Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 04-21-2014, 18:32   #16 (permalink)
titanic's Avatar
Member: 63065
Sonork: 100.102547
Thanks Meter: 23
Speed matters!!!!!
Writing file...D:\Phones\Easy Jtag\I9300\EMMC_ROM2_00000000_00200000.bin
Z3X EasyJtag Software ver. 1.1.0.0
Skip loading eMMC Addon Firmware
CMD Pullup Level:1608 mV
CMD Active Level:2217 mV
Writing 000000200000 bytes to 00000000 ...ROM2
Write Length has been corrected to 0x000000080000 bytes...
Write Speed: 820 kB/s
Done !!!
Cheers
BR,
The Following User Says Thank You to titanic For This Useful Post:
Old 04-21-2014, 18:36   #17 (permalink)
titanic's Avatar
Member: 63065
Sonork: 100.102547
Thanks Meter: 23
bugs to be fixed
usb port open fail.
read emmc error: "cant init emmc"
BR,
Old 04-21-2014, 19:00   #18 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 176,638
Originally Posted by titanic View Post
usb port open fail.
BR,
when this happends? please explaine
Old 04-21-2014, 19:44   #19 (permalink)
titanic's Avatar
Member: 63065
Sonork: 100.102547
Thanks Meter: 23
error log
sorry could not log them but will respond to it soon.
and help with logs too.
but the speed is the best.
i9300 whole process finished in 14min.
BR,
Old 04-22-2014, 04:24   #20 (permalink)
Member: 1836541
Thanks Meter: 82
tHANK TEAM VERY FAST
Old 04-22-2014, 10:29   #21 (permalink)
Member: 1911593
Sonork: 100.1645151
Thanks Meter: 122
Thanks Team Easy-Jtag!
EasyJtag Suite ver.: 1.1.0.0 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition.
Successefuly connected to box on COM63
Box S/N: 0100900689******, ,FW Ver.: 01.49
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AA1*-**** , ver: 22
Loading eMMC Addon Firmware...
CMD Pullup Level:1361 mV
CMD Active Level:1258 mV
eMMC Device Information
EMMC CID : 1501004B594C30304D122EAF7E9DCE84
EMMC CSD : D02701320F5903FFF6DBFFEF8A404066
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 12/2011 Rev.0x12
EMMC NAME: KYL00M , S/N: 783253149
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 512 kB
EMMC ROM3 (Boot Partition 2) Capacity: 512 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Backup saved: KYL00M_ 783253149_20140302_1444.extcsd
Done.
Running:SAMSUNG: Smart Factory Reset + Format...
Sending Smart Wipe Request...
Wiping Card... Please do not touch it!!!
Done.
Please don't forget to repair extCSD from backup!!!
extCSD file...E:\EASYJTAG\Backups\KYL00M_ 783253149_20140302_1238.extcsd
Running:Repair extCSD...
Writing...
Done!
Done.
Writing file...E:\Full Dump Riff\A820L\A820L-512MB.BIN
Writing 000020000000 bytes to 00000000 ...ROM1
Write Speed: 528 kB/s
Done !!!
Old 04-22-2014, 16:33   #22 (permalink)
F-Buzz's Avatar
Member: 730337
Thanks Meter: 65
speed jet
write done
The Following User Says Thank You to F-Buzz For This Useful Post:
Old 04-22-2014, 16:39   #23 (permalink)
alkim's Avatar
Member: 992568
Sonork: kulit
Thanks Meter: 226
support nexus s i9020t thanks
The Following User Says Thank You to alkim For This Useful Post:
Old 04-22-2014, 19:52   #24 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 757
thanks z3x team for ideal speed.it is work perfect and very good speed.
Operating system ver.: Windows 7 (build 7601, Service Pack 1).
Successefuly connected to box on COM3
Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.49
Z3X Card Serial : AA3B-2511 , ver: 22
CMD Active Level:1680 mV
EMMC CID : 15010056545530304D08637E86212178
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Date: 02/1998 Rev.0x8
EMMC NAME: VTU00M , S/N: 1669236257
EMMC ROM1 (Main User Data) Capacity: 14910 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Backup saved: VTU00M_1669236257_20140302_1031.extcsd
Done.
Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM2_00000000_00200000.bin
CMD Pullup Level:1185 mV
Write Speed: 511 kB/s
Done !!!
Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM1_00000000_20000000.bin
Write Speed: 508 kB/s
Done !!!
The Following User Says Thank You to drjaved_akhter For This Useful Post:
Old 04-23-2014, 16:31   #25 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 5,915
1ST Post has been updated and new build attached.
The Following User Says Thank You to NoName® For This Useful Post:
Old 04-23-2014, 16:38   #26 (permalink)
Member: 585807
Thanks Meter: 757
sir,
beta exe not repair no product problem.old exe repair please check.beta exe not power on phon
Old 04-23-2014, 17:39   #27 (permalink)
Member: 1815849
Thanks Meter: 9
Z3X EasyJtag Software ver. 1.1.0.1
Box S/N: 0707051BED842DAD, ,FW Ver.: 01.49
CMD Pullup Level:2691 mV
CMD Active Level:2774 mV
EMMC CID : 15010056594C30304D19228C48D99E40
EMMC Manufacturer ID: 0000 , OEM ID: 0000
EMMC Date: 00/0000 Rev.0x0
EMMC NAME: , S/N: 0
Can't init EMMC, Reason: CARD Data FIFO Timeout Error
Check Data Line !!!
i9100,before repair connect,i format samsung,format movinand,repair extcsd,and with error writing rom 1.
now cant connect
Old 04-23-2014, 20:03   #28 (permalink)
shadigsm's Avatar
Member: 280342
Thanks Meter: 68
EasyJtag Suite ver.: 1.1.0.1 / wxWidgets 3.1.0-W-U started.
Successefuly connected to box on COM10
Box S/N: 18FF501759B481A6, ,FW Ver.: 01.49
Z3X Card Serial : AACA-40CD , ver: 22
CMD Pullup Level:1216 mV
CMD Active Level:1660 mV
EMMC CID : 15010056545530304DF7D55234A6CF5A
EMMC Date: 12/2012 Rev.0xf7
EMMC NAME: VTU00M , S/N: 3578934438
Backup saved: VTU00M_3578934438_20140305_2211.extcsd
Done.
Writing file...C:\Users\Shadi\Documents\i9300\EMMC_ROM1_51 2Mb_USER\EMMC_ROM1_00000000_20000000.bin
Write Speed: 495 kB/s
Done !!!
Writing file...C:\Users\Shadi\Documents\i9300\EMMC_ROM2_2M b_BOOT\EMMC_ROM2_00000000_00200000.bin
Write Speed: 490 kB/s
Done !!!
Old 04-24-2014, 08:43   #29 (permalink)
titanic's Avatar
Member: 63065
Sonork: 100.102547
Thanks Meter: 23
can any one highlight thie error
Box S/N: 0606F80FA22B6D2F, ,FW Ver.: 01.49
CMD Pullup Level:1474 mV
CMD Active Level:2258 mV
EMMC CID : 15010056545530304DF1084B4D707F88
EMMC Date: 07/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 139152752
Backup saved: VTU00M_ 139152752_20140304_0942.extcsd
Searching for partition tables...
Read Pages Failed, Reason: CARD Data FIFO Timeout Error
Done.
Br,
Old 04-24-2014, 17:00   #30 (permalink)
Member: 1823012
Thanks Meter: 10
Hallo ihave z3x jtag iwant to repair deadboot sgh i337 and the pinout u show dont mach with my cable eg idont hav NRST RTCK and TDO or which colours are they?
Page generated in 0.59806 seconds with 7 queries
