Old 04-25-2014, 16:38   #31 (permalink)
Registered User
Member: 986203
Sonork: 100.1663211
Thanks Meter: 12
htc desire v t328w after repair dead boot show
locked
primods pvt ship s-on rl
hboot-1.14.0001
redio-1.05.34d.29
emmc-boot
apr 30 2012:11:02:15
any solution easy jtag team pls help
Old 04-25-2014, 21:43   #32 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
locked
hboot-1.14.0001
redio-1.05.34d.29
emmc-boot
Unlock botloader by HTCDEV website and flash any custom firmware.
Old 04-26-2014, 07:24   #33 (permalink)
Registered User
Member: 986203
Sonork: 100.1663211
Thanks Meter: 12
pls post this ver firmware
Old 04-26-2014, 13:14   #34 (permalink)
Member: 683321
Thanks Meter: 23
Soft partition reading bug
Please fix soft partition reading in new version, screenshots :
Old 04-26-2014, 16:15   #35 (permalink)
..::Thanh_gsm::..'s Avatar
Member: 207400
Sonork: 100.1582556
Thanks Meter: 262
Great speed
Writing file...D:\MOBOSOFT\Thiet bi\EASY-JTAG\Easy Jtag files\SAMSUNG\E210K\Main_EMMC_00000000_20000000.bin
Z3X EasyJtag Software ver. 1.1.0.0
Skip loading eMMC Addon Firmware
CMD Pullup Level:2258 mV
CMD Active Level:2165 mV
Writing 000020000000 bytes to 00000000 ...ROM1
Write Speed: 868 kB/s
Done !!!
Writing file...D:\MOBOSOFT\Thiet bi\EASY-JTAG\Easy Jtag files\SAMSUNG\E160L\E160L_dump_4G_EMMC_32G\E160L_dump_4G_EMMC_32G
CMD Pullup Level:2763 mV
CMD Active Level:2763 mV
Writing 000100000000 bytes to 00000000 ...ROM1
Writing eMMC flash page stopped by user request
Writing file...D:\MOBOSOFT\Thiet bi\Riff box\Tong hop\Repair\Samsung\E160L\SHV-E160L_Work_Dump_FA09\SHV-E160L_Work_Dump_FA09.bin
Write Speed: 865 kB/s
Done !!!
Old 04-26-2014, 16:34   #36 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Will do that ;-) in next rev.
The Following 3 Users Say Thank You to NoName® For This Useful Post:
Old 04-26-2014, 17:07   #37 (permalink)
Registered User
Member: 986203
Sonork: 100.1663211
Thanks Meter: 12
Old 04-27-2014, 18:50   #38 (permalink)
tavo_unlock's Avatar
Member: 817412
Sonork: 1618066
Thanks Meter: 69
new version is good best z3x team
Old 04-28-2014, 13:21   #39 (permalink)
Member: 207400
Sonork: 100.1582556
Thanks Meter: 262
A770K repair ok, good speed.
Writing file...D:\MOBOSOFT\Thiet bi\Riff box\Tong hop\Repair\SKY\A770K 1G dump\a770k dump.bin
CMD Pullup Level:2691 mV
Writing 000040000000 bytes to 00000000 ...ROM1
Write Speed: 848 kB/s
Done !!!
Old 04-28-2014, 23:53   #40 (permalink)
Member: 1316129
Sonork: 2cb2c7e4b0cde9577335a8ff1
thanks team good work
Old 05-04-2014, 16:50   #41 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Hello , for 2x speed increase you may try use ver 1.3 from support or get here:
https://dl.dropboxusercontent.com/u/...e_v1.3.3.0.exe
We still testing improvements. Now write speed LITTLE INCREASED.
The Following User Says Thank You to NoName® For This Useful Post:
Old 05-05-2014, 14:11   #42 (permalink)
Member: 306671
Sonork: 100.1621692
Thanks Meter: 4
Can't init EMMC, Reason: CARD Data FIFO Timeout Error
Originally Posted by a65333002 View Post
Z3X EasyJtag Software ver. 1.1.0.1
Loading eMMC Addon Firmware...
Box S/N: 0707051BED842DAD, ,FW Ver.: 01.49
CMD Active Level:2774 mV
eMMC Device Information
EMMC CID : 15010056594C30304D19228C48D99E40
EMMC CSD : D02701320F5903FFF6DBFFEF8A404066
EMMC Manufacturer ID: 0000 , OEM ID: 0000
EMMC Date: 00/0000 Rev.0x0
EMMC NAME: , S/N: 0
Check Data Line !!!
i9100,before repair connect,i format samsung,format movinand,repair extcsd,and with error writing rom 1.
now cant connect
i face same problum in i9300.i fromat samsung,format movinand sucess but when i write rom 1 show emmc write adress error retry error show.
i think box firmare not good problum in new firmare & latest exe.
Old 05-05-2014, 18:27   #43 (permalink)
Member: 147039
Thanks Meter: 88
EMMC NAME: , S/N: 0
your emmc dead, replace it.
Old 05-06-2014, 08:48   #44 (permalink)
Member: 142949
Thanks Meter: 71
EMMC NAME: , S/N: 0
Check Data Line !!!
now cant connect
Z3X EasyJtag Software ver. 1.3.3.0
Loading eMMC Addon Firmware... IO: 2450 mV
Box S/N: 0D00401A1383xxxx, ,FW Ver.: 01.50
CMD Pullup Level:1897 mV
CMD Active Level:2248 mV
EMMC CID : 15010056594C30304D198F6D5DA06EB2
EMMC NAME: , S/N: 0
Check Data Line !!!
m250s
Old 05-06-2014, 10:48   #45 (permalink)
titanic's Avatar
Member: 63065
Sonork: 100.102547
Thanks Meter: 24
Excellent Speed
Loading eMMC Addon Firmware... IO: 1850 mV
Box S/N: 0606F80FA22B6D2F, ,FW Ver.: 01.50
Warning: CMD Pullup Level (1144 mV) too low , check cables etc.!!!
CMD Active Level:1536 mV
EMMC CID : 15010056545530304DF1844034AA9F5A
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 09/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 2218800298
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Backup saved: VTU00M_2218800298_20140402_1215.extcsd
Done.
Running:SAMSUNG: Smart Factory Reset + Format...
CMD Pullup Level:1144 mV
Sending Smart Wipe Request...
Wiping Card... Please do not touch it!!!
Done.
Please don't forget to repair extCSD from backup!!!
extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_2218800298_20140 402_1215.extcsd
Running:Repair extCSD...
Writing...
Done!
Done.
Warning: CMD Pullup Level (1134 mV) too low , check cables etc.!!!
Backup saved: VTU00M_2218800298_20140402_1217.extcsd
Done.
Writing file...D:\Phones\Easy Jtag\N7100\ROM2_GT-N7100_v2\EMMC_00000000_00200000.bin
CMD Pullup Level:1134 mV
Writing 000000200000 bytes to 00000000 ...ROM2
Write Speed: 1723 kB/s
Done !!!
BR,
The Following User Says Thank You to titanic For This Useful Post:
Page generated in 0.26905 seconds with 8 queries
