Old 01-19-2017, 19:15   #1 (permalink)
Member: 180442
Easy-Jtag Box: "Can't init device, Reason: CMD Timeout Error"
Hi
I bought an z3x easy-jtag recently.
The box arrived this week and after I installed it, I tried to read eMMC with it but unsuccessfully.
So now I'm here to ask official developers any help.
To be easier to understand my problem by the support people and by anyone who's facing the same problems I'll try to simplify everything, explain my test conditions and give you images of a log of a phone that I've tried to read. Notice: the phone was fully working before trying to read its eMMC (and is still working, I supose...)
Here we go.
Phone: Samsung Galaxy S4 gt-i9505 (which was perfectly booting and working)
Desktop: Windows 10 x64 Pro + admin rights + driver signature verification disabled + Intel processor + 8GB Ram + 200Mb (upload and download) internet very stable conection
Box Software: Z3X EasyJtag Box Software JTAG Classic Suite ver.2.5.0.6
Box Firmware: 01.58
Configs:
-eMMC Voltage: 2.8 Volt IO
-eMMC CLK Rate: 14MHz
-HiPower CLK Drive Mode = checked
Hardware conditions:
-Samsung original 2A wall charger connected to USB port of logic board
-200 Ohm resistors between CMD / Dat0 and 1.8V testpoint
-Strong/thick wire for Ground connection between box and logic board
-All the Ground pins of the box are connected together
-All the wires have at max 5 centimeters of lenght
Log:
EasyJtag Suite Classic ver.: 2.5.0.6 / wxWidgets 3.1.0-W-U started.
OS ver.: Windows 10 (build 14393), 64-bit edition. Admin rights OK
undefined
Android Explorer ver.: 1.0.0.21
eMMC ODIN ver.: 1.0.11.0
Successfully connected to box on COM26
Box S/N: not important, ,FW Ver.: 01.58
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.1.0, are OK
Z3X Card Serial : not important , ver: 22
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Z3X EasyJtag Software ver. 2.5.0.6
Loading eMMC Addon Firmware... IO: 2800 mV
CMD Pullup Level:1753 mV
CMD Active Level:2567 mV
Box IO Level:2800 mV
CLK Rate:14000 khz
HiPower mode is ON!
Done.
Check the following images
postimg*org/image/7suikbcsh/
postimg*org/image/se9ac7udd/
>>>>>replace the "*" with a "."
All of the above is a test condition to show to official supporters an example o my test conditions.
Now I'll report all that I have already tried to not let people make me waste my time and their with tips and tricks that I could have already tried:
eMMC reading:
I tried to read eMMC of 1 faulty (not booting) gt-i9205 Galaxy Mega
I tried to read eMMC of 1 faulty (not booting) gt-i9505 Galaxy S4
I tried to read eMMC of 1 great condition' gt-i9505 Galaxy S4
----------With Adapter------------
Using th Red Adapter that arrived inside the box' package that I bought from GSMServer, using the adpater's external power (Vcc adpater's pin to 2.8V logic board's testpoint & VccQ adapter's pin to 1.8V logic board's testpoint)
(the adapter is the one on the right side of the picture)
postimg*org/image/75vlusfwh/
----------Without adapter---------
Used USB cable to feed the Logic Board internally + HiPower CLK Drive Mode
---------configs possible---------
tried all the combinations of eMMC voltages + eMMC CLK rates (with and without adapter
I tested all of this in the 3 phones that I mentioned above in an Windows 10 x64 Pro Desktop and then repeated all again in another different Windows 7 x86 Pro Desktop
The results were the same
In the 2 desktops I tried serveral Box software + Box firmware (downgrade too)
EasyJtag_Release_v1.0.105.0 (plus respective firmware)
EasyJtag_Release_v1.7.0.1 (plus respective firmware)
EasyJtag_Release_v2.0.5.0 (plus respective firmware)
EasyJtag_Release_v2.5.0.6 (plus respective firmware)
JTAG reading:
after all of this I tried to JTAG the gt-i9205 follwing all the instrutions of the most recent "EasyJtag_Release_v2.5.0.6" software suite. Using the USB cable + battery to power the logic boarfd as sugest by software suite, etc.. just to check if it could be a fault of the box.
Result: none....
Log:
For support and updates visit "no links"
Check security...
OK
Initialising: SAMSUNG GT-I9205 Config ver.:1.00
I/O Level set to : 2200 mV
Box S/N: not important ,FW Ver.: 01.58
Connecting to Target...
Done with error(s)...
What I didn't tried:
I didn't tried to dessolder the eMMC chip and read it directly but I don't see any advantage for me and my clients on that kind of service so I'm not interested in trying too
Last toughts:
For general users: If anyone have any valid sugestion please feel free to leave your answer and share your experience
For developers + official z3x supporters: it would be nice to hear any help from you. And if you think that this box unit can be faulty, please tell me so I can ask for a replacement on GSMServer seller
Best regards for all
Old 01-20-2017, 08:23   #2 (permalink)
Member: 1398121
please check your adapter for resistor pullup 100 ohm, and vcc,vccq voltage.
direct emmc can't use usb or battery, it must use adapter to supply vcc,vccq.
and what connection you use for jtag?
Old 01-20-2017, 17:56   #3 (permalink)
Member: 180442
why is there an "HiPower CLK mode" so?
Have you tested, sucessfully, the solution that you're sugesting?
I used the connection sugested by the image on last version of EasyJatg...
I'm still waiting from developers answer/support... Aren´t you there?
Old 01-29-2018, 11:23   #4 (permalink)
Member: 1436644
hello please help i have this problem too when connect emmc with easy jtag only Can't init device, Reason: CMD Timeout Error but connect phone with octoplus tjag all norm
Old 01-29-2018, 12:48   #5 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,788
connection problem or damage hw
Old 02-11-2018, 15:28   #6 (permalink)
Member: 1436644
Exclamation help
Compression is ON
Z3X EasyJtag Box JTAG Софт версия. 2.9.0.0
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 09FFB01DA436B525, ,FW Ver.: 01.62
Напряжение подтяжки линии CMD :3104 mV
Напряжение активной линии CMD :3176 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Сделано.
Old 02-11-2018, 18:36   #7 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 557
If have problems then don't forget upload your emmc adapter pic
Old 02-12-2018, 16:34   #8 (permalink)
Member: 2438408
Thanks Meter: 380
Originally Posted by tecnotel View Post
Hi
Here we go.
Box Firmware: 01.58
Configs:
Log:
undefined
CLK Rate:14000 khz
HiPower mode is ON!
Done.
eMMC reading:
JTAG reading:
Result: none....
Log:
Check security...
OK
Last toughts:
Check clk or cmd properly not connected show this error
The Following User Says Thank You to alexid For This Useful Post:
Old 02-13-2018, 06:14   #9 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Originally Posted by obel-x View Post
Compression is ON
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Сделано.
Can you make a photo of your set-up? What ISP adapter is used for connection ?
Page generated in 0.22061 seconds with 8 queries
