05-15-2014, 12:02 | #46 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: England Manchester
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | Need help Quote:
hello i have same problem....can u help me. Z3X EasyJtag Software ver. 1.3.4.3 Loading eMMC Addon Firmware... IO: 2450 mV Box S/N: 1616070D14A51DC6, ,FW Ver.: 01.50 CMD Pullup Level:1485 mV CMD Active Level:1784 mV eMMC Device Information EMMC CID : 15010056545530304DF18F1145649FBA EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0000 , OEM ID: 0000 EMMC Date: 00/0000 Rev.0x0 EMMC NAME: , S/N: 0 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line !!! | |
05-15-2014, 12:58 | #47 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 540932 Status: Offline Thanks Meter: 36 | EasyJtag Suite ver.: 1.3.4.3 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7601, Service Pack 1). Successefuly connected to box on COM7Box S/N: 18FF900BE3CD5E21, ,FW Ver.: 01.50Box Working Mode: JTAG Box.Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AAFA-E5F5 , ver: 22 Z3X EasyJtag Software ver. 1.3.4.3 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 18FF900BE3CD5E21, ,FW Ver.: 01.50 CMD Pullup Level:1103 mV CMD Active Level:1433 mV eMMC Device Information EMMC CID : 15010056545530304DF156273F257FAC EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 1445412645 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_1445412645_20140404_1336.extcsd Done. Running:SAMSUNG: Smart Factory Reset + Format... Z3X EasyJtag Software ver. 1.3.4.3 Skip loading eMMC Addon Firmware CMD Pullup Level:1103 mV CMD Active Level:1433 mV Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! Running:SAMSUNG: MoviNAND Format... Z3X EasyJtag Software ver. 1.3.4.3 Skip loading eMMC Addon Firmware CMD Pullup Level:1103 mV CMD Active Level:1433 mV EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_1445412645_20140 404_1336.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 1.3.4.3 Skip loading eMMC Addon Firmware CMD Pullup Level:1103 mV CMD Active Level:1433 mV Writing... Done! Done. Please don't forget to repair extCSD from backup!!! Writing file...D:\BOX-SETUP\J-TAG\EASY-JTAG\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM2_00000000_00200000.bin Z3X EasyJtag Software ver. 1.3.4.3 Skip loading eMMC Addon Firmware CMD Pullup Level:1103 mV CMD Active Level:1433 mV Writing 000000200000 bytes to 00000000 ...ROM2 Retry writing adress 0x00000000 (Attempt #1)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #2)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #3)... Retry Fail !!! Write Block Failed, Reason: DATA SND CRC Error Writing file...D:\BOX-SETUP\J-TAG\EASY-JTAG\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM1_00000000_20000000.bin Z3X EasyJtag Software ver. 1.3.4.3 Skip loading eMMC Addon Firmware CMD Pullup Level:1103 mV CMD Active Level:1433 mV Writing 000020000000 bytes to 00000000 ...ROM1 Retry writing adress 0x00000000 (Attempt #1)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #2)... Retry Fail !!! Retry writing adress 0x00000000 (Attempt #3)... Retry Fail !!! Write Block Failed, Reason: DATA SND CRC Error |
05-15-2014, 13:19 | #48 (permalink) |
Member: 540932 Status: Offline Thanks Meter: 36 | i notice that only s3 no:216 on EMMc and note2 no:219 and some time no:234 are working perfect for repairing dead boot and specially for product code at this moment i have no logs available but as soon available i post here. i almost done 30 mobiles S3 and 10 note2 mention above no on emmc.others not detected. i think this information help EASY JTAG team for improvement their software in next updates |
05-16-2014, 18:00 | #49 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: 202.43.163.90
Member: 323742 Status: Offline Thanks Meter: 73 | Quote:
What meaning n where is no:216, 219 n 234, phisically seen or via log.? I get N7100 dead for several times n facing can't do write to eMMC But can do read n formating eMMC became read only memory ... Look at Ur log n mine, had same error in writing process Is this positive eMMC totaly can't repaired.? Code: Successfully connected to box on COM69 Box S/N: XXXXXX, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.109.0 Loading eMMC Addon Firmware... CMD Pullup Level:1639 mV CMD Active Level:2310 mV EMMC CID 15010056545530304DF104260B109F0B EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 69602064 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM3 Retry writing adress 0x00000000 Retry writing adress 0x00000000 Retry writing adress 0x00000000 Retry writing adress 0x00000000 Writing eMMC flash page stopped by user request | |
05-04-2015, 15:57 | #53 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1073769 Status: Offline Thanks Meter: 34 | any body fcae this problem Z3X EasyJtag Software ver. 1.9.0.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 04040217523E5ACE, ,FW Ver.: 01.52 CMD Pullup Level:1412 mV CMD Active Level:2062 mV eMMC Device Information EMMC CID : 1501004D4147344642F71C3E2EF8CFC2 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 Rev.0xF7 EMMC NAME: MAG4FB , S/N: 473837304 EMMC NAME (HEX): 4D414734464200 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. |
12-27-2015, 10:56 | #56 (permalink) |
Junior Member Join Date: Jun 2009 Location: Osmanabad.Mharastra.india
Member: 1051866 Status: Offline Sonork: 100.1669165 Thanks Meter: 3 | any on halp me Z3X EasyJtag Software ver. 2.0.5.1 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 14007016C09E928B, ,FW Ver.: 01.52 CMD Pullup Level:2196 mV CMD Active Level:2897 mV eMMC Device Information EMMC CID : 1501004C3758484D4203A7BBBCACC09C EMMC CSD : D02701320F5903FFF6DBFFEF8E406068 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2013 Rev.0x3 EMMC NAME: L7XHMB , S/N: 2814098604 EMMC NAME (HEX): 4C3758484D4200 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! |
06-25-2016, 12:03 | #58 (permalink) |
No Life Poster Join Date: Oct 2008 Age: 39
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | Z3X EasyJtag Software ver. 2.1.1.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0701001D36DA3BF9, ,FW Ver.: 01.55 CMD Pullup Level:1763 mV CMD Active Level:2320 mV Box IO Level:2800 mV CLK Rate:1000 khz HiPower™ mode is ON! eMMC Device Information EMMC CID : 90014A4838473264040300A529EB11A2 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 01/2014 Rev.0x3 EMMC NAME: H8G2d , S/N: 10824171 EMMC NAME (HEX): 48384732642000 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. ihave also same problem fifo??? |
10-10-2016, 14:52 | #59 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Pakistan Hyderabad Age: 40
Member: 117640 Status: Offline Sonork: 100.1580505 Thanks Meter: 62 | J110H/DS dead boot Z3X EasyJtag Software ver. 2.3.0.1 Loading eMMC Addon Firmware... IO: 1800 mV Box S/N:------------, ,FW Ver.: 01.55CMD Pullup Level:1619 mV CMD Active Level:2310 mV Box IO Level:1800 mV CLK Rate:7000 khz HiPower mode is off! ---------- eMMC Device Information ----------EMMC CID : 90014A483447326211012D26118F82BC EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 08/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 757469583 EMMC NAME (HEX): 48344732622000 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. |
