Old 05-15-2014, 12:02   #46 (permalink)
AhsanNawaz's Avatar
Member: 2081860
Sonork: 100.1608350
Thanks Meter: 128
Exclamation Need help
Originally Posted by titanic View Post
Z3X EasyJtag Software ver. 1.3.3.0
Loading eMMC Addon Firmware... IO: 1850 mV
Box S/N: 0606F80FA22B6D2F, ,FW Ver.: 01.50
Warning: CMD Pullup Level (1144 mV) too low , check cables etc.!!!
CMD Active Level:1536 mV
eMMC Device Information
EMMC CID : 15010056545530304DF1844034AA9F5A
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 09/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 2218800298
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Backup saved: VTU00M_2218800298_20140402_1215.extcsd
Done.
Running:SAMSUNG: Smart Factory Reset + Format...
Skip loading eMMC Addon Firmware
CMD Pullup Level:1144 mV
Sending Smart Wipe Request...
Wiping Card... Please do not touch it!!!
Done.
Please don't forget to repair extCSD from backup!!!
extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_2218800298_20140 402_1215.extcsd
Running:Repair extCSD...
Writing...
Done!
Done.
Warning: CMD Pullup Level (1134 mV) too low , check cables etc.!!!
Backup saved: VTU00M_2218800298_20140402_1217.extcsd
Done.
Writing file...D:\Phones\Easy Jtag\N7100\ROM2_GT-N7100_v2\EMMC_00000000_00200000.bin
CMD Pullup Level:1134 mV
Writing 000000200000 bytes to 00000000 ...ROM2
Write Speed: 1723 kB/s
Done !!!
BR,
hello i have same problem....can u help me.
Z3X EasyJtag Software ver. 1.3.4.3
Loading eMMC Addon Firmware... IO: 2450 mV
Box S/N: 1616070D14A51DC6, ,FW Ver.: 01.50
CMD Pullup Level:1485 mV
CMD Active Level:1784 mV
EMMC CID : 15010056545530304DF18F1145649FBA
EMMC Manufacturer ID: 0000 , OEM ID: 0000
EMMC Date: 00/0000 Rev.0x0
EMMC NAME: , S/N: 0
Can't init EMMC, Reason: CARD Data FIFO Timeout Error
Check Data Line !!!
Old 05-15-2014, 12:58   #47 (permalink)
Member: 540932
Thanks Meter: 36
EasyJtag Suite ver.: 1.3.4.3 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows 7 (build 7601, Service Pack 1).
Successefuly connected to box on COM7Box S/N: 18FF900BE3CD5E21, ,FW Ver.: 01.50Box Working Mode: JTAG Box.Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AAFA-E5F5 , ver: 22
CMD Pullup Level:1103 mV
CMD Active Level:1433 mV
EMMC CID : 15010056545530304DF156273F257FAC
EMMC Date: 07/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 1445412645
Backup saved: VTU00M_1445412645_20140404_1336.extcsd
Done.
Done.
Running:SAMSUNG: MoviNAND Format...
Sending Internal Reconfiguration Request...
Waiting configuration Apply!!!
Restoring configuration...
EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB
Done.
extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_1445412645_20140 404_1336.extcsd
Writing...
Done!
Done.
Writing file...D:\BOX-SETUP\J-TAG\EASY-JTAG\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM2_00000000_00200000.bin
Retry writing adress 0x00000000 (Attempt #1)...
Retry Fail !!!
Retry writing adress 0x00000000 (Attempt #2)...
Retry Fail !!!
Retry writing adress 0x00000000 (Attempt #3)...
Retry Fail !!!
Write Block Failed, Reason: DATA SND CRC Error
Writing file...D:\BOX-SETUP\J-TAG\EASY-JTAG\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM1_00000000_20000000.bin
Writing 000020000000 bytes to 00000000 ...ROM1
Retry Fail !!!
Retry Fail !!!
Retry Fail !!!
Old 05-15-2014, 13:19   #48 (permalink)
Member: 540932
Thanks Meter: 36
i notice that only s3 no:216 on EMMc and note2 no:219 and some time no:234 are working perfect for repairing dead boot and specially for product code at this moment i have no logs available but as soon available i post here. i almost done 30 mobiles S3 and 10 note2 mention above no on emmc.others not detected. i think this information help EASY JTAG team for improvement their software in next updates
Old 05-16-2014, 18:00   #49 (permalink)
dj.orion's Avatar
Member: 323742
Thanks Meter: 73
Can U explain more..
What meaning n where is no:216, 219 n 234, phisically seen or via log.?
I get N7100 dead for several times n facing can't do write to eMMC
But can do read n formating
eMMC became read only memory ...
Look at Ur log n mine, had same error in writing process
Is this positive eMMC totaly can't repaired.?
Successfully connected to box on COM69
Box S/N: XXXXXX, ,FW Ver.: 01.48
Z3X EasyJtag Software ver. 1.0.109.0
CMD Pullup Level:1639 mV
CMD Active Level:2310 mV
EMMC CID 15010056545530304DF104260B109F0B
EMMC CSD D02701320F5903FFF6DBFFFF8E40406D
EMMC Date: 09/2012 FW rev.0xf1
EMMC NAME: VTU00M , S/N: 69602064
EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card)
Writing 000000200000 bytes to 00000000 ...ROM3
Writing eMMC flash page stopped by user request
Old 05-16-2014, 19:40   #50 (permalink)
Member: 540932
Thanks Meter: 36
not in logs check at the top of right side on EMMc CHIP
Old 05-16-2014, 21:36   #51 (permalink)
tavo_unlock's Avatar
Member: 817412
Sonork: 1618066
Thanks Meter: 69
blang new version present fail in conecction tested in i9300 ?
Old 05-17-2014, 13:00   #52 (permalink)
Member: 540932
Thanks Meter: 36
Old 05-04-2015, 15:57   #53 (permalink)
Member: 1073769
Thanks Meter: 34
any body fcae this problem
Z3X EasyJtag Software ver. 1.9.0.5
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 04040217523E5ACE, ,FW Ver.: 01.52
CMD Pullup Level:1412 mV
CMD Active Level:2062 mV
EMMC CID : 1501004D4147344642F71C3E2EF8CFC2
EMMC Date: 12/2012 Rev.0xF7
EMMC NAME: MAG4FB , S/N: 473837304
EMMC NAME (HEX): 4D414734464200
Check Data Line!
Done.
Old 05-04-2015, 17:31   #54 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 171
Yes im facing it too after update to ver 2 other emmc box connect ok
Old 05-05-2015, 23:46   #55 (permalink)
Crazy Poster
Member: 1185263
Sonork: 030986
Thanks Meter: 19
Originally Posted by BABAK NURI View Post
Hi
Speed is like Jet....It's Great
hei... riff user need you, but you stand here. are you product suporter or just user???
The Following User Says Thank You to dimas_lumazank For This Useful Post:
Old 12-27-2015, 10:56   #56 (permalink)
Member: 1051866
Sonork: 100.1669165
Thanks Meter: 3
any on halp me
Z3X EasyJtag Software ver. 2.0.5.1
Loading eMMC Addon Firmware... IO: 3300 mV
Box S/N: 14007016C09E928B, ,FW Ver.: 01.52
CMD Pullup Level:2196 mV
CMD Active Level:2897 mV
EMMC CID : 1501004C3758484D4203A7BBBCACC09C
EMMC CSD : D02701320F5903FFF6DBFFEF8E406068
EMMC Date: 12/2013 Rev.0x3
EMMC NAME: L7XHMB , S/N: 2814098604
EMMC NAME (HEX): 4C3758484D4200
Check Data Line!
Old 04-21-2016, 07:48   #57 (permalink)
Member: 2491556
Thanks Meter: 2
Thank you
I found this post very helfull
Old 06-25-2016, 12:03   #58 (permalink)
alex_030385's Avatar
Member: 875541
Sonork: 100.1604468
Thanks Meter: 327
Z3X EasyJtag Software ver. 2.1.1.1
Box S/N: 0701001D36DA3BF9, ,FW Ver.: 01.55
CMD Pullup Level:1763 mV
CMD Active Level:2320 mV
Box IO Level:2800 mV
CLK Rate:1000 khz
HiPower™ mode is ON!
EMMC CID : 90014A4838473264040300A529EB11A2
EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2
EMMC Manufacturer ID: 0090 , OEM ID: 014A
EMMC Date: 01/2014 Rev.0x3
EMMC NAME: H8G2d , S/N: 10824171
EMMC NAME (HEX): 48384732642000
Check Data Line!
Done.
ihave also same problem fifo???
Old 10-10-2016, 14:52   #59 (permalink)
Niaz Hussain's Avatar
Member: 117640
Sonork: 100.1580505
Thanks Meter: 62
J110H/DS dead boot
Z3X EasyJtag Software ver. 2.3.0.1
Loading eMMC Addon Firmware... IO: 1800 mV
Box S/N:------------, ,FW Ver.: 01.55CMD Pullup Level:1619 mV
Box IO Level:1800 mV
CLK Rate:7000 khz
HiPower mode is off!
---------- eMMC Device Information ----------EMMC CID : 90014A483447326211012D26118F82BC
EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA
EMMC Date: 08/2015 Rev.0x1
EMMC NAME: H4G2b , S/N: 757469583
EMMC NAME (HEX): 48344732622000
Check Data Line!
Done.
Old 10-10-2016, 16:29   #60 (permalink)
Member: 257716
Sonork: 1650684
Thanks Meter: 57
Error (404)
We can't find the page you're looking for
Page generated in 0.27259 seconds with 8 queries
