Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2010 Age: 34
Member: 1418143 Status: Offline Thanks Meter: 341 | CPH1803 dead by other tool I d like fix by easy ; is the log below is correct ? I get error when I try to write Boot1/2/3 Quote:
![]() | #2 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1865744 Status: Offline Thanks Meter: 3 | try to reduce the frequency of low frequence to see if the error still occurs from 4-12 mhz https://www.youtube.com/watch?v=KQTSoyZ1xLw&t=603s |
The Following User Says Thank You to ladyvu_168 For This Useful Post: |
![]() | #4 (permalink) | |||
Member: 1418143 Status: Offline Thanks Meter: 341 | till getting error , Quote:
Operation: Reading from eMMC... Quote:
![]() | #6 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2002 Location: Belarus Age: 43
Member: 13148 Status: Offline Thanks Meter: 1,388 | Hi Power mode: 1) for OLD Box (COLOR box) with 1.xx box firmware Short 4 CLK wires together Set Clk rate 21/14MHz Set IO level 2,8/1.8V Set "HiPower CLK mode" Connect to board only GND, CMD/CLK/Dat_0 Connect USB power to board 2) for NEW Box (Black-White box) with 2.xx box firmware Use complect ISP adapter (use 1 line CLK) Set Clk rate 18/24MHz Set IO level 1.8V Set "HiPower CLK mode" Connect to board only GND, CMD/CLK/Dat_0 Connect USB power to board Last edited by layder; 11-26-2019 at 21:05. |
The Following User Says Thank You to layder For This Useful Post: |
![]() | #7 (permalink) | |
Member: 1418143 Status: Offline Thanks Meter: 341 | Quote:
OK I try and let you know thank | |
![]() | #8 (permalink) | |
Member: 1418143 Status: Offline Thanks Meter: 341 | is my info is correct ? I have GPT issu how can I fix it ? none write operation is accepted , with all giving setting Quote:
![]() | #10 (permalink) | |
Member: 1418143 Status: Offline Thanks Meter: 341 | how to fix that ? Quote:
