03-12-2018, 16:35 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Coolpad dozen 1 boot repair done Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 1788 mV CMD Active Level: 1882 mV EMMC Device Information : EMMC CID: 90014A4838473165050756D288A75231 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G1e , EMMC NAME (HEX): 483847316500 , S/N: 56D288A7 , rev. 0x07 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G1e_56D288A7_20180312_151832.extcsd EMMC Init completed. Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 1787 mV CMD Active Level: 1883 mV EMMC Device Information : EMMC CID: 90014A4838473165050756D288A75231 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G1e , EMMC NAME (HEX): 483847316500 , S/N: 56D288A7 , rev. 0x07 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G1e_56D288A7_20180312_152732.extcsd EMMC Init completed. Operation: Erasing partitions Partition name: modem , offset: 000002000000 , size: 000004000000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: sbl1 , offset: 000006000000 , size: 000000080000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: sbl1bak , offset: 000006080000 , size: 000000080000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: aboot , offset: 000006100000 , size: 000000F00000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: abootbak , offset: 000007000000 , size: 000000F00000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: rpm , offset: 000007F00000 , size: 000000080000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: rpmbak , offset: 000007F80000 , size: 000000080000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: tz , offset: 000008000000 , size: 000000080000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: tzbak , offset: 000008080000 , size: 000000080000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: hyp , offset: 000008100000 , size: 000000080000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: hypbak , offset: 000008180000 , size: 000000080000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: modemst1 , offset: 000008300000 , size: 000000180000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: modemst2 , offset: 000008480000 , size: 000000180000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: misc , offset: 000008600000 , size: 000000100000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: fsg , offset: 00000A008000 , size: 000000180000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: sec , offset: 00000A188000 , size: 000000004000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: boot , offset: 00000A18C000 , size: 000001400000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: params , offset: 00000C000000 , size: 000000100000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: panic , offset: 00000C100000 , size: 000001400000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: system , offset: 00000E000000 , size: 000080000000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: persist , offset: 00008E000000 , size: 000000A00000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: cache , offset: 00008EA00000 , size: 000008000000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: recovery , offset: 000096A00000 , size: 000001400000 eMMC switching to ROM1 Erasing partition... Done erasing partition. Partition name: userdata , offset: 000097E00000 , size: 00003A1FBE00 eMMC switching to ROM1 Erasing partition... Done erasing partition. All done Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 1785 mV CMD Active Level: 1884 mV EMMC Device Information : EMMC CID: 90014A4838473165050756D288A75231 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G1e , EMMC NAME (HEX): 483847316500 , S/N: 56D288A7 , rev. 0x07 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G1e_56D288A7_20180312_153403.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon) Creating GPT-partitioninig GPT-partitioning done Partition name: modem Filename: NON-HLOS.bin , Offset: 000002000000 , filesize: 47793664 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1355.75 KB/s Partition name: sbl1 Filename: sbl1.mbn , Offset: 000006000000 , filesize: 250664 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1227.19 KB/s Partition name: sbl1bak Filename: sbl1.mbn , Offset: 000006080000 , filesize: 250664 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1225.92 KB/s Partition name: aboot Filename: emmc_appsboot.mbn , Offset: 000006100000 , filesize: 2255244 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1373.64 KB/s Partition name: abootbak Filename: emmc_appsboot.mbn , Offset: 000007000000 , filesize: 2255244 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1347.31 KB/s Partition name: rpm Filename: rpm.mbn , Offset: 000007F00000 , filesize: 150848 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 967.27 KB/s Partition name: rpmbak Filename: rpm.mbn , Offset: 000007F80000 , filesize: 150848 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 963.64 KB/s Partition name: tz Filename: tz.mbn , Offset: 000008000000 , filesize: 387016 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1227.17 KB/s Partition name: tzbak Filename: tz.mbn , Offset: 000008080000 , filesize: 387016 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1225.34 KB/s Partition name: hyp Filename: hyp.mbn , Offset: 000008100000 , filesize: 20520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 460.33 KB/s Partition name: hypbak Filename: hyp.mbn , Offset: 000008180000 , filesize: 20520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 460.91 KB/s Partition name: modemst1 Filename: dummy.bin , Offset: 000008300000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1411.50 KB/s Partition name: modemst2 Filename: dummy.bin , Offset: 000008480000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1412.85 KB/s Partition name: misc Filename: MISC.img , Offset: 000008600000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1390.04 KB/s Partition name: fsg Filename: nv.tar.mbn , Offset: 00000A008000 , filesize: 77608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 720.30 KB/s Partition name: sec Filename: sec.dat , Offset: 00000A188000 , filesize: 428 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 35.96 KB/s Partition name: boot Filename: boot.img , Offset: 00000A18C000 , filesize: 8366080 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1404.68 KB/s Partition name: params Filename: param.bin , Offset: 00000C000000 , filesize: 10752 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 431.18 KB/s Partition name: panic Filename: panic.img , Offset: 00000C100000 , filesize: 4579328 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1366.14 KB/s Partition name: persist Filename: persist.img , Offset: 00008E000000 , filesize: 4427960 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 13 Done writing partition. Write speed: 1152.13 KB/s Partition name: cache Filename: cache.img , Offset: 00008EA00000 , filesize: 6348948 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 10 Done writing partition. Write speed: 1340.05 KB/s Partition name: recovery Filename: recovery.img , Offset: 000096A00000 , filesize: 8953856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1408.83 KB/s All done time: [00:01:38:374] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 12 Mhz CMD Pullup Level: 1784 mV CMD Active Level: 1884 mV EMMC Device Information : EMMC CID: 90014A4838473165050756D288A75231 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G1e , EMMC NAME (HEX): 483847316500 , S/N: 56D288A7 , rev. 0x07 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G1e_56D288A7_20180312_153546.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: modem, [000002000000 - 000006000000], size: 000004000000 Partition: sbl1, [000006000000 - 000006080000], size: 000000080000 Partition: sbl1bak, [000006080000 - 000006100000], size: 000000080000 Partition: aboot, [000006100000 - 000007000000], size: 000000F00000 Partition: abootbak, [000007000000 - 000007F00000], size: 000000F00000 Partition: rpm, [000007F00000 - 000007F80000], size: 000000080000 Partition: rpmbak, [000007F80000 - 000008000000], size: 000000080000 Partition: tz, [000008000000 - 000008080000], size: 000000080000 Partition: tzbak, [000008080000 - 000008100000], size: 000000080000 Partition: hyp, [000008100000 - 000008180000], size: 000000080000 Partition: hypbak, [000008180000 - 000008200000], size: 000000080000 Partition: pad, [000008200000 - 000008300000], size: 000000100000 Partition: modemst1, [000008300000 - 000008480000], size: 000000180000 Partition: modemst2, [000008480000 - 000008600000], size: 000000180000 Partition: misc, [000008600000 - 000008700000], size: 000000100000 Partition: fsc, [000008700000 - 000008700400], size: 000000000400 Partition: ssd, [000008700400 - 000008702400], size: 000000002000 Partition: DDR, [00000A000000 - 00000A008000], size: 000000008000 Partition: fsg, [00000A008000 - 00000A188000], size: 000000180000 Partition: sec, [00000A188000 - 00000A18C000], size: 000000004000 Partition: boot, [00000A18C000 - 00000B58C000], size: 000001400000 Partition: params, [00000C000000 - 00000C100000], size: 000000100000 Partition: panic, [00000C100000 - 00000D500000], size: 000001400000 Partition: autobak, [00000D500000 - 00000DF00000], size: 000000A00000 Partition: system, [00000E000000 - 00008E000000], size: 000080000000 Partition: persist, [00008E000000 - 00008EA00000], size: 000000A00000 Partition: cache, [00008EA00000 - 000096A00000], size: 000008000000 Partition: recovery, [000096A00000 - 000097E00000], size: 000001400000 Partition: userdata, [000097E00000 - 0001D1FFBE00], size: 00013A1FBE00 GPT header successfully parsed |
The Following 2 Users Say Thank You to royalnasim For This Useful Post: |
