver. 2.9.0.0
Loading eMMC GEN1 Firmware... IO: 1850 mV
Box S/N: 0A001019F1234785, ,FW Ver.: 01.62
CMD Pullup Level:1722 mV
CMD Active Level:11830 mV
Box IO Level:1850 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
Done.
I AM BUY NEW JTAG ADAPTER BUT MY PROBLEM NOT SOLVE PLASE HELP
Old 12-29-2017, 05:39   #7 (permalink)
mridulnandy's Avatar
Member: 1134419
Sonork: 100.1621725
Thanks Meter: 452
http://forum.gsmhosting.com/vbb/f672...-jtag-2257982/
Old 12-29-2017, 14:36   #8 (permalink)
Member: 2620337
Thanks Meter: 13
Sir my problem is emmc not connect jtag always cmd time out error
Old 12-29-2017, 18:32   #9 (permalink)
Member: 2343170
Thanks Meter: 50
Arrow
Compression is ON
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
https://*********/YN_8MnYX7AE
100% tested me
Old 12-30-2017, 07:11   #10 (permalink)
Member: 2620337
Thanks Meter: 13
Sir link not working
Old 12-30-2017, 07:23   #11 (permalink)
Member: 2620337
Thanks Meter: 13
Sorry sorry sir link work thankx
sir help for me
Old 12-31-2017, 06:52   #12 (permalink)
Member: 2620337
Thanks Meter: 13
SIR I AM TRY THIS PROCESS BUT SAME PROBLEM
Compression is ON
Box S/N: 0A001019F6043867, ,FW Ver.: 01.62
CMD Pullup Level:1732 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
Old 01-02-2018, 11:05   #13 (permalink)
Member: 1001635
Thanks Meter: 63
Try in easy jtag plus........................................
If fail plug usb jack for 5 sec then remove and connect.............
Try and post result
Old 01-02-2018, 15:44   #14 (permalink)
Member: 2620337
Thanks Meter: 13
Sir my problem solve thnkx
i am repair boot successful phone on
but a new problem imei null
i am full flashing ygdp tools but not solve
please help me thanks
Old 01-02-2018, 15:47   #15 (permalink)
Member: 2644678
Sonork: 100.1685569
Thanks Meter: 33
Compression is ON
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
Flash with Qfil tool 100% done boot repair and again flash YGPD tool
The Following User Says Thank You to M Osman For This Useful Post:
Page generated in 0.26720 seconds with 9 queries
