10-23-2018, 09:57 | #1 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1970633 Status: Offline Thanks Meter: 15 | Is possible to recover data? no partition table found box detect it but he say: Operation: Find table from emmc here is full log: eMMC_tool Suite ver. 1.5.2.0 (release date: 06.08.2018) Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.23403) Looking for EasyJTAG box... EasyJTAG API ver. 2100 EasyJTAG Box Serial = 152E1C886C40EFCE Card Serial = AAD0788C EasyJTAG Box Firmware = 2.30 Changelog: 06.08.2018 (ver 1.5.2.0) Fix: Bugs that have been found through your crash report Fix: Writing ROM2 for Samsung (Write by vendor) Fix: Freezing the program on a RandomVerify Add: Folder for saving to Explorer (in settings) Add: Extract from store.vol from emmc (explorer) Add: Automatic repair of damaged store.vol when extracting (Explorer) Add: Adding MountPoints for partitions (efs, userdata) when formatting Add: Checking for an empty EFS before backup (Read by Vendor Samsung) Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 Mhz EMMC Device Information : EMMC CID: 11010030303447453001D1980249922B EMMC CSD: D05E00320F5903FFFFFFFFE7924000E3 EMMC Manufacture : TOSHIBA , EMMC NAME: 004GE0 , HEX: 303034474530 , S/N: D1980249 , rev. 0x01 EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2015 EMMC ROM 1 (Main User Data) Capacity: 3776 MB (0000EC000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 004GE0_D1980249_20181023_105613.extcsd EMMC Init completed. Scanning soft partitions Partition table not found Get firmware version Brand = WIKO Manufacturer = WIKO Model = SUNSET2 CPU Abi = armeabi-v7a Mediatek platform = MT6572 Android release = 4.4.2 Firmware version = ALPS.KK1.MP7.V1 Firmware date = Wed Jan 6 16:49:02 CST 2016 Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 Mhz EMMC Device Information : EMMC CID: 11010030303447453001D1980249922B EMMC CSD: D05E00320F5903FFFFFFFFE7924000E3 EMMC Manufacture : TOSHIBA , EMMC NAME: 004GE0 , HEX: 303034474530 , S/N: D1980249 , rev. 0x01 EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2015 EMMC ROM 1 (Main User Data) Capacity: 3776 MB (0000EC000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 004GE0_D1980249_20181023_105627.extcsd EMMC Init completed. Operation: Find table from emmc Vendor: Mediatek Platform: MT6572 Searching GPT ... GPT header is not found Searching PMT (MediaTek) ... Error reading at address: 000000800000 , error: -3, DATA RCV Timeout Error ... Retry #1 Error reading at address: 000000800000 , error: -3, DATA RCV Timeout Error ... Retry #2 Error reading at address: 000000800000 , error: -3, DATA RCV Timeout Error ... Retry #3 Error reading at address: 000000800000 , error: -3, DATA RCV Timeout Error ... Retry #4 Error reading at address: 000000800000 , error: -3, DATA RCV Timeout Error ... Retry #5 Too many errors. Reading has been stopped |
